My razr maxx gsm and 4.1.2 JB?
Posted 14 February 2013 - 10:14 PM
I have a question about Jelly Bean, I have now 4.0.4 ICS on my Razr Maxx xt910 GSM and I really want to improve my phone by changing from ICS to JB.
Is there any manual way, or just any way to install 4.1.2 JB on my phone?
P.S.
My phone is rooted and I have some mexican/spanish network (Claro) ICS version, not Verizon.
Thanks for reading and eventual help
Cheer, Michal.
Posted 15 February 2013 - 01:50 PM
Posted 15 February 2013 - 09:07 PM
Can you tell me what is the vzw leak?if you flash the vzw leak it will mess up and brick your phone.
And do you mean that there's no way at the moment to upgrade my soft?
Posted 15 February 2013 - 10:21 PM
If you are rooted with a recovery installed you can run 4.2.1 AOKP or CM10.1.
Posted 16 February 2013 - 01:00 AM
Better software anyway, but can you link me or explain how to install that soft on my phone step by step without bricking my deviceIf you are rooted with a recovery installed you can run 4.2.1 AOKP or CM10.1.
Thanks for answer
Posted 24 February 2013 - 12:01 PM
its the new one and have gsm !
download all the files!!
when u finished to download put it on ur ext sd card in place u can find it!
1.download safe stap from here:
2.install apk, and open safe strap.
3.install recovery
4.now reboot ur device
5,when u see safe strap click on the left bottun.now u got into the safe strap menu
6.click backup click down at the use external sd, and swipe
7.click boot opetions. rom slot 1, click 1 gb and create rom slot.
8.now open rom slot 1 and activate it.
9.come back to the menu and click install, now go to the aokp zip and click and swipe. after its done add more zip and click attached then swipe
10.go back to the menu and click wipe. wipe cache and delvik cache
11.now reboot the system and let it install itself
11.when its done, reboot again and come to the boot strap menu
12.click install and install google app, and again the attached,
13,come back to wipe and wipe cache and dalvik cache.
14, reboot and u got urself aokp 4.2.2 with google apps!
if u want to come back to ur original rom come back to the bootstrap menu and click boot opetions and activate the stock rom
thats it!
Posted 13 March 2013 - 03:34 PM
i think u should install aokp 4.2.2
3.install recovery
thats it!
At the end when I tryied to turn on, after PIN came out a massage that 'Google services Framework has stopped working' and 'Setup wizard has stopped working' Maybe I did something wrong please answer!
Also tagged with one or more of these keywords: jelly bean, 4.1.2, razr, maxx, gsm
