how can i print out text messages?
Posted 10 February 2013 - 08:55 AM
What's a easy way to do this?
Thanks in advance
Posted 10 February 2013 - 09:33 AM
I'm dealing with a divorce and need to print out 600 text messages between my ex and I.
Thanks in advance
There is an app called SMS Backup. if the text messages are still on your phone. Use this app to back them up to an email acct. then print them out. I think you have to use your gmail acct.
- SYSo likes this
Posted 10 February 2013 - 09:38 AM
Good luck though.
Sent from RAZR Maxx FlyingJelly
Posted 10 February 2013 - 12:17 PM
I think you can also log into your account online and there may be an option
Logging into Vzw will only give a log list of what messages were sent like when and two what number, incoming or outgoing. But the text content isn't logged on there. Unless they're still on the phone, their content is gone.
Sent from my SCH-I605 using Tapatalk 2
Posted 10 February 2013 - 12:37 PM
Posted 10 February 2013 - 02:05 PM
Posted 10 February 2013 - 08:33 PM
Posted 10 February 2013 - 08:43 PM
Thanks in advance
Curiosity, how much did this site (and/or other Android sites) contribute to the divorce in the first place?!
Posted 10 February 2013 - 10:47 PM
Sent from my Droid Razr Maxx running on high octane with Jelly Bean
Posted 11 February 2013 - 12:40 AM
- johnlgalt, shane1 and IAmMarino like this
Posted 27 July 2013 - 05:29 PM
Try using
. You can set up a a message format to look however you want, and then email the texts to yourself and print them out. Lots of options...even include MMS image attachments.#13
Posted 06 November 2013 - 01:04 AM
I happened to have found that iPubsoft has published its newly Android Desktop Manager which seems to have this function, i just saw a guide in their Android tips among the Resources page, named "An Easy Way to Print off Text Messages from An Android Phone", you can have a look at that! I just used this, and it works!
- millyce likes this
Posted 11 November 2013 - 11:35 PM
I have been face this problem,I use the Coolmuster Android Assistant to help me print out my text message,it also help me breezily push music, videos, photos, etc. from PC to your phone;Add, delete, unduplicate and edit contacts on PC.If you want to print out your Android phone text message with less time,you can use this tool to help you too.
Posted 16 April 2014 - 01:11 AM
Well, use the Vibosoft Android Mobile Manager.
Since I bought “Vibosoft Android Mobile Manager” and use it, no matter how many text messages I have, It can provide me a fast speed for backup.
You can find the guide here:
- Kolpoiu likes this
Posted 27 April 2014 - 04:53 AM
Sent from my DROIDX using Tapatalk 2
Posted 11 September 2014 - 03:28 AM
As for me, I used How to print Text Messages software to print out android phone messages, it is capable of transfer messages, contacts, photos and video from an Android phone to computer. Due to the ease-to-use interface, it's ideal for everyone.
Posted 26 December 2014 - 10:27 PM
To print out android phone messages on computer, you need to move them to computer at first, then you can print them out as you like.We can use Coolmuster
to move android phone messages to pc easily.#19
Posted 06 July 2015 - 01:10 AM
If you just need to save/
.You can do simple screen capture? Simultaneously press 'power' and 'volume down' buttons to capture the screen. Then, you can save or share the image, or even print it out if you really want a paper copy for some reason.- Jkbllaa likes this
Posted 19 October 2016 - 05:49 PM
http://www.android-s...-recovery.comhttp://www.transfer-...a-recovery.com If you do not think about your future, you cannot have one.
