[How To] What Is Adb And How Do I Use It? Find Out How To Manipulate Your System Files
48 replies to this topic
#41 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 13 February 2012 - 03:18 PM
I posted this in the unbrick your phone thread as well, but thought it would be more appropriate here. It seems my work computer will only recognize my phone as connected when booted up normally. In Fastboot Mode, ADB doesn't show any devices as being connected??
I could use some help getting ADB set up on my work computer. Running Windows XP & followed all instructions completely. When I enter a command prompt, type "adb devices" & the phone is booted up normally, it shows my phone is connected. When I attempt to repeat this in AP Fastboot mode though, I encounter 2 problems. First, it begins to look for devices, shows "Devices Attached," but there is no serial number. Second, when I type "moto-fastboot.exe flash system system.img" it says that this isn't a recognized command. Any thoughts on what I am doing wrong?
Edit: I have exhausted every option I can think of, but still can't get it setup & working. This is super frustrating since I was able to successfully set it up on Windows Vista.
#42 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 14 February 2012 - 11:49 AM
Still looking for some help here! I reinstalled the SDK/JDK/Moto Drivers, and have tried 2 different computers. My phone still appears to not be recognized by ADB when in Fastboot. When booted up normally, I typed the "adb devices" command which worked; my phone was displayed. I also used "adb reboot-bootloader" to reboot into Fastboot mode. That worked, but once the phone was there, it still wasn't recognized. I opened RSD Lite as well to cross check, and it appears that it won't recognize the phone either? I'm stumped! Can someone help me figure this out please?
Edit: Still haven't found an answer to this question, but just wanted to share that despite it,
was able to get the job done!
#43 bikebuilderdude
bikebuilderdude
  • 23 posts
Posted 15 February 2012 - 02:07 PM
  69.89KB   20 downloads
When installing SDK Usb drivers, what is "Stopping ADB server failed (code -1)" and is it anything to worry about? Other than that it did install the drivers and I see the phone in cmd. Thanks.
#44 bikebuilderdude
bikebuilderdude
  • 23 posts
Posted 20 February 2012 - 07:15 AM
Bignadad: I have two questions about setting up SDK. I was reading the install instructions at the SDK web site and for Path they say "double-click on Path (under System Variables)." and yours says under User Variables, what is the difference between these? If you do use User Variables, does is matter what name you give it (I've seen XDA list it as ADB for the name)? Thanks.
#45 in_dmand
in_dmand
  • 7 posts
  • LocationUSA
Posted 05 March 2012 - 05:37 PM
stuck on step # 9.... can't find "SDK Setup.exe" in the folder that i extracted from the link you posted... all i'm showing that are actual programs are "SDK Manager" and "AVD Manager"... what am I doing wrong?
#46 sparkie
sparkie
  • 45 posts
  • Locationoregon
Posted 11 March 2012 - 07:27 AM
In the Android SDK Manager are you suppose to check every box in the list and install the packages?
#47 vols4life
vols4life
  • 123 posts
Posted 30 June 2012 - 05:50 PM
to a folder on my desktop.C:\program files(x86)\android\android-sdk......... screenshots would be cool
The problem with that is you can't have your tools folder in a folder with spaces. So with Program Files (x86) its not going to work. Move the sdk to Windows or some other folder with no spaces and it will work. Try C:\Windows\android\android-sdk then fix your path and it will work. Maybe this should be put in the OP to help with people who aren't familiar with adb.
#48 vols4life
vols4life
  • 123 posts
Posted 01 July 2012 - 03:41 PM
And i know that's my first post but i used to theme on the OG Droid back in the day.
#49 BraulioArellano
BraulioArellano
  • Current Device(s):Motorola RAZR hd Maxx
Posted 28 April 2013 - 06:18 PM
Thank you very much for this post.  Not only was it useful info to use the sdk correctly, but I learned That I can really speed up my old pc.  Thanks again!
