[ROM] Batakang ROM for Jellybean XT912 - by Kebob Sparkyman and mattlgroff
209 replies to this topic
#141 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 28 February 2013 - 05:28 PM
I would like to be able to use webtop.
You could probably pull all of the files you need from the system/app folder of any deodexed ROM based off the JB leak. Then use a file manager to push them to system/app on batakang & match permissions.
#142 St33l
St33l
  • 62 posts
Posted 28 February 2013 - 06:07 PM
mattlgroff, why it's impossible to update google chrome by PlayStore? It say "incompatible package" or "wrong signature". What can I do?
#143 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 28 February 2013 - 06:21 PM
You need to use Titanium backup to uninstall then reboot and re-install from the play store.
#144 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 28 February 2013 - 10:47 PM
+1
#145 ziggity
ziggity
Posted 01 March 2013 - 05:42 AM
Would anyone know what files to restore to enable web top function?
#146 garywojdan81
garywojdan81
  • 633 posts
Posted 01 March 2013 - 06:10 AM
Try:
WelcomeWebtop.apk, MotoDockHelperService.apk, DockService.apk & DockComm.apk.
#147 mllora81
mllora81
  • 25 posts
Posted 01 March 2013 - 02:56 PM
Here's all of those webtop apks in a zip file
I tried to push them to system/app on batakang & match permissions, but no webtop won't work.
Edited by mllora81, 01 March 2013 - 03:29 PM.
#148 ziggity
ziggity
Posted 01 March 2013 - 03:50 PM
Mattlgroff
Sorry to hijack maybe we should start a new thread dedicated to restoring all files needed for web top in a flash able zip file? Sorry if this sounds ridiculous but I have noticed web top works in some instances and it would be nice to install a custom ROM and apply a zip flash for web top 3.0
#149 caseyk44
caseyk44
  • 15 posts
Posted 01 March 2013 - 09:56 PM
For the circle and favorite widget problem I noticed it seems to be related to screen rotation. I've had good lucking fixing it by using TiB to make circle and favorite apks system apps. Hope this is helpful.
#150 St33l
St33l
  • 62 posts
Posted 04 March 2013 - 07:41 PM
Guys, who knows, why so many "USB" kernel wake locks? And what does it mean?
#151 Dreamliner
Dreamliner
  • 15 posts
  • Current Device(s):RAZR MAXX HD
Posted 04 March 2013 - 10:19 PM
In wondering why when I use voice input the Window pops up instead of the real - time voice to text?
Also, thoughts on that script mod with this rom?
#152 Shinare
Shinare
  • 235 posts
Posted 07 March 2013 - 09:22 PM
My batakang bootloops after flashing hashcodes ss stock slot soak update for Xmas JB leak. Stock slot boots fine into soak version so I'm using that now.
Sent from my toilet (probably) using Tapatalk 2.
#153 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 07 March 2013 - 10:46 PM
I got it booting with a fast and dirty merge with the new build. I get hot reboots and non-fully working WiFi. Progress though I guess.
Will work on it more tomorrow.
#154 Shinare
Shinare
  • 235 posts
Posted 08 March 2013 - 05:00 AM
Thanks Matt! Your efforts do not go unappreciated.
#155 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 08 March 2013 - 11:05 AM
Fixed compatibility issues!
#156 HSD-Pilot
HSD-Pilot
  • 303 posts
  • LocationGermany
  • Current Device(s):RazR
Posted 08 March 2013 - 11:10 AM
Nice.
But what i don't understand > Why nobody supports BMM? I mean i don't even need an PC to switch Kernels/Basebands and i can use / create Slots on internal Memory or Webtop Partition.
Every Leak based Rom works flawless, even on Stock Slot.
I really don't get it :blink:
Gesendet von meinem XT910 mit Tapatalk 2
Soundcloud <> Bassgrow
#157 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 08 March 2013 - 12:55 PM
Nice.
Probably because Kexec doesn't work as well on it or something...?
  • ninrulz likes this
#158 N1-tr0
N1-tr0
  • 16 posts
Posted 08 March 2013 - 02:55 PM
KEXEC works fine on BMM, just tested a few hours ago
#159 HSD-Pilot
HSD-Pilot
  • 303 posts
  • LocationGermany
Posted 08 March 2013 - 03:34 PM
:ph34r:
#160 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 08 March 2013 - 04:04 PM
:ph34r:
Guess it works just fine then! To each his own
