[ROM] Batakang ROM for Jellybean XT912 - by Kebob Sparkyman and mattlgroff
209 replies to this topic
#61 money mike
money mike
  • 284 posts
Posted 12 February 2013 - 05:16 PM
Matt, I've been running Droid HD Rom for a while now. Absolutely love it...I have not taken OTA Jb leak. Are there any known issues for using Dual Boot Method to load Batakang? Thanks keep up the awesome work....
I'm dual booting Batakang with no issues. It's running flawless as far as I can tell.
  • droid1177 likes this
#62 droid1177
droid1177
  • 49 posts
  • LocationGa, USA
Posted 12 February 2013 - 05:26 PM
Awesome, I'm stoked to give this a try. Just one quick question for anyone who could answer. I need to have a functional wifi tether. I currently use an open source app for this, as I don't have SQ Lite to change any values. Will the open source app still work? Many thanks...
#63 melfunn
melfunn
  • 165 posts
  • LocationNashville, TN
Posted 12 February 2013 - 05:46 PM
You can download sqlite from the play store.
#64 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 12 February 2013 - 06:28 PM
Also people should be aware when pirating if you refuse to support the dev, that older versions don't work right and will error. I ran into this with users on the RAZR HD Jellybean.
#65 droid1177
droid1177
  • 49 posts
  • LocationGa, USA
Posted 12 February 2013 - 06:43 PM
Just flashed , so far so good... These DEVs are really something else. I never cease to be amazed...
#66 droid1177
droid1177
  • 49 posts
  • LocationGa, USA
Posted 12 February 2013 - 06:50 PM
Please don't take my post the wrong way. I was simply stating that I didn't have it. If I do end up needing to do the value change, I will most certainly do so. You guys rock... Thanks for the hard work and dedication...
Edited by droid1177, 13 February 2013 - 11:45 AM.
#67 money mike
money mike
  • 284 posts
Posted 12 February 2013 - 08:11 PM
Wifi tether for root users works great on batakang. I posted earlier in the thread what settings I used to make it work.
#68 bleulin
bleulin
  • 19 posts
  • Twitter:bleulin
  • Google+:bleulin
Posted 12 February 2013 - 09:44 PM
Can it flash on stock slot?
#69 Shinare
Shinare
  • 235 posts
Posted 12 February 2013 - 09:48 PM
Finally upgraded to 1.32 tonight when i ran out of space on my rom slot. 1GB just isn't big enough. heh thanks for all your work Matt.
Sent from my toilet (probably) using Tapatalk 2.
#70 thrasher194
thrasher194
    http://androidn00b.com/
  • 226 posts
  • Google+:Thrasher194@gmail.com
  • LocationNorthCarolina, USA
  • Current Device(s):Motorola G4 Play (xt1609)
Posted 13 February 2013 - 12:34 AM
i wouldn't flash anything to stock until we have fastboot.
#71 dave5777
dave5777
    Crack Flashing MOFO
  • 145 posts
  • LocationCali
  • Current Device(s):RAZR MAXX, NEXUS 7 32gb
Posted 13 February 2013 - 03:43 AM
Hotspot works after this fix ***If you want to use tethering, you must use the SQLite Editor app to change the line "entitlement_check" from a 1 value, to a 0 value, then reboot.
com.motorola.android.providers.settings,
Line 66
#72 droid1177
droid1177
  • 49 posts
  • LocationGa, USA
Posted 13 February 2013 - 10:17 AM
Is the no frills CPU app baked in? I didn't see it anywhere so I downloaded it and installed it but can't seem to find it anywhere. Strange...
  • satman80 likes this
#73 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 13 February 2013 - 07:16 PM
Quick Question, Any audio EQ etc....?
Also does the Alarm with Circles work yet?
Edited by satman80, 13 February 2013 - 07:17 PM.
Site Rules and Guidelines
#74 bleulin
bleulin
  • 19 posts
  • Twitter:bleulin
  • Google+:bleulin
Posted 13 February 2013 - 08:54 PM
but i want...
#75 thrasher194
thrasher194
  • 226 posts
Posted 13 February 2013 - 09:40 PM
flash to slot 1 to be safe bro
#76 HSD-Pilot
HSD-Pilot
  • 303 posts
  • LocationGermany
  • Current Device(s):RazR
Posted 13 February 2013 - 10:04 PM
but i want...
I do :ph34r: ;)
Sent from my XT910
Soundcloud <> Bassgrow
#77 logan3824
logan3824
  • 308 posts
  • LocationHouston, Texas. GO TEXANS!
Posted 13 February 2013 - 10:10 PM
but i want...
If you were to flash it to stock and then screw up the phone in any way then you'd be (to put it lightly)...f%$ked. We have no way to fastboot it at the moment.
#78 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 14 February 2013 - 02:34 AM
Not entirely.. they can unbrick as long as they have enough battery power or a factory-cable using the
Windows utility.
#79 jpjm132003
jpjm132003
  • 25 posts
  • LocationHuntington Beach
Posted 14 February 2013 - 08:27 AM
Quick question, which would be the best procedure to flash?
1. Flash rom and boot.... let it settle..... reboot and flash Gapps
or
2. Flash rom, flash Gapps, then boot?
EDIT:
Flash Rom, flash Gapps then boot.
I tried it the first way and the setup FC'd. Flashing both works briliantly.
#80 logan3824
logan3824
  • 308 posts
Posted 14 February 2013 - 10:32 AM
or
EDIT:
Yea, you have to install Gapps before initial setup or you'll run into a heap of problems.
