[ROM] Batakang ROM for Jellybean XT912 - by Kebob Sparkyman and mattlgroff
#41
Posted 10 February 2013 - 04:09 PM
#42
Posted 10 February 2013 - 05:20 PM
Did you use SQL lite to edit the entitlement check? Mine works fine I'm not using any security.I am unable to connect to mobile hotspot
- luke61456789 likes this
#43
Posted 10 February 2013 - 05:43 PM
so weird I did what you told me it worked why is that? Thank you very much.I'd check your md5 for the hardware version its 0b4e8696e2aee67734c6a2ee3960583b
I don't have the soft. If it's good then I would start from scratch delete ROM slots reboot into stock ROM then delete the safestrap folder on your internal then try it again.
#44
Posted 10 February 2013 - 05:48 PM
ROM slots are like condoms you can only use them so many times before they don't work any more.so weird I did what you told me it worked why is that? Thank you very much.
- caseyk44, chuckyteets, rmoya5150 and 2 others like this
#45
Posted 10 February 2013 - 06:03 PM
#46
Posted 10 February 2013 - 06:06 PM
hahahahahahahha I really had no idea and Ive been flashing for awhileROM slots are like condoms you can only use them so many times before they don't work any more.
#47
Posted 10 February 2013 - 06:31 PM
Crack Flasher's ParadiseI hate you guys...always releasing great stuff. My phone hasnt had the same rom for more than a week...lmfao. This is awesome. Great work guys.
#48
Posted 10 February 2013 - 11:05 PM
Trumpet The Harlot - Lead Guitar
#49
Posted 11 February 2013 - 01:01 AM
#50
Posted 11 February 2013 - 04:46 AM
My only (minor) complaint is that the Google search bar is pinned to the top of the home screen. Is there a way to make that go away so I can use that bit of real estate that way I'd prefer?
#51
Posted 11 February 2013 - 05:59 AM
you could just download apex or novaGreat ROM, thanks for the hard work guys!
#52
Posted 11 February 2013 - 07:03 AM
Thanks for the tip, but I'm liking the circle widgets.
#53
Posted 11 February 2013 - 09:47 AM
If you are heartset on circles, you can't remove that google search bar to my knowledge.Thanks for the tip, but I'm liking the circle widgets.
#54
Posted 11 February 2013 - 10:35 AM
#55
Posted 11 February 2013 - 11:02 AM
small improvements would be to have the reboot button and a working gallery edit feature.
#56
Posted 11 February 2013 - 10:07 PM
Any suggestions?
#57
Posted 12 February 2013 - 12:30 AM
#58
Posted 12 February 2013 - 01:11 PM
#59
Posted 12 February 2013 - 02:13 PM
That's odd dude. Snap is working fine for me.
weird. it's not working on aviator either so i don't know what's going on.
#60
Posted 12 February 2013 - 04:34 PM
