[ROM] Batakang ROM for Jellybean XT912 - by Kebob Sparkyman and mattlgroff
209 replies to this topic
#201 Ethan82691
Ethan82691
  • 113 posts
  • Google+:blindside7x@gmail.com
  • LocationIdaho
Posted 29 May 2013 - 12:37 PM
Use
tool to switch your Kernel to the Xmas leak
Thank you! I am looking at the tool now, and to run batakang ROM i need to be on the .16 kernel, and in the tool it does not have an option for the Leak rom on the .16 kernel, they both show .8. Any ideas?
Ethan82691
#202 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 29 May 2013 - 12:41 PM
You need to be on the Leaked .8 Kernel for this Rom.
#203 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 29 May 2013 - 12:46 PM
Really? On this page:
It shows that i need to be on the .16 kernel
Ethan82691
#204 Memnoch73
  • 5,016 posts
Posted 29 May 2013 - 12:49 PM
Hmm.. I guess it does. However the OP of this thread says: DROID RAZR XT912 or DROID RAZR MAXX XT912 on the Jellybean Leaked Update
It also has a link to the same tool I gave you posted right below it.
I will fix the other thread. Sorry for the confusion
#205 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 29 May 2013 - 01:04 PM
Not a big deal at all! I tried that it worked! You are a genius. I thank you very much for showing me the tool!
  • Memnoch73 likes this
Ethan82691
#206 Memnoch73
  • 5,016 posts
Posted 29 May 2013 - 01:10 PM
Glad to hear it man... Happy to help.  :)
#207 DroRzr
DroRzr
  • 97 posts
  • Current Device(s):XT912, Nexus7
Posted 30 May 2013 - 06:25 AM
flash to slot 1 to be safe bro
CM10.1 in SS slot I. Like it. Want to try this in slot 2. Will it work there? Not quite ready to pack in CM 10..need to try this to test my opinion. Thanks!
#208 DroRzr
DroRzr
  • 97 posts
Posted 02 June 2013 - 06:38 PM
Wow! NO response?? Has Anyone tested this in Slot 2 or 3??
#209 cmh714
Posted 02 June 2013 - 06:57 PM
You should be fine in slot 2 but you need the xmas kernel, as in .8
#210 ernibal1musicman
ernibal1musicman
Posted 08 July 2013 - 07:23 AM
Has anyone else noticed that on the soft key version (I cant speak for the hard key version) the music player widget on the lock screen doesn't work? seems like the unlock ring is covering it and blocking you from pausing, or changing songs while the screen is locked. Any fixes for this? or should I give the hard key version a try?
