[ROM] Batakang ROM for Jellybean XT912 - by Kebob Sparkyman and mattlgroff
209 replies to this topic
#181 FretNoize
FretNoize
  • 16 posts
Posted 25 March 2013 - 11:30 AM
Does anyone else notice "popping" sounds emitted at random times from the speaker when running the ROM?
#182 calebgreenwood
calebgreenwood
  • 10 posts
Posted 05 April 2013 - 10:17 AM
Cant get it to boot past safe strap screen just keep boot looping? any ideas installed and reinstalled safe strap cleared files downloaded and redownloaded files? any other ideas?
#183 cmh714
Posted 05 April 2013 - 10:20 AM
This is for the .8 kernel from Xmas eve. If you are on .16, then your choice would be to use Matts ROM Compatibility flasher to downgrade the kernel to .8
  • PillClinton likes this
#184 calebgreenwood
calebgreenwood
  • 10 posts
Posted 05 April 2013 - 10:26 AM
oh ok makes sense! thanks a bunch
#185 calebgreenwood
calebgreenwood
  • 10 posts
Posted 05 April 2013 - 10:40 AM
is there a big difference in the .8 kernal and the .16?
#186 msidner
msidner
  • 11 posts
Posted 05 April 2013 - 06:59 PM
So far so good, just got done flashing, swapping kernels, etc. Dumped a bunch of my normal junk on and so far its running clean. Only complaint really, and maybe there's something I'm missing somewhere, but I really miss having the reboot and screenshot items in the power menu. Is there a way to add this in without extensive work? Just curious.
#187 qss247
qss247
  • 28 posts
Posted 29 April 2013 - 09:10 AM
gsm patch ?
#188 jmaher1023
jmaher1023
  • 19 posts
Posted 29 April 2013 - 07:08 PM
Hey matt, is there any way to convince you to do a build based on the .16 kernel? This has been the most stable and smooth ROM, and all the others I've tried on the official ota base seem to be quirky.
Sent from my IdeaTabA2109A using Tapatalk HD
#189 cmh714
Posted 30 April 2013 - 02:31 PM
gsm patch ?
qss youve been here with us long enough to know Matt probably wont make one :)
ZKK wrote up a How To make a GSM patch in the How To section, so I would give that a try.
  • qss247 likes this
#190 qss247
qss247
  • 28 posts
Posted 30 April 2013 - 02:42 PM
gsm patch ?
Thank you sir good.to see you around again
Sent from my XT910 using Tapatalk 2
#191 cmh714
Posted 30 April 2013 - 02:47 PM
Glad youre still kickin in here as well :)
#192 Ethan82691
Ethan82691
  • 113 posts
  • Google+:blindside7x@gmail.com
  • LocationIdaho
Posted 28 May 2013 - 06:36 PM
I am running JB ROM .16 kernel and I cannot get this ROM to work. Once I install it , I reboot from safe strap and the phone just boot loops. I am on safe strap 3.11 any ideas??
Ethan82691
#193 papanut
papanut
  • 107 posts
Posted 28 May 2013 - 06:39 PM
this rom is for the leak, not the official ota update
#194 coletrane09
coletrane09
  • 236 posts
  • Twitter:coletrane09
  • LocationHart, MI
Posted 28 May 2013 - 06:41 PM
In pretty sure this rom is for the Jellybean leak that came out around Christmas time
sent by wireless transmission
  • Ethan82691 likes this
#195 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 28 May 2013 - 07:00 PM
Can you explain that? This is my second RAZR, and it worked okay on the first one. And I updated from ICS to JB through the system update on stock ROM.
Ethan82691
#196 Guest_BDH_*
Guest_BDH_*
Posted 28 May 2013 - 07:03 PM
Requires
DROID RAZR XT912 or DROID RAZR MAXX XT912 on the Jellybean Leaked Update
Directly from the OP.
Sent from my Raged Out HD using Tapatalk (VIP)
#197 Guest_BDH_*
Guest_BDH_*
Posted 28 May 2013 - 07:05 PM
Double
#198 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 28 May 2013 - 07:06 PM
Is there a way for to get this working then?
Ethan82691
#199 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 29 May 2013 - 11:42 AM
Ethan82691
#200 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 29 May 2013 - 11:45 AM
Use
tool to switch your Kernel to the Xmas leak
