1460 replies to this topic
#1441 harry-yuang
harry-yuang
  • 15 posts
Posted 15 June 2014 - 04:58 AM
by stuck on the setup wizard, you mean stuck on the waiting screen?
Sent from my XT1060 using Tapatalk
Yes,I also got this problem,how can i fix ?thanks so much.
#1442 sunkim50
sunkim50
  • 58 posts
Posted 15 June 2014 - 09:24 AM
no fix yet. Dev is reworking his base. it might be a while before it is fixed.
#1443 harry-yuang
harry-yuang
  • 15 posts
Posted 15 June 2014 - 08:37 PM
Got you.have to wait for  a while。。
#1444 TALLYWACKER
TALLYWACKER
    Android caused my divorce !
  • 139 posts
  • LocationSouth
  • Current Device(s):M8 ROOTED S-OFF UNLOCKED, XT926 UNLOCKED
Posted 16 June 2014 - 03:01 AM
Tried flashing this got stuck inna bootloop didnt think much of it until i restored a previous 4.1.2 rom and now its like i have no radio no cell data and no wifi know of a quick fix that doenst require a pc or a fxz ?
#1445 TALLYWACKER
TALLYWACKER
  • 139 posts
  • LocationSouth
Posted 16 June 2014 - 03:04 AM
Like a zip ? Im assuming the rom  zip wiped or replaced my old radio with a kk version ? Wont a zip bring me back ?
#1446 sunkim50
sunkim50
  • 58 posts
Posted 16 June 2014 - 05:28 AM
not that this will help you, but might help others, this rom shouldn't be flashed if you were on JB. you need to be on the latest KK bootloader. with that said, it was stated before that this ROM was not usable.
I think you will need to FXZ back to a 4.1.2 JB setup then just fastboot and load a custom recovery (the one you were previously on) and then restore your backup.
#1447 sgpapesh
sgpapesh
  • 43 posts
Posted 21 June 2014 - 02:29 PM
Tried to install the 4.4.2 beta in TWRP 2.7.1.0. After wiping the cache, data, and system, the install failed.
#1448 Jaysp656
Jaysp656
  • 9 posts
Posted 21 June 2014 - 05:38 PM
Failed for me too. The below spoiler includes the log from TWRP. Hope it helps :)
Spoiler
  • taterfry likes this
#1449 taterfry
taterfry
  • 17 posts
Posted 23 June 2014 - 02:10 PM
Failed for me as well... Does this build include a kernel?
#1450 abonlion
abonlion
Posted 25 June 2014 - 06:07 AM
#1451 aaki_rocker
aaki_rocker
  • 10 posts
  • Twitter:aaki_rocker
  • Google+:aakidevil
  • LocationIndia
  • Current Device(s):Motorola Droid Razr™ HD, Nokia Lumia™ 928
Posted 26 June 2014 - 11:16 AM
flashing the 4.4.2 beta build fails using twrp for stock kk.
has anyone tried using the cwm built for stock kk ?
#1452 harry-yuang
harry-yuang
  • 15 posts
Posted 26 June 2014 - 04:43 PM
yes i did.but failed as well.need to wait till the new version release.
  • aaki_rocker likes this
#1453 j37hr0
j37hr0
  • 13 posts
Posted 13 July 2014 - 06:41 AM
Can't wait for the new 4.4 build
#1454 blindman
blindman
  • 45 posts
Posted 27 July 2014 - 10:41 AM
Missing this ROM after update to kk. Hope we get a working version soon!
#1455 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 27 July 2014 - 12:48 PM
If You are Unlocked. You can use the FlashBack kit to quickly downgrade your bootloader back to 4.1.2. Then install the JB version until JP can work an update. I sent him the links to the Stock KK BASE ROMs I got posted up. So hopefully it will be a matter of when JP can mustard up some time...
$3π+ £®m€ ×X× ®∆z® |/|@xX Π¶ oπ $ø|/|£ťhïñğ ¢ű$ț¤|/|
#1456 blindman
blindman
  • 45 posts
Posted 27 July 2014 - 02:35 PM
I was under the impression you couldn't go back to the jb bootloader after going with kk. Is this wrong?
#1457 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 27 July 2014 - 02:41 PM
Only if your bootloader is unlocked you can go back to the previous bootloader setup.... Still cannot change the partition table or downgrade the tz security partition, but the bootloader no problem as long as you are Unlocked and rooted on KK..
#1458 deeroks
deeroks
  • Current Device(s):DROIDRazr xt926
Posted 06 September 2014 - 09:27 AM
Does anyone have the first original Nexesque Rom? That was by far the best working one for my Xt926 :)
  • legend221 likes this
#1459 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 06 September 2014 - 11:22 AM
Over on XDA the older version can be found for 4.1.2 bootloader.
  • legend221 and deeroks like this
#1460 deeroks
deeroks
Posted 06 September 2014 - 05:45 PM
Got it, thanks :)
