1460 replies to this topic
#121 dunttt
dunttt
  • 177 posts
  • Twitter:dunttt
  • Google+:jon36m@gmail.com
  • LocationChicago IL
Posted 18 February 2013 - 03:03 PM
Not sure if this will cure anyone's woes, but maybe try clearing cache from system recovery (i.e. not safestrap). I used to do this periodically on my og razr, and it would speed things up.
I tried going into recovery and I would let the phone sit for around 30 secs once seeing the little android man then simultaneously pressing volume up and down and power I used to be able to get Into recovery on my OG RAZR. I've tried every button press combo on my HD and can't get the screen to pop up just to clear the cache. any ideas ?
#122 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 18 February 2013 - 03:09 PM
It aint gonna happen because you cant have 2recoverys at the same time either stock or safe
#123 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 18 February 2013 - 03:27 PM
I just did it, so it definitely works. Once you get to the android with the red alert triangle, you gotta press volume up and down at the same time to get to the next menu... Clear system cache and reboot.
#124 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 18 February 2013 - 03:29 PM
Maybe this will help... Idk if it sped anything up, but it didn't hurt either. Worth a shot.
#125 dunttt
dunttt
  • 177 posts
  • Twitter:dunttt
Posted 19 February 2013 - 12:11 AM
You are correct ! Played with it a little more and seems to work the best by holding down the power down after getting to red alert triangle and while holding down power down , press and release power up , and boom instantly I'm in lol. Thanks a lot . I'm running on non safe side right now and I'm starting to think that theory is right about the speed being better ... either this or the difference in the .39 and .41 builds . There's gotta be something different between the two even if its just so minor non of us can tell . Its one of those two its gotta be. This thing is flying right now.
#126 jld
jld
  • 149 posts
  • Current Device(s):Motorola Razr HD MAXX
Posted 19 February 2013 - 10:18 AM
Didn't see this asked yet, but can the update be flashed over? Or do I have to do a full wipe again? Thanks!
#127 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 19 February 2013 - 10:46 AM
I don't know, but I would think that it could most likely be flashed over. If you see any problems, just do full wipes and reflash. Just make sure you back up anything important.
#128 jld
jld
  • 149 posts
Posted 19 February 2013 - 02:17 PM
Dirty flash seems successful so far...
Will report back if I encounter any problems.
#129 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 19 February 2013 - 09:36 PM
I'm uploading a test version to the OP right now if anyone wants to test it out with me. I basically just debloated a ton (removed 21 more system apk's), and I want to make sure everything is still working. It might help free up some more resources like background processes, ram, etc... hopefully make things run smoother.
#130 jtommyj
jtommyj
  • 181 posts
Posted 19 February 2013 - 09:44 PM
I'll give it a shot !
  • adamjmtz likes this
#131 manutcbs
manutcbs
Posted 20 February 2013 - 07:49 AM
REALLY smooth so far. Had to add email.
#132 bboyles4
bboyles4
  • 10 posts
Posted 21 February 2013 - 04:59 AM
Been running this version for a few days. Is super smooth. No lag whatsoever. I restored about 50 apps and everything is running great!
#133 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 21 February 2013 - 05:14 AM
That's great! I haven't noticed anything wrong so far either, but I may give it a few days before I remove the "Test" moniker from it. Just to make sure. I have noticed less ram usage, though, which is good.
#134 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 21 February 2013 - 05:21 AM
Are you gonna leave it as is or are you gonna change it before you let it go.
#135 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 21 February 2013 - 05:28 AM
I'm not sure yet... I'm just waiting to see if there are any bugs. The only thing I've added since posting is the razr camera in addition to the 4.2 cam. I'd say go ahead and use it, because any major changes I'll make won't be for a few weeks at least.
#136 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 21 February 2013 - 05:32 AM
Thanks is the razr cam in there now or can we pick it up somewhere?
#137 triskropf97
triskropf97
  • 118 posts
  • Google+:Triskropf@gmail.com
  • LocationNashville, AR
Posted 21 February 2013 - 08:19 AM
I take it the WiFi hotspot and tether don't work? N great work on this ROM! So fast n smooth...
#138 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 21 February 2013 - 08:40 AM
Havent tried it yet on update but Trevs wifi tether works good for me I dont evev use hotspot.
#139 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 21 February 2013 - 08:42 AM
I don't have it natively enabled in this rom, but you can do it here...
#140 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 21 February 2013 - 10:36 AM
Do we need to do a clean flash if were doing the experiment since there was so much removed.
