1460 replies to this topic
#1281 grnsl2
grnsl2
  • 128 posts
Posted 18 December 2013 - 06:02 AM
jp1044,is the wifi icon supposed to be white instead of blue on 3.7 ?
Sent From My Windows 8.1 Surface Tablet
So im used to the blue going white when I don't have a good data connection; obviously 4g or 3g disappears when there's totally not a connection.
What happens when I still technically have 3/4g but not the data connection now that everything is white all the time?
#1282 kraven
kraven
  • 24 posts
Posted 18 December 2013 - 10:59 AM
3.7 has been overheating my razr, did a fresh install,same thing. Did a fresh install of the rom before the 3.7 update, no overheating. same amount of usage.
  • zack75mercado likes this
#1283 adamtodd06
adamtodd06
  • 5 posts
Posted 18 December 2013 - 11:21 AM
please make a xt925 version!!! please please please. The little turotial/build.prop edits dont work good enough. It needs to be based on a xt925 rom .
thanks a lot
#1284 kraven
kraven
  • 24 posts
Posted 18 December 2013 - 11:46 AM
Solved overheating problem. I adjusted the no frills cpu settings and played with it until my razr was overheating no longer, it was set to the highest cpu settings to begin with
#1285 viper8u2
viper8u2
  • 12 posts
Posted 18 December 2013 - 12:06 PM
I have something odd happening
I notice that the center icons (blutooth, speaker off, alarm and wifi) shift left to right constantly (3 sec's) (looks animated now)
I am using nova launcher and  dirty flashed
Anyone else?
#1286 grnsl2
grnsl2
  • 128 posts
Posted 18 December 2013 - 12:14 PM
mind sharing you ended up with?
#1287 kraven
kraven
  • 24 posts
Posted 18 December 2013 - 12:39 PM
Screenshot of my settings
#1288 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • Google+:jp1044@gmail.com
  • LocationColorado
Posted 18 December 2013 - 02:41 PM
Anyone else?
Yes this is an issue. Everything shifts to the left when there is wifi activity and shifts back when there isn't. I will address this in the next update.
#1289 TerrorTodd
TerrorTodd
  • 20 posts
  • LocationFlorida
  • Current Device(s):Razr MAXX HD
Posted 18 December 2013 - 07:21 PM
I wish I could answer this but to be honest I've been looking for the answer to this ever since I started using governors. This is a pretty good post that explains each governor:
Sent from my Nexesque DROID RAZR HD using Tapatalk Pro
I can't seem to find the governors or NoFrills CPU...where do they live....in the settings???
#1290 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 18 December 2013 - 08:20 PM
No frills should be in the app drawer
#1291 legend221
legend221
  • 70 posts
  • Current Device(s):Motorola RAZR HD
Posted 19 December 2013 - 01:04 AM
thanks a lot
Try this out.
#1292 SoccerDad91016
SoccerDad91016
Posted 19 December 2013 - 11:01 AM
+1
just flashed Nexesque 3.5 with SS 3.12 for XT926 maxx
by far the best ROM for performance.
encountered error when opening the supplied browser, though...
browser wont open and there's error msg " unfortunately com.goggle.process.gapps has stopped " something like that...
wonder what i did wrong ? any suggestions ?
currently replaced the browser with dolphin and no more error msg appear.
Has anyone responded to this issue? I am having the exact same problem with version 3.7
#1293 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 19 December 2013 - 02:52 PM
Did you wipe data when you flashed 3.7?
#1294 legend221
legend221
  • 70 posts
Posted 19 December 2013 - 04:20 PM
Try re-downloading the Rom, follow instructions on OP and you should be good. I have zero issues with the Rom and am as happy as ever on Nexesque. Thanks JP1044!
Sent from my Razr HD running the latest version of Nexesque
#1295 virusalone
virusalone
  • 10 posts
  • Twitter:virusalone
  • LocationRussia
  • Current Device(s):Razr maxx HD locked
Posted 19 December 2013 - 11:19 PM
try to delete hangouts app before sign in into google account. It helped to me with another rom. But nexesque working perfectly to me now.
I have 8% battery drain per night. Is it normal? I set smartassV2 and deadline in nofrills cpu app.
#1296 bshk4126
bshk4126
  • 12 posts
  • LocationGeorgia USA
  • Current Device(s):XT912, XT926
Posted 20 December 2013 - 01:36 AM
Had the same issue before with 3.5 (gapps/browser FC).  i ended up re-downloading and re-installing the rom..  problem fixed. It happened when i decided to "wipe the slate clean" and re-install the ROM (was perfect prior).   Perhaps a bad or corrupted download(?).  Haven't had an issue with 3.7.   Thanks for the Awesome ROM JP!
#1297 bshk4126
bshk4126
  • 12 posts
Posted 20 December 2013 - 02:05 AM
small bug I've encountered.  When i used the timer on the clock app.. and hit home... or back... i get a clock FC.  When i re-open the clock all is working well... and still counting down. No issues... just thought i would share.  Happen to anyone else?
#1298 adamtodd06
adamtodd06
  • 5 posts
Posted 20 December 2013 - 08:17 AM
Try this out.
Yes that is the build.prop tweaks/hack I was refering to. It doesnt work that good and I always have to fiddle with my network settings after reboots. All it would take is for the developer to take a base xt925 rom and apply the same changes to it that he applied to this xt926 ROM. I'd do it myself if I knew how.
#1299 wifimax
wifimax
Posted 20 December 2013 - 09:13 AM
I just loaded 3.7 ROM and love it.   Anyone knows where can I download the 4 buttons softkeys?
#1300 fishstik
fishstik
  • 23 posts
Posted 21 December 2013 - 09:25 AM
Hello good people!!
I've been using this rom for quite some time even though I'm a gsm user on T-mobile. (I've unlocked the gsm capabilities). While I was on T-mobile, before using this phone, I owned a nexus 4, but it never had the battery life I was looking for so I sold it and bought a razr HD. :) Anyways.. to cut to the chase I was missing the raw speed and power of the Nexus 4 so I've disabled logging on my razr to make it go blazing fast :)))))))))))) since the razr was bogged down by having to log and run programs at the same time with just 2 cores. Just add these 3 lines to the end of your build.prop:
#simple speed supertweaks (optional description line)
profiler.force_disable_err_rpt=1
profiler.force_disable_ulog=1
logcat.live=disable
Restart and that's it! in keeping with the traditional theme of Nexusque simplicity. Good day and let me know how it goes! :lol:
I did some more digging and apparently the first two entries don't do anything (
). Disabling logcat is still valid though. I've since added these tweaks and haven't really seen that much of a difference.
