#101
Posted 18 February 2013 - 09:52 AM
#102
Posted 18 February 2013 - 09:58 AM
hmm for some reason i cant put this in stock rom slot i can install most roms in stock slot except this one.
Someone else had this problem, I don't know why that is.
#103
Posted 18 February 2013 - 10:02 AM
I didnt think you could install any roms in stock slot if we could they would all have a lot less lag.
#104 Guest_Megaroad_*
Posted 18 February 2013 - 11:16 AM
I don't get much lag with this, Fuzion, Vitreous, or Inflikted. All of them seem to run smoothly.
- bboyles4 likes this
#105
Posted 18 February 2013 - 11:25 AM
If you want to compare set up your stoc rom in stock slot just like the others. Its not the Devs fault just what safestrap is + Moto juzt screwed up JB.I don't get much lag with this, Fuzion, Vitreous, or Inflikted. All of them seem to run smoothly.
#106
Posted 18 February 2013 - 11:57 AM
I actually still get moments of lag with vit. and fuzion, this is the first rom I've tried that has eliminated all of it, so far anyways. Ill certainly be sticking with this rom until cm/aokp are daily drivers.
#107 Guest_Megaroad_*
Posted 18 February 2013 - 12:26 PM
Every ROM I've run has run more smoothly than the stock Motorola version. I don't think the slot it's in has an impact on speed, it's just a different partition.
#108
Posted 18 February 2013 - 12:40 PM
#109
Posted 18 February 2013 - 12:47 PM
#110
Posted 18 February 2013 - 12:53 PM
Not sure if this will cure anyone's woes, but maybe try clearing cache from system recovery (i.e. not safestrap). I used to do this periodically on my og razr, and it would speed things up.
Yeah I remember that for a fix on the Bionic to somebody else mentioned it here also. I guess you can pickup an app from the store to but much easier to clear it in stock recovery.
#111 Guest_Megaroad_*
Posted 18 February 2013 - 01:29 PM
Widgetsoid toggle widgets have an option to make one of the buttons a "clear cache" toggle. I've been using that. I'm not sure, but I think that one might require you to make Widgetsoid into a system app (which can be done with Titanium Backup).
#112 Guest_Megaroad_*
Posted 18 February 2013 - 01:35 PM
That app looks pretty good, I may have to give it a shot and see if it's better than power toggles. I'm working on getting the install to go more smoothly right now and looking into adding a few more things to make it more like stock android. Let me know if you experience any other weirdness.
The thing I don't like about using Power Toggles or Widgetsoid for pull-down toggles is that they don't stay on top unless you allow them to have a notification icon or at least a blank space in the navbar. Not sure if the Notification Toggles app functions the same way.
#113
Posted 18 February 2013 - 02:13 PM
Im using it and yes they di jocky for position in the pulldown no big deal though
#114
Posted 18 February 2013 - 02:16 PM
You cant get into stockrecovery in with safe instaled can you
#115 Guest_Megaroad_*
Posted 18 February 2013 - 02:28 PM
There might be a Power Toggle to clear cache, because there's one in Widgetsoid, which works similarly.
#116
Posted 18 February 2013 - 02:44 PM
There are a bunch in the store but I dont think there gonna clear the system just each slot but then whats the difference just do each one I dunno
#117
Posted 18 February 2013 - 02:47 PM
You can, just shut down and do the 3 finger salute to reboot into recovery.
#118
Posted 18 February 2013 - 02:51 PM
I tried just gets you into safe we have no stock recovery just safestrap unless you uninztall itYou can, just shut down and do the 3 finger salute to reboot into recovery.
#119 Guest_Megaroad_*
Posted 18 February 2013 - 02:54 PM
The option in Widgetsoid says "clear the cache of all apps." I don't think the cache within other ROM slots would be a an issue for the ROM slot you're currently running.
#120
Posted 18 February 2013 - 02:57 PM
What the heck cant hurt to try.The option in Widgetsoid says "clear the cache of all apps." I don't think the cache within other ROM slots would be a an issue for the ROM slot you're currently running.
