Anybody having trouble with Titanium Root with the new version of the ROM (11/22)? I can't get root access; I've tried uninstalling and re-installing, wiping data, wiping super user and updating binaries, re-flashing ROM, every time Titanium says it couldn't gainroot permissions
#1161
Posted 23 November 2013 - 12:18 PM
#1162
Posted 23 November 2013 - 12:21 PM
Are you using the latest version of Titanium? I am and have no problem gaining root accessAnybody having trouble with Titanium Root with the new version of the ROM (11/22)? I can't get root access; I've tried uninstalling and re-installing, wiping data, wiping super user and updating binaries, re-flashing ROM, every time Titanium says it couldn't gainroot permissions
Sent From My Windows 8.1 Surface Tablet
#1163
Posted 23 November 2013 - 12:31 PM
"30 flash" = dirty flash?
Yes sir, saw that, forgot to fix it.
I use voice recognition all the time and sometimes you just have to sound out what I'm sitting here trying to say. Ha
#1164
Posted 23 November 2013 - 12:40 PM
Yes, made sure that all apps are up to date
#1165
Posted 23 November 2013 - 12:58 PM
30 - dirty close enough. Nice dog my Bud just got one just like it spicy little girl.
#1166
Posted 23 November 2013 - 01:59 PM
Yup they sure can be. This one is ball crazy, that's for sure...
#1167
Posted 23 November 2013 - 03:43 PM
#1168
Posted 24 November 2013 - 06:31 AM
Is it normal to have all these ext4 partitions on the Nexesque? Is it safe to delete?
Without being able to see the entire directory path those look like backups of another rom to me. I could be wrong though.
#1169
Posted 24 November 2013 - 06:44 AM
I hope this doesn't sound like too much of a stupid question...lol Can this be installed with safestrap with locked bootloader??
THANKS!!
#1170
Posted 24 November 2013 - 06:48 AM
THANKS!!
This is what I've been able to find for you Safe Strap users: " I have this ROM running via safe strap right now. Built it out last night.
SS 3.12
My procedure: Erased rom slot 1 completely by doing standard cache wipes and wiping the OS. Then activated a different ROM slot. Then clicked rom slot 1 and deleted it.
Rebuilt rom slot 1 with a 2 gig partition. Did all the standard wipes again before I installed. Mounted system only, unchecked other boxes. Installed ROM. Once this ROM was installed wiped cache and dalvik cache & booted, no issues to report yet"
sent from my xt926 Droid RAZR HD flashed with Nexesque v3.5
#1171
Posted 24 November 2013 - 07:14 AM
adamjmtz, on 22 Nov 2013 - 10:04 PM, said:Rom updated! Unless there are any major issues with the rom, this will be my last build
Have fun everyone!
Have thoroughly enjoyed your roms, you will be missed, Thank You!!
#1172
Posted 24 November 2013 - 07:22 AM
- legend221 likes this
#1173
Posted 24 November 2013 - 08:00 AM
OK GREAT!! THANK YOU!! WILL TRY!!!
#1174
Posted 25 November 2013 - 11:26 AM
#1175
Posted 25 November 2013 - 11:46 AM
adamjmtz, i sent you a message about old keyboard. Could you help me, please?
New usual google keyboard is worse!
#1176
Posted 25 November 2013 - 12:13 PM
try updating superuserIs there a trick to get the xposed framework installed? I click the install update option, wait a bit and it says permission denied
#yoloswagXT926
#1177
Posted 25 November 2013 - 12:54 PM
Download
and . Put them in system/app and set permissions to rwrr. Reboot.
You can delete LatinIMEGoogle.apk (google keyboard) if you don't want it.
#1178
Posted 25 November 2013 - 01:33 PM
For those having issues with losing root and TiBu. The issue is in the latest Superuser (Koush's). The latest 1.0.2.6 version from the Play Store is broken. I'm running 1.0.2.1 Superuser version and it is fine. I believe that is the version packed with this ROM. Do not update Superuser through the Play Store right now.
- viper8u2 likes this
#1179
Posted 25 November 2013 - 02:26 PM
#1180
Posted 26 November 2013 - 12:02 AM
Download
It is doesn't work, I think it needs some libs. When I put it in app folder and set permissions, I still can't choose this keydoard in Settings.
