1460 replies to this topic
#1081 rdhqcpro
rdhqcpro
  • LocationNC
Posted 24 October 2013 - 04:53 PM
Adam,
This rom is the definition of exceptional!  Thank you SO much for the great work you did on this.
Like many others, thanks to only 1 GB of memory and a locked bootloader, I thought I was doomed to another 13 months with a painfully slow phone.  Installed Safestrap and tried several of the most highly recommended roms and found them to be no faster than the stock rom with all the bloatware frozen.  Then I installed Nexesque and found an entirely different experience.  The available free memory with this rom is consistently about 100 MB - 150 MB greater than the stock rom and the other custom roms I tried.  With that extra memory the performance of my phone has been transformed! It is considerably smoother and faster. Then there's the look of this rom...I LOVE it!
Thanks again!
  • adamjmtz, truedis and legend221 like this
#1082 gregpsaros
gregpsaros
  • 10 posts
  • Current Device(s):D4, Rzr Maxx HD
Posted 27 October 2013 - 05:55 AM
Awesome ROM, Thanks
  • truedis likes this
#1083 yukino
yukino
  • 25 posts
  • Current Device(s):Razr HD xt926
Posted 27 October 2013 - 07:10 PM
@adamjmtz, could you please upload to another host, i currently have slow internet as it is and dev-host just doubles the slowness. Sorry for being a pain in the arse. My razr hd xt926 is having problems like freezing up, shutting down, blackscreen and no powering up. I blame myself for these problems as i use my razr 24/7 nonstop and i have not reinstalled your ROM like in forever :) I am sure that a re-installation of your ROM would fix the problems I'm having. My razr eventually comes back to life after a 15 minute kool down. I just love e this phone, it's hard to put it down!!!! I plan on buying another one. Thanks for a great ROM!! If you can't re-upload it somewhere else, I'll just have to wait for it to download from dev-host even if it takes me 2 hours, it's well worth it
#1084 legend221
legend221
  • 70 posts
  • Current Device(s):Motorola RAZR HD
Posted 27 October 2013 - 07:16 PM
Curious, what Rom were you using with those issues?
Sent from my DROID xt926 flashed with NEXESQUE v3.5
#1085 yukino
yukino
  • 25 posts
Posted 27 October 2013 - 07:46 PM
Curious, what Rom were you using with those issues?Sent from my DROID xt926 flashed with NEXESQUE v3.5
v3.1 (4/28/2013) I have not updated since then, I have been having those problems for the last three days. If it is my razr hd burning out, i have no problems purchasing another one, especially the way i use and abuse it. You know what, these problems have been happening since i installed a 32gb SD card... Hmmm, do you think that's what the problems are about?
#1086 legend221
legend221
  • 70 posts
Posted 28 October 2013 - 12:51 PM
Hmm, I'm thinking you should flash the latest release and hope your problems do not come back. If they do return, it sounds more like a hardware issue.
#1087 yukino
yukino
  • 25 posts
Posted 28 October 2013 - 01:59 PM
Actually i downloaded the latest release three times and all of them are corrupt :( so i found out by accident that I made three backups of the ROM when i first installed it using TWRP. Then i wiped everything, installed one of the backups, wiped cache, rebooted and wow!! Everything is back to normal, no freeze ups, no blackscreens, 8 hours strong.
Is there a reason why the latest release is corrupt? I downloaded it at three different WI-FI locations, all ended up being corrupt according to TWRP
Sent from my DROID RAZR HD using Tapatalk 4 Beta
#1088 legend221
legend221
  • 70 posts
Posted 28 October 2013 - 02:36 PM
I'm running the latest release. No issues or hiccups on the downloaded file. Try using your computer for getting the file. Delete the file that's corrupted and try again.
#1089 yukino
yukino
  • 25 posts
Posted 29 October 2013 - 04:09 PM
Downloaded twice on windows 8 desktop, still corrupt, downloaded twice on windows 7,still corrupt.
Sent From My Windows 8.1 Desktop
#1090 yukino
yukino
  • 25 posts
Posted 29 October 2013 - 10:19 PM
Finally worked!!! I was flashing from internal storage when TWRP kept saying FAILED, moved the ROM to external SD and it finally flashed... Yesssss.!
  • legend221 likes this
#1091 mapki
mapki
  • 11 posts
Posted 31 October 2013 - 11:45 PM
Those are mostly 4.2 and 4.3 features that are out of my league to implement on a 4.1 ROM. Mms won't send from the cm10.1 app. I can likely fix the ciphering warning, though.
#yoloswagXT926
Yurok82 from 4pda (
) just released "no ciphering mod" for nexesque. It is flashable zip
#1092 legend221
legend221
  • 70 posts
Posted 01 November 2013 - 06:30 AM
Yurok82 from 4pda (
Thanks for sharing, what does this file change or add onto this Rom?
#1093 legend221
legend221
  • 70 posts
Posted 01 November 2013 - 06:34 AM
I have few propositions how to make this ROM even more great.
1. Update Messaging app from the latest CM10.1 ('mark as read' button added in notification bar) -
2. Add built-in toggles if possible (similar to CM10.1). Messaging app doesn't show buttons (reply, call...) in notification bar when power toggles are activated with highest priority. Also built-in toggles allow to get to setting with long-press.
3. Remove "ciphering" warning on 2G GSM networks -
Found it.
So it adds these 3 things to the Rom?
#1094 lazybox
lazybox
  • 11 posts
Posted 01 November 2013 - 09:12 AM
oh,good work!!!
#1095 runinpoop
runinpoop
  • 9 posts
Posted 02 November 2013 - 08:29 AM
Is flashing gapps necessary with this rom?
#1096 grnsl2
grnsl2
  • 128 posts
Posted 02 November 2013 - 08:42 AM
Nope, comes with all the basics, nice n clean. Download what ever else you need.
#1097 runinpoop
runinpoop
  • 9 posts
Posted 02 November 2013 - 10:59 AM
Are there any flashable softkeys mods that work for this ROM? Preferably one that changes it to 24 dpi
#1098 mapki
mapki
  • 11 posts
Posted 02 November 2013 - 11:04 AM
Found it.
It just removes "no ciphering" warning on 2g gsm networks
#1099 legend221
legend221
  • 70 posts
Posted 02 November 2013 - 03:27 PM
Lucky enough to be on Verizon to not have the message come up on the Rom. Sent from my DROID xt926 flashed with NEXESQUE v3.5
#1100 mapki
mapki
  • 11 posts
Posted 04 November 2013 - 07:14 AM
adanmtz, are you going to add kitkat launcher and apps to nexesque?
