#1061
Posted 18 October 2013 - 03:09 PM
- legend221 likes this
#1062
Posted 18 October 2013 - 05:55 PM
#1063
Posted 19 October 2013 - 02:43 AM
Install "Light Manager" from the market. Best notification light app out there, best thing of all its FREE.
Tried to use this a little bit but seems to have notifications coming up that I can't control. I'll find some random yellow or whatever. Wish there was a way to figure out the trigger short of waiting for a notification and seeing if I can adjust it.
Also looks almost like if it's not in the list it won't change it, let's say off for night time. Still toying around with it.
So as to not to totally hijack this thread, does anyone run any scripts along with this ROM, say crossbreeder or something? I'm not sure I wanna even try.
#1064
Posted 19 October 2013 - 04:47 AM
You can adjust the color and click test a pop up will appear and turn off your screen with the power button.Tried to use this a little bit but seems to have notifications coming up that I can't control. I'll find some random yellow or whatever. Wish there was a way to figure out the trigger short of waiting for a notification and seeing if I can adjust it.
From there you can see what color the HD can actually show on the notification led and save til satisfied.
#1065
Posted 19 October 2013 - 05:20 AM
You can adjust the color and click test a pop up will appear and turn off your screen with the power button. From there you can see what color the HD can actually show on the notification led and save til satisfied. Sent from my DROID RAZR HD using Tapatalk 2
Yep, played around with it quite a bit and really like that dimming feature especially at night however I still get notifications that pop up some random color and I don't know what's triggering it thus my only real issue. Program called light flow is another option and it shows you which items are set to trigger your phone then it shows you what color it set to trigger as well before even going in to make changes.
#1066
Posted 19 October 2013 - 10:17 PM
- adamjmtz and truedis like this
#1067
Posted 20 October 2013 - 06:52 PM
My thanks as well for this, Adam - I was psyched when I logged on and saw the new update. I've probably tried about a dozen roms for this phone and this is, without exaggeration, the only one that has been rock-solid / has working navigation / solid battery life. Cheers!
- adamjmtz and legend221 like this
#1068
Posted 21 October 2013 - 04:05 AM
Does anybody else use the cameras extensively? I've noticed some lag and delay and focus issues between each of them and not really sure exactly why that might be since everything else runs so perfectly.
#1069
Posted 21 October 2013 - 05:47 AM
That was my experience, too, and why I quit using it. Yellow would start flashing for no reason and no notifications.
#1070
Posted 21 October 2013 - 07:20 AM
Moto has never been nooted for good cameras. They just suck. The camera is the camera just because you use a different version doesn't make it any better just a few different options.Been playing around with this ROM now for a few days and over the weekend had an opportunity to use the two cameras that are built in. I believe one is the Moto X camera and the other is stock asop something like that.
#1071
Posted 21 October 2013 - 07:28 AM
Yeah kinda knew that and know there are 3rd party options out there, was just hopin.
#1072
Posted 21 October 2013 - 05:21 PM
I have zero issues using Light Manager. Weird.
Sent from my DROID xt926 flashed with NEXESQUE v3.5
#1073
Posted 21 October 2013 - 05:55 PM
Mine just went to a yellow blink tonight on the way home, nothing in the notification bar at all. I dono really what causes that or if it happens on stock too.
#1074
Posted 21 October 2013 - 10:33 PM
Noticed there is a new update on the Play Store for the app. Might want to try that, restart and hope it disappears.
#1076
Posted 22 October 2013 - 06:39 AM
#1077
Posted 22 October 2013 - 12:21 PM
Thanks for the ROM, I've been enjoying it for a couple of weeks now. I loved how CM10.1 ran but the lower signal in marginal areas (like my commute every day) was too frustrating. It also crashed repeatedly on certain games.
Your cleaned up stock ROM has worked great with no crashes and very good battery life (best 4.1.2 has been for me, 4.1.1 was still better).
#1078
Posted 23 October 2013 - 03:56 PM
#1079
Posted 24 October 2013 - 04:22 AM
#1080
Posted 24 October 2013 - 06:41 AM
Wow... I had not checked this forum because I thought the ROM was pretty much abandoned. I was on the verge of abandoning my phone with all the problems I was having (sluggish in phone, apps, camera, and launcher), but this actually brings me back to being happy with my phone.
First off, this update is a huge improvement so far over the previous version (meaning the one I installed several months ago). The previous version was great at first, but over time it suffered from what appeared to be "bit rot." I'm not sure if this is an Android thing, or what, as I've seen it happen to a lot of my phones. The performance increase is staggering from where I was at before this install.
Next, I got a chance to test the tethering, and wow... I didn't even know the phone was capable of these speeds. Max speedtest to date was 6 down and about 2-4 up. I wire tethered and got 15 down and 15 up today! Wireless tether has always been a miss with this phone, and it still is. I'm not sure if it's my laptop wireless card (highly suspect) or the phone, but the laptop will connect, say it's connected to the internet, then the internet will flake out. Waiting for 10 minutes for a page to load only to have it give the page cannot be displayed message. I think I had a similar event occur several months ago when I tested my X360 with wireless tether.
I didn't even bother with Google calendar... Widgets are ugly, and it still isn't that great of a tool. Moved on to aCalendar+, so I guess it's great that you removed that.
Anyhow, absolutely no complaints here for now. Everything is running smooth as butter!
It almost reminds me of CleanROM from my TF300 days... Best experience ever on Android.
