1460 replies to this topic
#941 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 06 October 2013 - 07:46 AM
When you say kernel do you mean arrrghhh?
#942 woodjc01
woodjc01
  • 38 posts
  • LocationJackson, TN
Posted 06 October 2013 - 07:59 AM
Don't see the download link.
#943 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 06 October 2013 - 08:04 AM
Download in OP at least in full version.
#944 woodjc01
woodjc01
  • 38 posts
Posted 06 October 2013 - 08:18 AM
I'm sorry, but I don't see the link in the first post where it normally is and where it says "download link".  There is no clickable link there and I am on a laptop.  What am I missing?
#945 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 06 October 2013 - 08:28 AM
Your right I swear it was there earlier I saw it this morning when he first posted. Maybe he is doing something.
#946 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 06 October 2013 - 08:33 AM
I'm fixing something... It'll be back soon.
Sent from my DROID RAZR HD using Tapatalk 4
#947 woodjc01
woodjc01
  • 38 posts
Posted 06 October 2013 - 12:27 PM
Rom installed well but am having black screen of death issues on first screen lock.
#948 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 06 October 2013 - 12:35 PM
Did you factory reset before installing? Did you get it back after a reboot?
#949 chdwrk
chdwrk
  • 36 posts
  • Twitter:workca
  • Locationnear Buffalo, NY
  • Current Device(s):Razr, Razr HD
Posted 06 October 2013 - 12:53 PM
No data, multiple apps fc, navigation buttons don't do anything. Two attempts following the instructions with same results. Not a complaint just sharing my results. :-)
#950 woodjc01
woodjc01
  • 38 posts
Posted 06 October 2013 - 12:55 PM
I did factory reset. I wiped and installed the rom again. Setup went well but the phone would not wake up after first time screen off.
#951 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 06 October 2013 - 12:57 PM
Maybe a bad download. I'll download the ROM and do a fresh install to see if it happens to me.
#952 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 06 October 2013 - 01:34 PM
So, I just downloaded and did a fresh install. So far everything is working for me. I'm on TWRP 2.5.
Some things to try:
1. Download from a computer if you're downloading from your phone. I've had problems flashing roms after downloading from unstable connections.
2. Make sure you're following instructions: Factory reset, then mount system, flash rom, wipe cache, reboot.
3. I'll make a download mirror, so you can try that if you like. (It'll be on Dropbox, so maybe the download will be better)
Thanks for reporting back!
#953 chdwrk
chdwrk
  • 36 posts
  • Twitter:workca
Posted 06 October 2013 - 02:01 PM
Some things to try:
Will try again in a bit, I flash everything I can and sometimes things just don't take right. Have fun
#954 sunkim50
sunkim50
  • 58 posts
Posted 06 October 2013 - 02:08 PM
Strange, download this morning and had no issues. Just make sure to mount system and flash 4.1.2 IMG file if coming from a higher version ROM.
#955 sunkim50
sunkim50
  • 58 posts
Posted 06 October 2013 - 02:14 PM
Any way to get aosp browser to have bookmark sync?
#956 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 06 October 2013 - 02:24 PM
Google stock browser for phone and you can get one think its forom 925 but works.
#957 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 06 October 2013 - 02:25 PM
I knew I forgot to do something!
Just push this to system/app and set permissions to r-w-r-r
I'll include it in a later update.
#958 woodjc01
woodjc01
  • 38 posts
Posted 06 October 2013 - 06:32 PM
Some things to try:
I redownloaded the ROM and installed per instructions. I ran fine with no failure to wake from screen lock until I set a pattern lock under security settings. Had to force into recovery, wipe everything, then reinstall...again. Running ROM now with a pin lock set under security settings instead of a pattern and all is well at the moment. I believe it is somehow failing to render the pattern lock page when the physical lock button is pressed and that is causing the black screen of death as it is called.
#959 bdavid
bdavid
Posted 07 October 2013 - 02:56 AM
Yep, installs fine with locked bootloader and safestrap. Thanks.
  • adamjmtz likes this
#960 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 07 October 2013 - 03:32 AM
I'll look at this when I get home from work today.
