For some reason I can't get hotspot to work it just freezes up
Just found this:
I can enable it now, will be testing within the hour to report if it works.
Posted 05 August 2013 - 07:54 PM
Posted 05 August 2013 - 08:58 PM
Posted 06 August 2013 - 08:18 AM
Posted 08 August 2013 - 08:01 AM
hey guys & girls, would like to thank all those involved in bringing this ROM out and sharing!
installed and running great! too awesome! very smooth!
keep up the fantabulous work!
Posted 08 August 2013 - 01:41 PM
The battery life is sick on this ROM. I've been running it for about a week now and was running great. But, i've noticed some significant lag lately. Anyone else?
Posted 09 August 2013 - 06:31 AM
I've noticed the same thing after several days, and can't pinpoint what's causing it. I suspect that it's some remaining Moto software, but that's just a guess. I know it's not the launcher because I use Nova, and I get the lag with either a live wallpaper or a fixed one. Other stock apps I use are messaging and mail. Regardless, it's not a huge deal to reboot my phone once a week for this level of stability, smoothness, lack of bloat, and battery life.
I tried the official CM10.1 nightlys for a few days and am back on Nexesque because I got sick of stupid bugs like randomly losing audio or WiFi, still getting speaker audio when connected via Bluetooth to my truck, as well as MASSIVE lag whenever I dropped it in my vehicle dock (was fine when connected to a normal charger or just to truck's Bluetooth). Really the only features that Nexesque doesn't have from CM10.1 that I really like are the customizeable unlock actions and the settings drop-down.
Posted 09 August 2013 - 06:57 AM
Posted 09 August 2013 - 08:03 AM
I was using the stock launcher. So yeah, that wasn't it. I had been using the rooted stock ROM with odexed apps for months prior to flashing this one. Never had a lag issue. The battery life is not near as good as this ROM but, I am back to tip-top performance (no lagging). I'm starting to think that deodexed apps may be cause for several ROM lag issues. JMHO.
Posted 09 August 2013 - 09:23 AM
Posted 10 August 2013 - 05:30 AM
Posted 12 August 2013 - 03:45 AM
any plans to update to the new OTA?
Posted 12 August 2013 - 03:50 AM
Posted 12 August 2013 - 11:53 AM
I was on Nexesque since the beginning, I switched to CM 10.2 to try out 4.3. Now I want to go back to Nexesque but I cannot get the zip to load using twrp 2.5. Keeps saying Failed. Any ideas or help. Thank you.
Posted 12 August 2013 - 12:27 PM
I suspect that when you flashed CM you also flashed a different kernel. You may have to flash a 4.1 kernel...don't forget to mount system.
Posted 12 August 2013 - 01:09 PM
I have Googled for a kernel with no luck. Do you have any places to look? Thanks again.I suspect that when you flashed CM you also flashed a different kernel. You may have to flash a 4.1 kernel...don't forget to mount system.
Posted 12 August 2013 - 01:18 PM
I think there's a link to one in the rage HD or aviator ROM op'sI have Googled for a kernel with no luck. Do you have any places to look? Thanks again. Sent from my SCH-I605 using Tapatalk 4 Beta
Posted 12 August 2013 - 02:00 PM
Sent from my XT926 using Tapatalk 4
Thank You! That did the trick. :-)
Posted 15 August 2013 - 10:09 AM
On the new governor its running much smoother. I also uninstalled Smart Actions since I don't use it. Read somewhere that the app may cause issues with freezing so I just uninstalled it with Titanium Backup. Rom has the best battery life out of all the ones I have flashed. Many thanks to the dev that put this together. My phone wouldn't be the same without you. Sent from my DROID RAZR HD using Tapatalk 2
Are those governors installed with this ROM or did you have to flash from other source?
Posted 15 August 2013 - 08:45 PM
Posted 16 August 2013 - 05:36 AM
No they are not.
I flashed the kernel from here. Just make sure you get the right one. Wipe cache and dalvik cache before you flash the file.
You are looking for version 0.18 for Jellybean of course.
Thanks, man.
