#861
Posted 20 July 2013 - 07:59 PM
sig made by
Rinkle McBally
#862
Posted 20 July 2013 - 08:17 PM
Sent from my XT926 using Tapatalk HD
#863
Posted 20 July 2013 - 08:18 PM
I had this problem with the installing binary thing on RageHD (and I was coming from stock rooted). I'm not 100% on what the issue was, but the process I went with was: restore rooted stock, mount system, factory reset (not wipe data), wipe system, wipe dalvik, go back to make sure system was still mounted (can't remember if it was or not), then flash ROM.
It seemed to go through fine after that. If not, try the same thing without wiping system. I'm not monkeying with mine again, as it was a PITA with the whole binary error thing.
#864
Posted 20 July 2013 - 08:24 PM
One more thing (actually two):
I watched a youtube video, and it stated that the codec was not available to play it. It was just that one, but it definitely raised an eyebrow, as I've never seen that before on an Android device in the youtube player.
Also, I installed 4 Pics 1 Word (just in case I get REALLY bored) and the overlay was an underlay, meaning after guessing each word, I had to go out of the program and come back in for the overlay to be visible. Something wrong with this app, or something wrong with the O.S.? Not sure yet - I'll have to try it on my daughter's hand-me-down phone (GNexus), but unfortunately, that's a 4.2 phone.
#865
Posted 20 July 2013 - 08:30 PM
Wow i got it. 22 flashes later. I use the nexesque with pie. did the mount system then installed rom. Its working. not sure if its the rom or what.
#866
Posted 21 July 2013 - 05:57 AM
All my flashing was done with Safe Strap back then with 4.1.2. Now im with TWRP comming back from 4.2.2 If you wipe everthing you would think you would get a clean install of you new rom you load. Not true. Iv yet to see a youtube or a wright up on how to mount it was trial and error for me. Key is to go to wipe/then advance and wipe everthing but sdcard. then go to mount/Check the system box. the back page back to install, and then install the rom. Not sure why system is not checked by default. Worked for me.
Hope it helps.
#867
Posted 21 July 2013 - 06:29 AM
#868
Posted 24 July 2013 - 12:41 PM
Thanks.
Doug B.
#869
Posted 24 July 2013 - 01:10 PM
#870
Posted 24 July 2013 - 01:35 PM
Thanks anyway.
Doug B.
#871
Posted 26 July 2013 - 05:46 PM
That works for me. Thanks.There isn't a setting, but you can dirty flash the original to go back to normal.
Guess I'm too much of a spaz for pie controls. But if you ever make a toggle, I'm going back!
This rom is super stable! Thanks again!
Doug B.
#872
Posted 29 July 2013 - 10:26 AM
Absolutely love this ROM, the PIE edition specifically. But is there any way to get rid of the battery percentage in the status bar? I searched this thread and have found a few comments but no real answers.
Edit: Also the messaging app "dark mode" doesn't appear to work for me. Aside from that, the only other issue seems to be the drop-down menus using the PIE controls.
#873
Posted 30 July 2013 - 09:33 PM
#874
Posted 31 July 2013 - 10:15 AM
Just want to check before I screw something up. I'm rooted with a locked bootloader on the 4.1.2 OTA update 9.18.79 (kernel 3.0.31-g101ca72). I can still install and use this ROM with safestrap, correct?
In response to my own question: yes this can be installed on locked but rooted 4.1.2 with the 9.18/20 updates. I just did it with SafeStrap and it works. Loading all my apps on with TiBu now.
- adamjmtz likes this
#875
Posted 31 July 2013 - 11:43 AM
#876
Posted 31 July 2013 - 12:10 PM
I told you that yesterday on another forum lol.
I wasn't sure if my kernel (3.0.31-g101ca72) was any different than the kernel discussed here though (3.0.31-ge491d6d). I wasn't sure if the crap after the dash was important or if just the 3.0.31 was all the mattered.
#877
Posted 02 August 2013 - 10:24 AM
I can't seem to get the old Motcamera.apk to install on this ROM. I've tried several different apk's and methods. Any ideas?
#878
Posted 02 August 2013 - 10:29 AM
it's already in the romI can't seem to get the old Motcamera.apk to install on this ROM. I've tried several different apk's and methods. Any ideas?
#879
Posted 02 August 2013 - 11:04 AM
I erased it on accident but, re-installing that version worked. Thanks.
#880
Posted 02 August 2013 - 08:16 PM
