1460 replies to this topic
#801 Andeh
Andeh
  • 6 posts
  • Current Device(s):Motorola DROID RAZR MAXX HD
Posted 19 June 2013 - 01:29 PM
Weird, that's what I tried before, but this time it worked.  You must be magic.  Thanks.
The reason I asked: I wanted to point out that hyperlinks in received SMS/MMS are especially difficult to see.  They are almost the same blue as the background bubbles.  Can this be changed?
I would also like to know how to change the bubble colors.  Links are very hard to read, and I can't see what the Android smileys are, other than a blotch of green.  My suggestion is to do a similar theme to Hangouts (Talk), where the background is light grey and both text bubbles are white with black text.
Also, does anyone know what .apk(s) I need to restore from the stock deodexed ROM in order to restore the following two features of Motorola's SmartCarDock.apk?  I've got the SmartCarDock working, aside from these two features (which are a huge part of why I like the app).
1)  incoming text message prompt for voice commands to read out loud (text to speech) or dismiss
2)  incoming text message auto-response
  • halfpint likes this
#802 yukino
yukino
  • 25 posts
  • Current Device(s):Razr HD xt926
Posted 22 June 2013 - 05:36 PM
i followed install instructions but when i flash the rom with twrp, it is stuck on flashing file of 1,
  36.88KB   88 downloads is there a way to stop the flashing process? wait for the battery to die? EDIT: i found the solution using the forum search, apparently i did not mount system and i held the three buttons (3 finger salute) to reboot into twrp for 10seconds, mounted system, flashed Rom, success! GREAT ROM! Sent from my PC36100 using Tapatalk 2
#803 koftheworld
koftheworld
  • 111 posts
  • Twitter:koftheworld
Posted 22 June 2013 - 06:04 PM
is there a way to stop the flashing process? wait for the battery to die? Sent from my PC36100 using Tapatalk 2
Hold power and both volume buttons until a reboot
sent from my xt926 RAZR maxx hd
  • yukino likes this
#804 runinpoop
runinpoop
  • 9 posts
Posted 25 June 2013 - 11:19 PM
Hey, I can't group message anymore. How do I fix this?
#805 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 26 June 2013 - 01:13 PM
The messaging he has doesn't group message. Either download handcent , go SMS or Verizon message apps
#806 lolshiftkey
lolshiftkey
Posted 08 July 2013 - 09:20 PM
Can someone explain to me what "mounting the system" actually does? I haven't had to do any mounting with other roms I've flashed till I decided to flash this one.
Thanks in advance.
#807 Guest_BDH_*
Guest_BDH_*
Posted 08 July 2013 - 09:26 PM
Thanks in advance.
It does exactly what it says. It mounts the /system partition of the device which allows for main system components to be overwritten, such as the boot.img (kernel).
  • lolshiftkey likes this
#808 lolshiftkey
lolshiftkey
Posted 08 July 2013 - 09:33 PM
Thanks for the fast response, BDH. One last bonus question.
Why do some roms need system mounted and some don't?
#809 Guest_BDH_*
Guest_BDH_*
Posted 08 July 2013 - 10:06 PM
Because some ROMs contain kernels and some don't :)
It also matters if the developer makes the updater-script correctly. If not, it will not mount the /system partition like it should. If the correct command (which is different for each device) is implemented then the updater-script will mount the /system partition itself and no manual mounting of system is needed :)
#810 lolshiftkey
lolshiftkey
Posted 09 July 2013 - 11:08 AM
Ah, that makes a lot more sense to me. Thanks for all the help, BDH.
Also, this rom is pretty great! I really dig having both the MotoCam and the 4.2 camera.
Keep up the good work, OP!  B)
  • adamjmtz likes this
#811 MajorPay
MajorPay
    Code Monkey
  • 17 posts
  • LocationColorado
  • Current Device(s):XT926
Posted 17 July 2013 - 07:54 AM
I made the jump to this ROM - good work - looks nice... like a stock Nexus, and appears to not run like poo like this phone stock.
One thing missing that would be a nice to have is the extended power settings (reboot, recovery, etc).
Overall though - great work - clean and everything appears to be functional (haven't been able to get tethering working yet, but I'll look into it later).
  • Skynx72 likes this
#812 Cooljoe
Cooljoe
  • 78 posts
  • Current Device(s):RAZR HD Unlocked Bootloader
Posted 17 July 2013 - 02:11 PM
When Are You Going To Update THis Pig To 9.20.1 ?
#813 PUNISHERB273
PUNISHERB273
  • 47 posts
  • Current Device(s):RAZR Maxx HD
Posted 18 July 2013 - 08:15 AM
Anyone know how to get quick office to work without buying the full version? I get a lot of word files on my work email and I can't open them anymore
#814 Skynx72
Skynx72
  • Current Device(s):RAZR MAXX HD
Posted 18 July 2013 - 03:49 PM
I agree that he only addition to this ROM that would make it perfect is he extended power settings.  I'm far from a developer so would anyone be able to make a MOD for this?
#815 Guest_BDH_*
Guest_BDH_*
Posted 18 July 2013 - 04:03 PM
I'll see what I can do for it this weekend. As long as the OP doesn't mind? Make his job a little easier. :)
Sent from my SCH-I545 using Tapatalk 4 Beta
#816 Skynx72
Skynx72
Posted 18 July 2013 - 04:07 PM
That would be awesome!  Thanks!
#817 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 18 July 2013 - 04:15 PM
If you can blacken framework and add a menu soft key. Lastly large Fry's and coke. Super size it please :)
  • heffzilla likes this
#818 Guest_BDH_*
Guest_BDH_*
Posted 18 July 2013 - 04:16 PM
Lol I said I would try to make the power menu, not mod the whole ROM haha.
#819 jpcalhoun
jpcalhoun
  • 178 posts
  • LocationCentral PA
  • Current Device(s):Galaxy S4 Dev Edition
Posted 18 July 2013 - 05:03 PM
Not to be presumptuous, but can you also incorporate the new radios from the most recent update. I understand that has absolutely nothing in common with extended power settings... Just kidding :-)
#820 Guest_BDH_*
Guest_BDH_*
Posted 18 July 2013 - 05:05 PM
This is not my ROM so as I stated, the only thing I will try to do is the power menu. Sorry but I'm not trying to take this ROM over or anything. Hope you guys understand I'm not trying to step on anyone's toes. I only agreed to TRY to do the power menu.
  • Skynx72 and MajorPay like this
