1460 replies to this topic
#761 spartandmd
spartandmd
  • 41 posts
Posted 27 May 2013 - 04:57 PM
Any way to swap back and forth between soft keys and lmt if I'm running nexesque with lmt pie?
#762 MajesticMint
MajesticMint
Posted 27 May 2013 - 07:43 PM
Just wanted to share that I've managed to get a repeatably successful WiFi Tether connection on this ROM using the following:
wifi_tether_v3_3-pre2.apk (
Checked/Changed Settings:
  • Device Profile = Generic ICS/JB (wlan0)
  • Setup Method = Net-Ndc (Master)
  • Send Netd Max Client Cmd = Checked
  • WiFi-Encryption = ON or OFF
  • SSID = Changed From Default
  • Channel (Frequency) = 11 (2462 MHz)
  • WiFi-driver reload (the first one) = Checked
  • MSS clamping = Checked
  • Routing fix = Checked
Also wanted to note that I had uncommon installation issues using 100% proper install methods with TWRP (4 hours of troubleshooting & re-installs across the board)
I tried once with CWR and achieved instant success. I appreciate the combined effort of all the contributors of this ROM, loving it!
  • MasterPrint likes this
#763 jeremym
jeremym
  • 53 posts
  • Google+:linuxfan24@gmail.com
  • LocationDubuque, Iowa
  • Current Device(s):Droid Razr HD MAXX Galaxy Nexus, Xoom LTE
Posted 27 May 2013 - 08:41 PM
Man i wish i knew what i was doing wrong...  I am no longer getting the error above but when I flash this it never boots past the initial motorola boot splash image.  I eventually have to hard reboot it back into CWM and restore back to my old nandroid so i can have a phone.
Steps im doing:
Unlocked boot loader
ClockworkMod
Factory Reset
Format /system
Format /Dalvik
Flash the zip
reboot
#764 MajesticMint
MajesticMint
Posted 27 May 2013 - 11:23 PM
Steps im doing:
ClockworkMod
Factory Reset
Format /system
Format /Dalvik
Flash the zip
reboot
I am by no means a veteran in this field, with that said, here's a guide:
  • Droid Razr HD Utility 1.20 (
  • Use the link above to download. The link will also provide instruction on how to properly run the utility (according to OS)
  • Use the utilities options in this order: 2, 1, 5, 6
  • Download a fresh copy of the ROM from preferred link on original post
  • Download a fresh copy of the boot.img (
  • Transfer the newly downloaded files directly onto the internal SD from your computer
  • Use utility option 4, upon completion it will boot you into recovery
  • Format boot, mount system, format system, mount data, format data, mount cache, format cache
  • Re-mount system, data, and cache
  • Wipe data/factory reset
  • Wipe cache
  • Check to ensure system, data, and cache are still mounted
  • Install zip from SD card
  • First Flash boot.img
  • Then Flash Rom
#765 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 28 May 2013 - 04:19 AM
You can probably just dirty flash the other version of the rom. That will bring them back.
  • spartandmd likes this
#766 curtdragon
curtdragon
  • 120 posts
Posted 29 May 2013 - 07:27 PM
  • Wipe cache
  • Then Flash Rom
Steps im doing:
ClockworkMod
Factory Reset
Format /system
Format /Dalvik
Flash the zip
reboot
Same here, shame you have to do all of that just to get this ROM working
#767 cjlrazr
cjlrazr
  • 14 posts
  • LocationAshburn, Va
  • Current Device(s):Verizon razr HD XT926
Posted 30 May 2013 - 06:30 AM
Really love this rom and getting incredible battery life! I wanted to use trebuchet with it but cant figure out how to get it working? downloaded apk brought up rom mgr, tried everything----- i think?
CJ
#768 iamgodlike87
iamgodlike87
  • 45 posts
Posted 30 May 2013 - 06:59 AM
This is a great rom, I was also unable to get this rom to work through TWRP, i eventually gave up and just ran Safe Strap.
#769 koftheworld
koftheworld
  • 111 posts
  • Twitter:koftheworld
Posted 30 May 2013 - 07:15 AM
CJ
What version did you try the one from cm10 or 10.1?
sent from my xt926 RAZR maxx hd
#770 cjlrazr
cjlrazr
  • 14 posts
Posted 30 May 2013 - 09:12 AM
I think it was the one for 4.2.1
#771 koftheworld
koftheworld
  • 111 posts
Posted 30 May 2013 - 10:09 AM
Try a 4.1.2 version
#772 cjlrazr
cjlrazr
  • 14 posts
Posted 30 May 2013 - 12:54 PM
Try a 4.1.2 version
K, thanks a bunch. works
#773 RoomTenONine
RoomTenONine
  • 78 posts
  • Current Device(s):RAZR HD
Posted 31 May 2013 - 04:43 AM
Loving the latest version.  Had to go to the regular soft key version due the the menu bug with LMT.
This menu overlay issue plagues several apps on the razr phones.  The top notch QuickPic gallery replacement had this issue since ICS, but the dev was able to finally fix it this winter.  He is the only dev that I've seen solve this moto issue with the disappearing menu overlay.  I know it also happens with Vignette and a few others programs.  Might want to reach out to the QuickPic guy to see if he can help with the fix for LMT.  I REALLY want to run the LMT version of this rom.
As usual, great work adamjmtz!
  • adamjmtz likes this
#774 makaighost
makaighost
Posted 31 May 2013 - 08:01 PM
Been running for a while now, my droid has found a home. Thank you!
#775 jeremym
jeremym
  • 53 posts
Posted 01 June 2013 - 10:55 AM
Well ignore my previous post.  I failed to do the one single most important step..."Read".  Had I read what was posted 2343232432 times "mount /system" I would have been using this long ago.
I mounted /system and now it works perfectly so far.
#776 jeremym
jeremym
  • 53 posts
Posted 01 June 2013 - 08:53 PM
Would it be possible to get an unthemed version?  Awesome so far and I am enjoying it :)
  • cjlrazr likes this
#777 cjlrazr
cjlrazr
  • 14 posts
Posted 01 June 2013 - 09:42 PM
Try a 4.1.2 version
#778 cjlrazr
cjlrazr
  • 14 posts
Posted 01 June 2013 - 09:43 PM
Try a 4.1.2 version
How this?
#779 cjlrazr
cjlrazr
  • 14 posts
Posted 02 June 2013 - 04:21 AM
that screen shot is from last night. Nexesque is by far the best but i still cant get trebuchet running on it. oh well
#780 tomv5314
tomv5314
  • 243 posts
  • LocationMass.
  • Current Device(s):One Plus 7Pro 8GB Ram - 256 GB Rom - Pixel 2 XL- 128GB - Nexus 6P- 128GB - LG G3- LG-G2 -Razor Maxx HD unlocked- Bionic- Samsung Galaxy Tab S3--SM-T820
Posted 03 June 2013 - 06:01 PM
I got a used Razor Maxx HD Friday. Rooted and unlocked it. Tried a few different ROM This being one of them. I love this ROM and  I have made this my daily driver and have been running it for 2 days one of which was a ten hour workday which gave me chance to really test it out. I need a ROM with everything working and this seems to be the best. Is this ROM still being supported as I have noticed not much activity for last couple of weeks.  I hope it is. Just wanted to thank you for a smooth stable Rom for my new unlocked toy.  Coming from a Bionic  running SS and flying Jelly
One Plus 7 Pro --  8 GB Ram - 256 GB Rom
