1460 replies to this topic
#741 drebin198
drebin198
  • 12 posts
Posted 20 May 2013 - 07:37 PM
Does it crash when you do anything specifically, or just random crashes?
It just crashes after 1 minute of use. I'm not sure why....
I've deleted cache, renamed the system music.apk and installed fresh from the market. No luck.
Not sure if I need to just delete my SD card music because it can't handle 20GB of music?
Grrr...
#742 anfurnyy
anfurnyy
Posted 21 May 2013 - 07:26 PM
Okay so I'm a twitter fiend and for some reason it won't let me sync my notifications from twitter? Data sync is turned on and everything. Any ideas?
#743 fishstik
fishstik
  • 23 posts
Posted 21 May 2013 - 08:12 PM
Is your Google Music crashing?
I think it's the app's problem. I've never had a problem with Play Music (other than it being a bad music player) before I updated thru Google Play. Give PlayerPro a shot, it's way better.
#744 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 22 May 2013 - 05:16 AM
Actually I noticed a minor update to the music app yesterday which had no description or changelog. It might've been a bug-fix. I'm not sure.
#745 drebin198
drebin198
  • 12 posts
Posted 22 May 2013 - 10:28 AM
Knock on wood, but, that small update made things work for me on my end. Yay!
  • adamjmtz likes this
#746 dru21281
dru21281
  • 103 posts
  • Google+:dru21281
  • LocationNY
  • Current Device(s):Razr HD, Droid X, Razr, HTC Rezound
Posted 22 May 2013 - 10:51 AM
Wrong thread.
#747 afmracer6
afmracer6
  • 58 posts
Posted 23 May 2013 - 01:11 PM
anyone interested in a smaller 36 DPI nav bar for this?
maybe even centered clock ?
I'm about to decomplie and try to make some mods for this and then flash the ROM, if they work then i will post individual mods etc etc
hey franzie3 any luck with these mods?
thanks!
#748 franzie3
franzie3
  • 74 posts
  • Twitter:@MikeFranz3
  • Google+:Michael Franz
  • LocationNY
  • Current Device(s):Samsung GS3, Xoom 4G, Asus Tf300T
Posted 23 May 2013 - 07:43 PM
thanks!
Yea. But its for another ROM. I can do it for this ROM but I will need some files out of the ROM zip. I can't get the centered clock buy the nav bar changes are easy. Right now I rock no nav bar with lmt controls.
If people are still interested I will do it.
#749 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 23 May 2013 - 07:46 PM
i like the last 5 posts :)
  • trikotret and shane1 like this
#750 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 23 May 2013 - 08:12 PM
They where very informative lol I learned a lot ;)
  • zooyork0721 likes this
sig made by
Rinkle McBally
#751 franzie3
franzie3
  • 74 posts
  • LocationNY
Posted 23 May 2013 - 08:29 PM
Wow....no idea what happened....sorry.... I'll delete them later
#752 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 23 May 2013 - 08:37 PM
$#it happens lol
sig made by
Rinkle McBally
#753 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 23 May 2013 - 08:44 PM
All fixed.  :ph34r:
#754 franzie3
franzie3
  • 74 posts
  • LocationNY
Posted 24 May 2013 - 05:11 AM
well now that all that nonsense is fixed (LOL).  If someone wants no nav bar or a smaller nav bar they need to PM me the systemUI.apk and framework-res.apk.
You can either pull them out of the rom zip or using root explorer on your phone copy them off to your SD card.  they are located in \system\app\systemUI.apk and system\framework\framework-res.apk.
You can upload them to dropbox or another file share where i can download them.  Please make sure you are on the most current release of this ROM.
#755 exia989
exia989
  • Current Device(s):Droid RAZR HD
Posted 25 May 2013 - 07:20 PM
ignore this
#756 runinpoop
runinpoop
  • 9 posts
Posted 26 May 2013 - 08:47 PM
Edit: got it....
#757 vctrrl
vctrrl
  • Current Device(s):Motorola RAZR HD (XT925)
Posted 27 May 2013 - 03:46 PM
Any chance to run this on a XT925? I know is not meant to, but...
#758 jeremym
jeremym
  • 53 posts
  • Google+:linuxfan24@gmail.com
  • LocationDubuque, Iowa
  • Current Device(s):Droid Razr HD MAXX Galaxy Nexus, Xoom LTE
Posted 27 May 2013 - 04:04 PM
I just tried to install this using the following:
CWM
factory reset
wipe dalvik cache
install Nexesque .zip file
I get E: Error in /sdcard/Nexesque_RazrHD v3.2.zip
(status 0)
Installation Aborted
#759 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 27 May 2013 - 04:16 PM
CWM
factory reset
wipe dalvik cache
(status 0)
DId you mount system? If so maybe bad download file
#760 jeremym
jeremym
  • 53 posts
Posted 27 May 2013 - 04:24 PM
Yea system is mounted.  I will try the download again.
