1460 replies to this topic
#721 PUNISHERB273
PUNISHERB273
  • 47 posts
  • Current Device(s):RAZR Maxx HD
Posted 19 May 2013 - 03:43 PM
hey i came back to this rom from eclipse hd and eclipse had his own kernel that flashed with the rom. i cant find a stock kernel to flash anyone have it? its just a flashable zip right? im unlocked on twrp 2.5
#722 RoomTenONine
RoomTenONine
  • 78 posts
  • Current Device(s):RAZR HD
Posted 19 May 2013 - 04:15 PM
hey guys,
did i brick?
i backed up my rom in TWRP, wiped wiped wiped, and tried to install the new nexusque. it gave me a failed message so i tried again and it failed again. i figured i'd go back to my saved rom and re-download nexusque but when i tried to restore i got error messages. finally in mounting frustration i accidentally rebooted with no OS loaded and now after powering on i get the "warning unlocked bootloader"  screen and immediately go to black. can't get into twrp. tried the razr hd utility 1.2 but it wont pick up that a device is connected.
am i fubar?
You could rsd back to stock. Or I believe the latest util from matt can fastbboot you back.
#723 spartandmd
spartandmd
  • 41 posts
Posted 19 May 2013 - 04:29 PM
the problem is i can't even seem to get into recovery. has anyone heard of twrp "breaking"? the razr hd utility doesn't seem to even recognize the phone. after i plug it into usb i get a message on the screen that "device was not installed properly". i power on, get the"warning unlocked bootlader" message and then black
#724 dru21281
dru21281
  • 103 posts
  • Google+:dru21281
  • LocationNY
  • Current Device(s):Razr HD, Droid X, Razr, HTC Rezound
Posted 19 May 2013 - 04:33 PM
Here is the stock kernel zip:
#725 RoomTenONine
RoomTenONine
  • 78 posts
Posted 19 May 2013 - 05:02 PM
In fastboot with Matt's util or rsd lite you don't need it.
#726 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 19 May 2013 - 05:10 PM
hey guys,
did i brick?
am i fubar?
So you've tried holding power+vol up+vol down to get into recovery and it didn't work?
#727 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 19 May 2013 - 05:13 PM
Pretty to brick a phone just doing that ai t it
#728 spartandmd
spartandmd
  • 41 posts
Posted 19 May 2013 - 05:26 PM
i've tried the usual stuff... chatting with bladerunner now but nothing seems to help. rsd lite won't recognize the phone as being connected.  tried reinstalling drivers multiple times, different cables, different pc's. motorola mobility driver installation seems to work but pc popup says installation not successful. matt's utility doesn't find the phone either. i think the hangup is for some reason the phone isn't communicating with the pc
#729 Martin028
Martin028
  • 19 posts
  • Current Device(s):xt926
Posted 19 May 2013 - 10:01 PM
Is anyone having a problem with Wifi on the latest version? wifi wont turn on for me. Is it a bad flash? other than that this rom is running great for me.
#730 dvgb131
dvgb131
  • 156 posts
  • Twitter:dvgb173
  • LocationAlbany
Posted 20 May 2013 - 04:36 AM
Did you come from the same rom?
Did you mount system before you flashed?
No-wifi problems seem to come from moving to a rom with a different base/kernel. And this one doesn't have a kernel included. So you have to already be on the same base.
Not sure if you can just flash the right base after the fact and recover wifi.
Someone please correct me if I am wrong.
Doug B.
  • adamjmtz likes this
Doug B.
#731 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 20 May 2013 - 05:40 AM
People have this problem when coming from the 4.1.1 kernel. You need the 4.1.2 kernel.
#732 Martin028
Martin028
  • 19 posts
Posted 20 May 2013 - 06:24 AM
Doug B.
Came from Inflikted, I wiped and wiped some more. I dont know if they use the same base, and I did remember to mount /system. I will try finding the 4.1.2 kernel and give that a shot. I have a backup of my inflikted setup anyway.
I will give this a shot as soon as I locate the kernel. Would it be posted on here or do I have to pull it out of a zip and create my own flashable version?
#733 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 20 May 2013 - 06:48 AM
This is from the RageHD rom post:
  • zooyork0721 likes this
#734 Martin028
Martin028
  • 19 posts
Posted 20 May 2013 - 10:29 AM
Worked beautifully, thanks.
#735 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 20 May 2013 - 12:07 PM
My current setup that I'm pretty happy with!
#736 drebin198
drebin198
  • 12 posts
Posted 20 May 2013 - 12:59 PM
Is your Google Music crashing?
#737 donkey2
donkey2
  • 25 posts
Posted 20 May 2013 - 01:09 PM
This is What I've been doing, and it seems to works. I restore back ups first. I have a 4.1.2 and 4.2.2 back ups.
I just restore to what version ROM I want to install (if not on it already) then flash away. Seems to work so far.
#738 thafngame24
thafngame24
Posted 20 May 2013 - 05:12 PM
In the new Google hangouts app... Can anybody get a video chat to work? I go to start a video chat and the app just closes and takes me right back to the homescreen. Anybody else have this issue?
#739 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 20 May 2013 - 07:07 PM
I haven't tried this yet, but sometimes weird things happen when apps are converted to system apps. I'd recommend deleting the app using root explorer or es file explorer and re downloading it from the market.
#740 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 20 May 2013 - 07:10 PM
Does it crash when you do anything specifically, or just random crashes?
