1460 replies to this topic
#681 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 06 May 2013 - 03:59 AM
So Chrome doesn't sync my bookmarks now. Is that something about this ROM or is it unrelated? I know people were talking about the AOSP browser needing adjustments but I didn't know if that pertained to Chrome as well.
Sorry figured it out. Apparently I did something while on my computer to Chrome. Probably shouldn't be changing stuff while I'm sick!
I'll fix it if and when I do update the rom with anything else. In the meantime, the same AOSP browser bookmark fix might work for chrome too.
#682 rossguy
rossguy
  • 6 posts
Posted 06 May 2013 - 07:32 AM
I am runnign RAZR HD MAXX with unlocked bootloader and twrp. I am running Carbon AOSP ROM. I am trying to get back to stock rooted and then flash Nexesque. I made a stock rooted backup back in the safestrap days. I tried to mount system and restore it via TWRP but i get a black screen after the first unlocked bootloader splash screen.
Am i doing something wrong? I want to get back to a stock base with an AOSP look and this looks AWESOME! If there is an easier way to do this I am open to that as well.
EDIT: Nevermind. Just flashed the boot.img.zip and install Nexesque.
  • adamjmtz likes this
#683 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 06 May 2013 - 09:29 AM
hey adamjmtz can you port over the 4.2.2 message app :)
#684 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 06 May 2013 - 03:19 PM
I really want this too, but I can't get it to work with 4.1.  I've tried multiple times and it always gets force closes.
#685 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 06 May 2013 - 03:20 PM
It only FCS with MMS :(
#686 koftheworld
koftheworld
  • 111 posts
  • Twitter:koftheworld
Posted 06 May 2013 - 04:10 PM
Are you going to be updating this with dh's new base (see Hash's goo account)?
sent from my xt926 RAZR maxx hd
I believe that's the version that this rom is currently running! Check the build number in "about phone" they match.
Ah I thought that was the new mr4 base being discussed on xda sorry. Is your base 9.16.6 or 9.16.9 BTW? Wasn't sure op had been updated.
#687 koftheworld
koftheworld
  • 111 posts
Posted 06 May 2013 - 04:17 PM
#688 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 06 May 2013 - 06:13 PM
Oh, I see there is a new 9.16.9 version out. I'll take a peek at it and see what it brings to the table.
  • zooyork0721 likes this
#689 Chahta
Chahta
  • 81 posts
  • Twitter:toph4er
  • Current Device(s):Droid X
Posted 06 May 2013 - 07:09 PM
I'm on the 9.16.9 DST currently and I know it feels much snappier than 9.16.6 did. Its possible it's placebo, but I'm not so sure, interface lag is almost non existent now while it was a little noticeable before. It could also just be mhous's tweaks
Sent from my unleashed xt926.
#690 DigiDevin
DigiDevin
  • 14 posts
Posted 10 May 2013 - 10:14 PM
So I absolutely love this ROM. I've been running this since it was first released and i can't say thank you enough for the hard work. I've run into an issue where I keep getting insufficient storage error in play store. I've uninstalled apps, cleaned caches, cleaned up both memory cards, but it still seems to happen. I've looked through Google and other forums but can't seem to find an answer... has anybody else dealt with this who may have a solution? Thank you in advance.
#691 PUNISHERB273
PUNISHERB273
  • 47 posts
  • Current Device(s):RAZR Maxx HD
Posted 10 May 2013 - 11:35 PM
I had that problem when I was using safe strap and I think it was because I only used 1 GB on the ROM slot and I really did fill it up. I unlocked boot loader and flashed no issues now
#692 DigiDevin
DigiDevin
  • 14 posts
Posted 11 May 2013 - 03:06 PM
Thank you for the response .I reflashed the Rom after wiping everything twice. Kept some of the user apps I converted to system apps as user apps instead...and so far so good. It seemed like it only happened when updating some apps in the play store but not all of them, it didn't matter if I uninstalled system apps or user apps, it still told me insufficient storage... but we'll see how it goes this time. I was concerned because I reflashed twice clean and it was still happening. Maybe a coincidence or not all data was wiped completely. I know Safestrap could cause this if the partition created was too small but I'm now on TWRP.
#693 dvgb131
dvgb131
  • 156 posts
  • Twitter:dvgb173
  • LocationAlbany
Posted 11 May 2013 - 07:00 PM
Did you delete your old  SS folders?
Doug B.
#694 DigiDevin
DigiDevin
  • 14 posts
Posted 11 May 2013 - 07:34 PM
Yea I deleted all my old recovery folders or moved them to external sd. I think the final reflash I did may have done the trick...knock on wood, but im wondering if it was a titanium backup issue even though I never restore app data, maybe that caused some bogus nonsense I'm not sure. I did read that others were having this problem on multiple different ROMs so I'm not thinking it's ROM related at all. I read the data folder sometimes holds extra garbage in it but I scanned through it and it's all things I use. Maybe TWRP didn't fully wipe or something before but now I'm up and running great. I also add the 4 button nav bar mod for the menu button which has worked flawlessly with this. Never had any issue before so I don't think that was it. I have the mod installed again and the Nexesque is smooth as butta. Thanks for the help guys :-)
#695 fishstik
fishstik
  • 23 posts
Posted 14 May 2013 - 07:21 AM
3.1 is running amazingly! However I just tried setting up Face Unlock and it FCs whenever I try to set it up. Not a big deal, but I thought you'd like to know.
#696 anfurnyy
anfurnyy
Posted 15 May 2013 - 06:55 PM
Man, I'm really interested In this rom but it hangs up and then fails flashing. I'm using TWRP v2.5. Any ideas? Coming from stock 4.1.2 with stock kernel.
Edit: Nevermind. Read earlier in post. Derp.
#697 New Rising
New Rising
  • 62 posts
Posted 15 May 2013 - 07:04 PM
Try downloading the rom and flashing again, that's what I just had to do.
  • anfurnyy likes this
#698 anfurnyy
anfurnyy
Posted 15 May 2013 - 07:47 PM
I just rebooted with the rom successfully installed. Like the previous posts made, just had to manually mount system and boom. So far I love the mms "theme" If you will and by far the best wallpapers of any rom I've ever had. Really liking this.
#699 New Rising
New Rising
  • 62 posts
Posted 15 May 2013 - 09:37 PM
I always find myself coming back to this rom. It's fast, stable, perfectly debloated and gets great battery life. I think it's the best rom for the HD right now.
  • idafan84 and anfurnyy like this
#700 anfurnyy
anfurnyy
Posted 16 May 2013 - 12:55 AM
+1
