Having trouble getting it to flash, not sure if something is wrong with my updater script or anything....standby
#641
Posted 01 May 2013 - 09:57 AM
#642
Posted 01 May 2013 - 10:01 AM
I had to download this ROM 3 times before it flashed correctly.
#643
Posted 01 May 2013 - 10:41 AM
not the ROM, mods im trying to make for it
#644
Posted 01 May 2013 - 05:56 PM
i dirty flashed this rom over dst remix v3 mounted system flashed then wiped dalvic and it run great !
Not reccomended lol but sometime it works lol
Edited by shane1, 01 May 2013 - 06:09 PM.
sig made by
Rinkle McBally
#645
Posted 01 May 2013 - 06:18 PM
Sent from my unleashed xt926.
- shane1 and RoomTenONine like this
#646
Posted 01 May 2013 - 06:35 PM
i did not know that lol but i just read the credit in the op lol
sig made by
Rinkle McBally
#647
Posted 01 May 2013 - 09:50 PM
#648
Posted 02 May 2013 - 05:33 AM
Has anyone flashed this over stock slot? I hate not being on stock
You should only do this if your bootloader is unlocked. if you have not done that i recommend looking into it.
- afmracer6 likes this
#649
Posted 02 May 2013 - 06:27 AM
- jrock likes this
#650
Posted 02 May 2013 - 08:50 AM
Dont take this the wrong way, but why are you asking about flashing to the stock slot. Since the bootloader is now unlocked there is no need to run safestrap anymore.
If you havent flashed anything since unlocking i would recommend booting into recovery, making a backup of your stock set up so you have it. Then flash this.
Make sure your on 4.1.2 and rooted before you do it, but you should be set.
Download the 4.1.2 boot.img so you have it
download rom
boot into recovery
make backup onto SD card (external if available)
mount system
wipe wipe wipe everything (except internal/external SD)
go back and make sure system is mounted
flash 4.1.2 boot.img
check system mount 1 last time
flash rom
reboot...profit
- adamjmtz, afmracer6 and VikingDroid like this
#651
Posted 02 May 2013 - 01:11 PM
I keep safestrap because it is nice being able to switch between roms without having to install/uninstall anything.
Thanks for the steps though, will take them into consideration should I ever rid safestrap.
#652
Posted 02 May 2013 - 01:49 PM
if you want to switch back and forth between roms ,after they are set up make a backup and then when you want to switch you just restore your backups. also roms are no longer going to be made the safestrap way so you may run into issues in the future
sig made by
Rinkle McBally
#653
Posted 02 May 2013 - 01:55 PM
Okay, good to know, I am new to this, I basically only know how to do this with safestrap haha
- shane1 likes this
#654
Posted 02 May 2013 - 01:58 PM
Okay, so I know how to get into recovery, but how do you flash things once in recovery? Can someone explain, or link me please.
#655
Posted 02 May 2013 - 02:03 PM
safestrap was very good and it was necessary then, but it is no longer needed. Please just make sure you read as much as possible before tinkering with your device! Just about any problem you may encounter somebody probably already had it so the answer is out there you just have to find it!
sig made by
Rinkle McBally
#656
Posted 02 May 2013 - 02:34 PM
this should help
sig made by
Rinkle McBally
#657
Posted 03 May 2013 - 02:14 PM
anyone interested in a smaller 36 DPI nav bar for this?
maybe even centered clock ?
I'm about to decomplie and try to make some mods for this and then flash the ROM, if they work then i will post individual mods etc etc
YES! PLEASE!
#658
Posted 03 May 2013 - 02:15 PM
i fooled around with the 4.1.1 method with no luck..
#659
Posted 04 May 2013 - 03:50 AM
Thank you! This ROM is awesome. I installed the Bookmarks fix for the AOSP browser and I can't believe how much faster it is. I was reluctant to even upgrade from 3.0 to 3.1, but I'm glad I did! Smooth as ever!
- adamjmtz likes this
#660
Posted 04 May 2013 - 06:28 AM
Where can one find the Bookmarks fix? I appreciate your help very much!
