thanks for the tip op, luckily even though i didnt temp unroot when i opened up voodoo after update it still let me re-root and all is well. wifi is working now
#581
Posted 21 April 2013 - 04:55 PM
- adamjmtz likes this
#582
Posted 22 April 2013 - 12:52 PM
Same exact issue.
E: Unknown File System: 'datamedia'
Updating partition details...
Installing '/external_SD/Android/Nexesque_RazrHD
Checking for MD5 file...
E:Error executing updater binary in zip '/extern
Error flashing zip 'external_sd/Android/Nexesque
Failed
Fixed by mounting System
Also,
When I try to Advance Wipe and select everything except Micro SDcard, TWRP flashes and reboots, then screen locks (I have to press power to turn it back on). I ran some tests (didn't have a ROM installed anyway.. )
Stand alone wipes from Advanced Menu:
- Dalvik Cache wipes fine
- System wipes fine
- Data wipes fine
- Cache causes to reload
Multiple Wipes from Advanced Menu
- Selecting Sytem and Data together causes reload
- Dalvik and System cause reload
- Dalvik and Data work together
Yeah, I've tried this twice, mounting system before each attempt. Each time, my OS gets wiped and I have to flash backup. Before I get to that point though I have to reboot and get back into recovery because TWRP is freaking out and rebooting. Oh well.........
#583
Posted 22 April 2013 - 02:35 PM
Is there anyway to increase (or change) the size of sent MMS pictures? Mine look grainy as if the quality's reduced.
#584
Posted 22 April 2013 - 03:31 PM
That's just how the stock android app is. I think it might be that way for speed of delivery, but as far as I know it can't be changed.
#585
Posted 22 April 2013 - 07:48 PM
- RoomTenONine likes this
#586
Posted 23 April 2013 - 03:02 AM
Sent from my DROID RAZR MAXX HD
#587
Posted 23 April 2013 - 07:15 AM
Hey guys, quick question. I'm loving this ROM, recently switched to it from Vitreous 1.9.3. The ONLY thing I would really like is the AOSP browser, which JakeDay somehow implemented in Vitreous. I've tried just backing it up in Titanium Backup and restoring the Browser. When I open it the first time, it starts signing me in, and then force closes. I just get FC's when I try to open after that.
Any idea on how to get the AOSP browser back running? I really prefer that to Chrome on my phone, it just seems much more responsive. Thanks!
#588 Guest_Megaroad_*
Posted 23 April 2013 - 07:21 AM
You need to rename BrowserProviderProxy.apk (like to BrowserProviderProxy1.apk). Then you should be able to install and use the Browser.apk without FC's.
- animez likes this
#589
Posted 23 April 2013 - 08:17 AM
Thanks, for the tip, this didn't work though, I get the same thing.
I first uninstalled the browser.apk from /system/app using ES File Explorer. Then I renamed the BrowserProviderProxy.apk. Then I reinstalled the browser from my Titanium Backup of it.
Any other suggestions? Thanks in advance.
#590 Guest_Megaroad_*
Posted 23 April 2013 - 08:48 AM
I think you need to do it by installing the Browser.apk, not a restoring backup. You should be able to use the apk from Vitreous.
ALSO - I forgot to tell you a necessary step after you rename BrowserProviderProxy.apk:
After putting Browser.apk in the system/app folder, set the permissions on Browser.apk to R-W, R, R (Owner = Read/Write, Group = Read, Others = Read). Then reboot and it should be installed and no force closes.
- animez likes this
#591
Posted 23 April 2013 - 09:13 AM
Thanks for all of your help. I got it to go after doing it by pulling the apk out and placing it in /system/app. It didn't install at first, and then I remembered I needed to do a reboot. It's working fine now.
I'd never changed the permissions, currently it has R-W-X, R-W-X, R-W-X. Should this be changed? Thanks again!
#592 Guest_Megaroad_*
Posted 23 April 2013 - 09:15 AM
No problem - if it's working, no need to change anything.
#593
Posted 24 April 2013 - 04:41 AM
I keep having problems with blank white MMS's. This is happening to my friend and I who both have your same build (2.0) and same phone. Solutions?
Not to resurrect an old post, but I've had this issue too on v3 of this ROM. Using the gorgeous stock messaging from this rom causes some MMS picture attachments to not send. You get a blank white image or if you include a text portion just that goes through. In my testing I found that if I took the photo with my phone it will send just fine. If I downloaded an image and shared it through MMS it will fail. It fails across other networks and on Verizon. I installed the moto messaging and it was not an issue at all. The same images that failed on the stock app sent fine with the moto app.
Could we just theme the moto app?
#594
Posted 25 April 2013 - 05:37 PM
Something I've noticed since the very early builds: The icons on the notification bar don't align to the right properly. I usually have 4G turned off and the wi-fi and vibrate icons don't occupy the right-most space. See below:
#595
Posted 25 April 2013 - 05:41 PM
i really like this rom, but the vibration doesnt work when you recieve a text....
#596
Posted 25 April 2013 - 06:03 PM
I haven't tried theming the Motorola messaging, but if it's close enough to the stock app then it shouldn't be too hard (I say this cautiously). The only real reason I use the stock app instead of moto is because I like the emoji option.
I remember the post you quoted and I don't remember if we came to a resolution.
- DonKilluminati likes this
#597
Posted 25 April 2013 - 06:07 PM
I haven't encountered this. I would suggest looking at any apps you have installed that might cause this.
#598
Posted 25 April 2013 - 06:42 PM
I don't think it's an app causing it because these are system notification icons. Just to clarify: If you turn off mobile data, your wi-fi icon and/or vibrate icon shift to the right where the 4G icon used to be?
#599
Posted 25 April 2013 - 07:01 PM
I just confirmed the gap is there when I disable data via power toggles and when I go into settings to disable.
*EDIT* I actually thought this was the Aviator thread as I'm on tapatalk and thread identification is poor. None-the-less, this issue is also present on aviator so I imagine it is not strictly the ROM's fault.
#600
Posted 25 April 2013 - 10:28 PM
My bad: Just booted the stock ROM and that has the same issue. Oh well!
