i have also noticed that both Adamjmtz and and koftheworld both have razrMAXX and i have the white plain razr hd
EDIT: This is terribly frustrating =P
Posted 17 April 2013 - 04:37 PM
Posted 17 April 2013 - 04:54 PM
Posted 17 April 2013 - 04:55 PM
Try this:
Posted 17 April 2013 - 05:05 PM
First I just wanna say great ROM. I have a few questions about how I can make it better lol. I found a zip that makes the navigation buttons look reflected and it worked on the ROM but it took away the 1% battery mod which I love I was wondering how can I get both of these working together. Also I pay for the Verizon hotspot so I was wondering how to get it to work. I pushed the apk to the system but I when I try to connect to it it does nothing. Do I need the stock moto settings? Your help would be greatly appreciated.
system/app/systemUI.apk/res/drawable-xhdpi
system/app/systemUI.apk/res/drawable/stat_sys_battery.xml
I'm not 100% that this will work, so it may require a reflash of the ROM if it doesnt.
In your theme zip (not the nexesque rom zip):
1. go to the first file-path (drawable-xhdpi) and delete all the battery icons
2. go to the second filepath and delete that xml file.
3. Now flash that over the rom, and hopefully the 1% mod will remain.
I posted a link in the changelog for the wireless hotspot hack. (post #2)
Posted 17 April 2013 - 06:43 PM
Posted 17 April 2013 - 06:55 PM
I'm trying to try this but I'm not sure how to actually edit the systemui.apk in the zip it let's me view but I can't edit what should I be using
Upload it somewhere for me... I'll take a look at it.
Posted 17 April 2013 - 07:38 PM
Posted 17 April 2013 - 08:26 PM
Posted 17 April 2013 - 08:43 PM
Here it is. I appreciate you taking your time to help me
Umm, where is it?
Posted 17 April 2013 - 09:44 PM
Wow, that is one heck of a batch script!!!
EDIT: Trying it now.. will let you know how it goes... after all is said and done.
EDIT: WOW UNLOCK BOOTLOADER APK - COOL
I Imagine dan rosenberg must be getting rich... i'll for sure donate
EDIT: This is definately a different TWRP then i was using... COME ON PLEASE WORK!!!!!!
Posted 17 April 2013 - 09:50 PM
Umm, where is it?
Posted 17 April 2013 - 10:12 PM
Posted 17 April 2013 - 10:15 PM
I'm not guaranteeing this will work (I think it will), but here you go!
Posted 17 April 2013 - 10:49 PM
YAY, wifi works on 3.0!!
Would you like a donation Adam, or are there certain people you would reccomend?
Posted 18 April 2013 - 03:47 AM
No donations to me, look at the people that I credit in the OP and you choose who you think is most deserving.
Posted 18 April 2013 - 04:23 AM
Posted 18 April 2013 - 08:26 AM
Gave it try the nav buttons are there but the battery is gone completely unless I charge the phone. Thanks for trying though I guess I can live without it it just looks nice lol
There are different icons, charging and discharging. Plus the XML. From my understanding you need to specify in an XML what you are looking for otherwise it will only look for certain ones. Example 100%, 80% 75%, etc. Some people dont use the charging icons and just base it off a somewhat stock look. The best bet is to make sure that the XML is ok. If you have it in plain text i can look at it.
Posted 18 April 2013 - 08:57 AM
My wifi isn't turning on
Posted 18 April 2013 - 09:53 AM
Search for "baddblood" on this forum. He had the same issue as you and worked through it.
Posted 18 April 2013 - 11:33 AM
