is working in atrix hd ??
#461
Posted 15 April 2013 - 04:30 PM
#462
Posted 15 April 2013 - 05:18 PM
#463
Posted 15 April 2013 - 05:25 PM
#464
Posted 15 April 2013 - 05:44 PM
#465
Posted 15 April 2013 - 05:54 PM
I have been using the wifi tether app from the market, works fine after using the hack and changing the settings in the app.
#466
Posted 15 April 2013 - 06:37 PM
#467
#468
Posted 15 April 2013 - 06:47 PM
Just wiped as you stated, three times for good measure, re-flashed ROM, no dice.. Still no wifi
You didn't flash the 4.1.2 boot.img. That should fix it.
This was the issue, thanks....
#469
Posted 15 April 2013 - 07:28 PM
Is there a way to have a working hotspot on v3.0? Stock vzw isn't present and for some reason tibu won't restore it, and Wi-Fi tether root doesn't work either
I followed this (
) and it worked perfectly for me. Make sure you reboot afterwards, it's critical.#470
Posted 15 April 2013 - 07:37 PM
If you cant get the built in hotspot to work, try wifi tether from the market. there is a picture floating around of the settings you need to change, PM me if you decide to go that route.
#471
Posted 15 April 2013 - 07:48 PM
If I want to have no nav bar and use LMT full-time with this ROM can I use a flashable .zip mod made for a different ROM (Rage1.0)? Or do I have to go in and edit the framework (I think that's what's modified) to make it work for each individual ROM?
#472
Posted 15 April 2013 - 07:51 PM
no that will break the framework of this rom
#473
Posted 15 April 2013 - 07:59 PM
Welp, figured I'd throw caution to the wind, and it's working? Haha. I'm not going to pretend like I know why it is because I used your mod zooyork and I figure you'd know what would work. Am I missing something? How would I know that something was broken?
#474
Posted 15 April 2013 - 08:03 PM
Welp, figured I'd throw caution to the wind, and it's working? Haha. I'm not going to pretend like I know why it is because I used your mod zooyork and I figure you'd know what would work. Am I missing something? How would I know that something was byou can flash onto here
you can use the mod on here but some things will change like some icons and things, someone tried my theme for RageHD and it worked so. just if you run into any problems reflash this rom without wiping
- adamjmtz likes this
#475
Posted 15 April 2013 - 08:06 PM
Okay cool. Thanks for the .zip and I'll see if anything get's wonky. I'm using Tersus for icons so maybe that's why I don't see anything different.
#476
Posted 15 April 2013 - 08:08 PM
To adam:
Is it possible for you to post the 1% battery mod here by itself??
Thanks!!
whomp
#477
Posted 15 April 2013 - 08:37 PM
#478
Posted 16 April 2013 - 12:56 AM
Woo! Great to see a new version up. Just a few questions before I flash. I'm currently on v2.3. Can I just flash this straight from 2.3 or do I have to take any OTA updates beforehand? I just want to make sure the update process goes smoothly.
Wondering about this myself. Since the base went from 4.1.1 to 4.1.2 I assume there could be some issues dirty flashing. I'm too lazy to back up and try it to see what happens though. :
#479
Posted 16 April 2013 - 02:22 AM
#480 Guest_Megaroad_*
Posted 16 April 2013 - 02:54 AM
Cool, 4.1.2 base. I'm going to try it out later.
