For those flashing through TWRP or CWM, are you making sure to mount system before flashing?
#441
Posted 15 April 2013 - 08:52 AM
- triskropf97 likes this
#442
Posted 15 April 2013 - 09:19 AM
OMG! FACEPALM!! i read that a thousand times n forgot! THANK YOU THANK YOU THANK YOU! it installed perfectly and the boot animation is SWEET! its running lik a champ.. i love the google keep addition
#443
Posted 15 April 2013 - 09:29 AM
No problem, glad it worked out for you. I always have to remember it for now until it gets fixed. I was so used to it on my other devices already being mouted and not having to deal with it. Enjoy!!
#444
Posted 15 April 2013 - 10:40 AM
Just unlocked my phone and flashed this ROM after doing a complete wipe. WiFi won't activate though. When I tap it, it just switches back to off instantly.
I tried re flashing the ROM, still same issue.
Any ideas?
Thanks,
B
#446
Posted 15 April 2013 - 10:45 AM
i must be missing something, i'm unlocked using twrp, i did my wipes (coming from v2.3) mounted system flashed and i stuck on the boot animation, let it do that for 10 min, cut the phone off went right back to recovery wiped again mounted system and i'm suck on the boot animation, both times after i flashed it said i wasn't root did it want me to install something i did that the first time and i didn't do it the second time
#447
Posted 15 April 2013 - 11:38 AM
I had the same issue. First, make sure you're coming from the stock kernel and have a backup of your stock-rooted rom. Then go to mount and just check all the boxes. Then go to wipe/advanced wipe and check dalvik, system, data, and cache and then "swipe to wipe"
Then go back to mount and make sure everything is still mounted as before (just in case), and then install the rom.
#448
Posted 15 April 2013 - 11:40 AM
Any ideas?
Thanks,
B
If you're on twrp, do full wipes under "advanced wipe" (dalvik, system, data, cache) before installing the rom.
#449
Posted 15 April 2013 - 11:53 AM
Sorry, mobile hotspot wasn't enabled by default on this rom... here's a link for how to do it.
Thank you very much!!
#450
Posted 15 April 2013 - 01:02 PM
#451
Posted 15 April 2013 - 01:12 PM
To adam:
Is it possible for you to post the 1% battery mod here by itself??
Thanks!!
#452
Posted 15 April 2013 - 01:17 PM
- adamjmtz likes this
#453
Posted 15 April 2013 - 01:24 PM
Thank you Adamjmtz for this ROM, it is so close to perfect.
Anyone willing to make a flashable zip that will return the battery to stock ( no 1% battery mod). It will be much appreciated, thanks.
Rom Toolbox probably can reset this for you. I agree though. Everything else is like nexus, should the battery be the same?
I'd also like to be able to disable the power controls in the pull-down and/or edit them. Derp. I just realized this is customizable with the built-in app. Going to flash this again with v3.
- divadem likes this
#454
Posted 15 April 2013 - 01:35 PM
#455
Posted 15 April 2013 - 01:39 PM
I've noticed that most themes I.e wwidow and bwidow, and a few others work on just about any ROM that is moto/ stock based. Not cm ROMs or themes. Not compatible at all.
#456
Posted 15 April 2013 - 01:56 PM
Just wiped as you stated, three times for good measure, re-flashed ROM, no dice.. Still no wifi
#457
Posted 15 April 2013 - 02:29 PM
You didn't flash the 4.1.2 boot.img. That should fix it.
#458
Posted 15 April 2013 - 02:37 PM
Wifi is not working for me. Everything else seems to be though.
#459
Posted 15 April 2013 - 02:59 PM
#460
Posted 15 April 2013 - 03:28 PM
hi wanted to ask a question is there any way to install this rom on my atrix hd rom I love this and I would like to install it on my atrix hd
THANKS
