Do I need to do anything special coming from CM10 or is it just a straight flash? Thanks.
#421
Posted 15 April 2013 - 03:50 AM
#422
Posted 15 April 2013 - 04:44 AM
Hello first of all thank you for this great rom, love is awesome.I had a question I'm from Spain Verizon the phone with me this rom works perfect, but the Mobile Hotspot and tethering I requested a subscription with Verizon there any way to make it work without thatThank you!
Sorry, mobile hotspot wasn't enabled by default on this rom... here's a link for how to do it.
- power9999 likes this
#423
Posted 15 April 2013 - 04:45 AM
Can you use this on a unlocked droid RAZR HD use safestrap
You can use safestrap or twrp... I briefly tested it on both and it works.
- trey likes this
#424
Posted 15 April 2013 - 04:46 AM
i saw your screenshots that boot up is sick nice adamjmtz !
Thanks! Just some batch editing in photoshop
#425
Posted 15 April 2013 - 04:53 AM
I had a lot of texting issues on the 4.1.2 OTA (not getting new text notifications). Is anyone that has flashed this seeing that issue?
I can't answer this yet, but I'll keep a lookout for the issue.
#426
Posted 15 April 2013 - 04:54 AM
Flash it with full wipes.
#427
Posted 15 April 2013 - 05:02 AM
I'm on cm 10 don't I need to flash the stock kernel first?
#428
Posted 15 April 2013 - 05:10 AM
I think so... I'm still learning twrp, so I'm not completely sure of the exact procedure coming back from cm10.
- triskropf97 likes this
#429
Posted 15 April 2013 - 05:23 AM
Yes you do.
#430
Posted 15 April 2013 - 07:58 AM
Yes you do.
ok so the kernel and nexus fail wen flashed.. as did rage... idk wat im doing wrong..
#431
Posted 15 April 2013 - 08:02 AM
#432
Posted 15 April 2013 - 08:05 AM
#433
#434
Posted 15 April 2013 - 08:08 AM
Yes you do.
Are you flashing the stock kernel through TWRP from a backup? I flashed the boot.img through fastboot after flashing CM10.1 and I flashed v2.5 if this rom with no issues.
There shouldn't be any issues doing it from a backup, just wondering.
#435
Posted 15 April 2013 - 08:10 AM
i tried flashing thru twrp after i wiped cm 10.. idk wat or how to use fastboot..
#436
Posted 15 April 2013 - 08:11 AM
What did you use to flash the stock kernel? A backup if the stock?
Here's how I did it through fast boot;
If you want to try this I can drop the boot.img on Dropbox so you don't have to download the whole stock firmware to get it.
#437
Posted 15 April 2013 - 08:29 AM
Ok thanks.. becuase i am on cm 10 and i was told i need to flash the boot img wen going back to a stock rom. and i want to flash this.. are u saying if i have a stock backup i can restore and then the stock kernel is back?
#438
Posted 15 April 2013 - 08:35 AM
(JB-4.2.1)-%5B01/24:-BETA%5D#entry247990
If you have a stock backup that you backed up the boot partition you can restore it from that backup. On the restore menu have boot selected only. Be sure to wipe boot first. After restoring you should be able to flash the rom.
#439
Posted 15 April 2013 - 08:38 AM
ok i have that but how do i wipe boot?? its not in advanced wipe..
#440
Posted 15 April 2013 - 08:50 AM
Thank you Adamjmtz for this ROM, it is so close to perfect.
Anyone willing to make a flashable zip that will return the battery to stock ( no 1% battery mod). It will be much appreciated, thanks.
