Yeah I want to use it on this Rom but oh well guess being patient will be key.I noticed the same thing. Smart actions itself seems to work, but whatever part of it handles locations seems to be broken.
#361
Posted 22 March 2013 - 02:16 PM
#362
Posted 22 March 2013 - 09:29 PM
Anyone having issues with SmartActions? When I go to select specific location it won't let me add my location. and I turned on my GPS and Wifi and nothing helped. Any ideas? I was trying to use llama but apparently it uses cell towers and I live too close to work and everyone else to make profiles and stuff on it. Thank you.
Because it's a verizon app it might only work with the verizon location agent installed. I'll play around with it and see if I can get it working.
#363
Posted 24 March 2013 - 07:05 AM
Looks like only 2 files Boothtooth.apk and BluetoothLE.apk thru Root Explorer?
Rom 2.5
XT926 HD
Pandora 4.1
Chevy Equinox
#364
Posted 25 March 2013 - 06:40 AM
#365 Guest_Megaroad_*
Posted 25 March 2013 - 06:50 AM
Do I need to flash a gapps package with this? If so, where do I download it?
You don't need a separate gapps packages, it is included with the ROM.
#366
Posted 25 March 2013 - 10:52 AM
I made a flashable zip of the mod that makes the navbar smaller, if anyone wants to try it out. I made it the same height as the status bar for the sake of symmetry. Let me know if it doesn't work, I'm new at this. To go back to the way things were before, reflash the ROM. I believe this only looks good if you're using Nova Launcher or something similar, or else you'll still see a black area where the rest of the bar used to be when you're on your home screen..
Any chance of getting the menu button added to the nav bar (far right) ?
#367 Guest_Megaroad_*
Posted 25 March 2013 - 11:30 AM
I don't know how to add the menu button, but I think some other people here do.
- brndn likes this
#368
Posted 25 March 2013 - 11:50 AM
#369
Posted 25 March 2013 - 12:57 PM
Uh... the calendar app appears to be missing. :\
It's on the market.
#370
Posted 25 March 2013 - 01:14 PM
- Inverted Gmail, same process
#371
Posted 25 March 2013 - 01:41 PM
#372
Posted 25 March 2013 - 05:25 PM
#373
Posted 06 April 2013 - 10:57 AM
#374
Posted 06 April 2013 - 11:15 AM
#375
Posted 06 April 2013 - 12:23 PM
#376
Posted 06 April 2013 - 04:10 PM
#377
Posted 06 April 2013 - 04:18 PM
Recently got 5d12h with ~6h screen on with the MAXX
how do you get this? I'm a very heavy user and get 15 hours in a day. Are you guys running any scripts or apps? Please share. Thank you.I'm a VERY heavy user, but I still average around 30 hours / 5 hours screen on.
#378
Posted 07 April 2013 - 03:19 AM
#379
Posted 07 April 2013 - 06:31 AM
I average around 30-40% at the end of a 16 hour day.
I am also on par for the same percentage as you. Sometimes low to high 50s.
#380
Posted 07 April 2013 - 11:11 AM
No special apps, running 24v, though I honestly don't think that script has had a real impact on battery life
