1460 replies to this topic
#301 r613
r613
  • 11 posts
  • Current Device(s):Motorola Razr Maxx HD XT926
Posted 10 March 2013 - 06:10 PM
Question. I noticed I am not getting status bar notifications for apps I enable such as facebbok and instagram. I reinstalled both apps and made sure notifications were enabled in the app and under app info in the settings icon. But still nothing. Am I missing anything?
#302 idafan84
idafan84
Posted 11 March 2013 - 06:41 AM
You'd have to reinstall the stock app to use group sms
Is that something I can copy from the stock deodexed rom and paste into the system/app folder? ... I'm new to this, I know just enough to be dangerous lol
#303 divadem
divadem
  • 13 posts
Posted 11 March 2013 - 10:46 AM
Is there anyone that can make me a flashable zip with the stock non 1% percent battery? I would greatly appreciate it and would gladly hit the "like" button.
#304 undagullu
undagullu
  • 14 posts
Posted 11 March 2013 - 03:12 PM
I made a flashable zip of the mod that makes the navbar smaller, if anyone wants to try it out. I made it the same height as the status bar for the sake of symmetry. Let me know if it doesn't work, I'm new at this. To go back to the way things were before, reflash the ROM. I believe this only looks good if you're using Nova Launcher or something similar, or else you'll still see a black area where the rest of the bar used to be when you're on your home screen..
I flashed this after i flashed the rom, and the back button is bigger than the others. I tried on apex launcher but nothing changed.how to fix/undo?
#305 pasinato
pasinato
  • 49 posts
  • Twitter:tonypasinato@hotmail.com
Posted 11 March 2013 - 04:42 PM
having issues with wi-fi, will connect, but won't gain internet access on ver 2.5. Anyone else
#306 jasonjw12
jasonjw12
  • 23 posts
  • Twitter:@jasonjw12
  • Google+:jasonjw12
Posted 11 March 2013 - 04:59 PM
I decided to try Fusion Messenger today and, following the instructions, attempted to uninstall Google Voice. In this ROM, however, this appears not to be possible.
Any suggestions?
#307 Guest_Megaroad_*
Guest_Megaroad_*
Posted 11 March 2013 - 06:02 PM
Hmm, I'm not sure why it's leaving the back button big for you, but I just made a version of the mod for 2.5, and it works for me. Here it is:
I just flashed Nexesque 2.5 after wiping cache/dalvik, rebooted, then rebooted again and flashed the new version of the mod, and all my navbar buttons are the same size as each other. It should work for you.
If you just want to go back to 2.4, then you can just reflash the ROM.
#308 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 11 March 2013 - 06:58 PM
Go back to 2.4 and see if you have the same issue. Let me know if you keep experiencing this and I'll check on it when I get back from my trip.
#309 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 11 March 2013 - 06:59 PM
Any suggestions?
I made it a system app, so you need to uninstall it with tibu
#310 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 11 March 2013 - 07:17 PM
Yes, just copy it into system/app and set permissions to rwrr, then reboot. Make sure to either delete or disable notifications for the other app.
#311 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 11 March 2013 - 07:18 PM
Redownload and reflash, see if that solves your issue. Make sure to do full wipes.
#312 pasinato
pasinato
  • 49 posts
Posted 12 March 2013 - 05:42 AM
Must be my wireless router at the house, came into work and no issues.... Thanks for your reply. Enjoy your trip brother.
#313 idafan84
idafan84
Posted 12 March 2013 - 07:02 AM
Thanks for the quick reply. Enjoy the rest of your break.
Cheers!
#314 triskropf97
triskropf97
  • 118 posts
  • Google+:Triskropf@gmail.com
  • LocationNashville, AR
Posted 12 March 2013 - 12:42 PM
Any ideas wats sucking my battery??! A little gaming n some YouTube clips n texting n IM.. Shudnt have went down that fast..
#315 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 12 March 2013 - 06:23 PM
My guess is display.
  • adamjmtz, budlight082684 and Moonrakerone like this
#316 triskropf97
triskropf97
  • 118 posts
Posted 12 March 2013 - 07:25 PM
well I got a day n 5 hours with 5 hours screen time on before this! Not this rom tho.. Something just isn't right..
#317 bostondroid
bostondroid
  • 14 posts
Posted 13 March 2013 - 03:04 AM
Your signal looks low...maybe its been searching for 4G and therefore draining the battery?
#318 richardbibbsr
richardbibbsr
  • 10 posts
  • LocationCasper Wyoming
  • Current Device(s):Motorola Maxx HD
Posted 13 March 2013 - 07:40 AM
Just got the Maxx HD & I'm kinda confused.. Will any RAZR HD ROM work on the max if its 926?
Sent From Dicks Maxx HD
#319 silverstag
silverstag
Posted 13 March 2013 - 07:59 AM
I have a RAZR HD MAXX and this ROM works great!
#320 dru21281
dru21281
  • 103 posts
  • Google+:dru21281
  • LocationNY
  • Current Device(s):Razr HD, Droid X, Razr, HTC Rezound
Posted 13 March 2013 - 08:59 AM
Yes any rom should work once you are rooted and have safestrap installed. All roms will install on rom slots, but only a few are able to install on stock slot like Vitreous 1.9.2 and above. Stock deodex 9.1.39a and Motoblur 9.1.39 will install on stock slot also or any other slots. You have to backup stock slot JB and restore it to the other slots prior to installing the actual roms, just wipe cache/dalvic/data and system after restoring the backup of stock slot JB then install the rom and gapps if necessary. When making a slot make sure your stock slot is active first. You can also create a rom slot and just flash a rom, but im not sure if it works 100% of the time, or after making a rom slot install deodex 9.1.39 on that slot and wipe then install the rom.
I have installed roms on stock slot before, but for some reason they run much slower. And it is a hassle figuring out how to flash/install on stock and still be safe... So I just use rom slot 1 for my daily driver.
  • adamjmtz likes this
