Any way to install that %1 battery mod by itself? Only asking so that I don't have to set things back up again.
Im pretty sure you can flash it dirty
Posted 04 March 2013 - 02:04 PM
Posted 04 March 2013 - 02:13 PM
Posted 04 March 2013 - 02:59 PM
Posted 04 March 2013 - 03:00 PM
Retrieve LiveWallpaper.apk and LiveWallpaperPicker.apk (or something like) and place them into system/app and set permissions to rw-r-rCan anyone post detailed instructions on how to install live wallpaper for this ROM? Thanks!
Posted 04 March 2013 - 04:59 PM
Yes, I appreciate it!Retrieve LiveWallpaper.apk and LiveWallpaperPicker.apk (or something like) and place them into system/app and set permissions to rw-r-r
If you need those apps I can upload for ya.
Posted 04 March 2013 - 05:50 PM
Posted 04 March 2013 - 05:54 PM
Awesome! I installed your ROM the first day I got my RMHD and it's pretty much flawless. Much thanks! One question: Where can I find the digital 4.2 clock widget you had in the previous versions? I Would rather have that than the analog one.
Could I also request a hold volume up to skip track feature? That and the night mode feature from CM10 (lower color temperature) are my most missed features. Thanks again!
Posted 04 March 2013 - 09:17 PM
Posted 04 March 2013 - 09:26 PM
Posted 04 March 2013 - 09:40 PM
Posted 05 March 2013 - 03:56 AM
Posted 05 March 2013 - 09:38 AM
Posted 05 March 2013 - 11:28 AM
Posted 05 March 2013 - 11:31 AM
Posted 05 March 2013 - 11:37 AM
Posted 05 March 2013 - 11:50 AM
Posted 05 March 2013 - 12:01 PM
Posted 05 March 2013 - 12:17 PM
Anybody else's calendar missing?
Posted 05 March 2013 - 12:56 PM
Posted 05 March 2013 - 07:27 PM
So, I can't figure out what I removed that also removed the digital clock widget. You can probably find another one on the play store if you search for "jb clock widget." I use HD Widgets, which has the same clock, but is also re-sizeable and can also change the color. As for your other requests, I really don't know if I'll get to that stuff. I'm constantly adding small things here and there, but I am learning how to do everything as I go along. My focus right now is to get the rom to run as smoothly as possible and to get every drop of battery life. Once I'm happy with that, then I'll [attempt] to add new features!
