Do you think you can print out text messages from android phone? The answer is yes, to print out android phone messages on computer, you need to move them to computer at first, then you can print them out as you like. And we can use iPubsoft Android Manager to move android phone messages to pc easily.
Step 1:Connect Android Phone to PC and start the app on computer, the app could detect your android phone data automatically.
If this is the first time you connect your android phone to computer, you shoule enable the USB debugging. You can follow the guide to open the USB bugging: Enter "Settings" < Click "Applications" < Click "Development" < Check "USB debugging".
Step 2: Preview messages and Start Export
Select and check those text messages you want to print out, then you can open the transferred sms to print them out.
That's all!
