[Theme] Red Baron for Aviator ROM
Red Baron Aviator Theme Red
21 replies to this topic
#1 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 03 February 2013 - 06:05 PM
Red Baron Theme
(Current Theme Version 1.0.7)
Hi all,
Here is a red theme based on the legendary Red Baron.
I am not responsible for anything that may happen to your device (Nothing should happen...)
Custom Boot Animation
What apk's have been themed (some more than others):
  • Framework-res
  • Browser
  • Contacts
  • Camera
  • Email
  • Gmail
  • MMS
  • Phone
  • SystemUI
Differences to stock rom:
  • Custom boot animation.
  • Status Bar icons: Red.
  • Dialer font.
  • Lockscreen Clock Font.
  • Dock and Lockscreen Icons.
  • Default Wallpaper – Can be changed to any wallpaper.
  • MANY different icons.
Installation:
(This is assuming you are already on Aviator ROM:
. If you are, then continue on.)
  • DOWNLOAD:
  • Download and install onto SD Card.
  • Reboot into Recovery Mode SafeStrap (I have only tested using SafeStrap v3.xx, but it should also work with 2.11).
  • If you want to be safe: Wipe Cache, Wipe Dalvik Cache (In “Wipe”).
  • Choose “Install.”
  • Locate “Red Baron” file.
  • Swipe to Confirm Flash.
  • After installation, Reboot, and enjoy!
Remove theme and return to stock Aviator theme:
  • To uninstall the theme, download this file and flash using the above instructions.
Default_wallpaper:
If anyone would like to pull and edit to use things for theming etc, go ahead. If you do post, all I ask is to be added under thanks/credits with a link to the page. You do not need to ask.
  • neckchop, vtwinbmx, SoccerRef12 and 1 other like this
Donate? Click on signature :)
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 03 February 2013 - 06:08 PM
Change Log:
v1.0.2 -
Updated theme to Aviator Blackbird.
Removed Messaging.apk, replaced with Mms.apk (ASOP)
Re-themed Phone, Contacts, SystemUI, Framework-res, and Mms.
v1.0.4 -
Updated to Aviator 3.0.2.
v1.0.5 -
Updated to Aviator Blur 3.0.6
v1.0.7 -
Updated to Aviator Blur 3.0.7
#3 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Reserved
#4 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 04 February 2013 - 02:15 AM
Love it!you should do some old school widget gauges to match the theme bro
#5 gohalos58
gohalos58
  • 16 posts
  • Twitter:@Adamesto
  • LocationCalifornia
Posted 04 February 2013 - 08:41 PM
The boot animation is so awesome! Ha good job man :)
#6 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 07 February 2013 - 09:04 AM
I'm gonna try aviator now just because this theme is sick!
#7 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 07 February 2013 - 11:24 AM
Awesome! Glad you like it! :)
#8 Maxxaholic
Maxxaholic
  • 628 posts
Posted 07 February 2013 - 05:48 PM
Not sure if its theme or rom but play store keeps fccing. Gonna try wiping playstore data first, then cache and dalvik and worst case re flash rom. Ill report back later :)
It's not your theme :)
#9 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 07 February 2013 - 07:21 PM
Were you able to fix the problem? It wont be the theme since I didn't theme the play store. But let me know if you still have the same issue. My next advice would be to delete the ROM slot then create it again and flash :)
#10 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 February 2013 - 02:46 PM
Updated OP for Aviator 1.0.8. Please download again even though it says 1.0.1. (The old file will not work as the setting.apk was changed)
Enjoy :)
#11 Maxxaholic
Maxxaholic
  • 628 posts
Posted 08 February 2013 - 08:57 PM
I had completely wiped cache, dalvik, system, factory reset (in ss 3.11) and re installed (all of this on slot 1) re flashed rom and still had same issue and noticed g mail did the same thing. I'm currently downloading the updated rom. If problem persists ill delete my rom slot 1 and try again :)
#12 Maxxaholic
Maxxaholic
  • 628 posts
Posted 08 February 2013 - 09:34 PM
Deleting the ROM slot and re installing ROM fixed it. I wonder if this was due to me having a cm10 ROM on slot one prior to this ROM. I noticed too that when I would set up ROM it never had me sign into gmail. After deleting ROM slot and re flashing ROM it had me sign into gmail during set up and now everything works :)
#13 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 February 2013 - 04:41 AM
Glad you got it fixed. I don't think it has anything to do with CM10, I've read others having this issue with other ROMs too so I think it's just on of those bugs that pop up from time to time. I did update the ROM OP instructions so now if anyone has the same issues it is addressed :)
#14 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 15 February 2013 - 01:26 PM
Updated OP to v1.0.2!
Changes include updating to Aviator v1.0.9 - Blackbird.
Updated and themed Framework-res, SystemUI, Phone, Contacts, Mms (removed Messaging.apk).
  • yamaha12 likes this
#15 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 22 February 2013 - 05:34 PM
Updated to Aviator 2.0.0! The uninstall theme zip has also been updated :)
#16 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 15 April 2013 - 10:33 AM
Updated the OP for v1.0.4. This is based on Aviator 3.0.2. Enjoy! :)
#17 Einsteindks
Einsteindks
  • 340 posts
Posted 17 April 2013 - 07:30 AM
It's long been my CB handle, and am truly digging this theme!!! Anyway to get the battery percentage and no toggles? I prefer the customization of Power Toggles.
sent via RazrMaxx over Tapatalk, y'all!
#18 SoccerRef12
SoccerRef12
  • 529 posts
  • Twitter:@SoccerRef12
  • LocationLampasas, TX
Posted 17 April 2013 - 09:33 AM
I flashed the Red Baron theme and everything is good except I still have the F22 wallpaper. :-(
Reflash?
"If you truly learned from your mistakes, I would be a genius by now!"
#19 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 17 April 2013 - 11:20 AM
Reflash?
Sometimes the wallpaper doesn't get set automatically. It has something to do with Google remembering your wallpaper. You need to download the wallpaper from the wallpaper link in the OP. :)
#20 SoccerRef12
SoccerRef12
  • 529 posts
Posted 17 April 2013 - 11:41 AM
Link in OP is broke...  :(
Also tagged with one or more of these keywords: Red Baron, Aviator, Theme, Red
