{ROM} Android Aggression Updated {2/26/13} *GSM patch *Stock theme *Fast *king beatz
#121
Posted 10 February 2013 - 08:19 PM
Sent from my sickeningly sweet RAZR MAXX.
#122
Posted 10 February 2013 - 08:21 PM
I'm having an issue in bit after if it's rom related but I keep losing my notification times and ring tones it resets to unknown ring tone at least twice a day. I'm not removing my sd card or anything. It's extremely frustrating
Ya its ROM related and I'm yet to figure out what causes it.
#123
Posted 10 February 2013 - 11:57 PM
I'll probably just move the ones I use into the system folder then and problem solved hopefully.
Aviator did it as well maybe it's a moto jellybean thing
#124
Posted 11 February 2013 - 06:14 AM
Its located in the framework apk under res/drawable-mdpi called background holo dark. You can drag your image into there and flash the apk or send me the image you want and I can make a flashable zip for you
Thank you but how difficult is it to flash the apk? I wouldn't mind learning a new skill!
#125
Posted 11 February 2013 - 07:43 AM
#126
Posted 11 February 2013 - 07:44 AM
Being that the apk that it is I believe you would need to do an adb push or put together a zip.
I explained everything for the flashable zip in his PM
#127
Posted 11 February 2013 - 07:59 AM
#128
Posted 11 February 2013 - 08:09 AM
Maybe I wanna know how to make a flashable zip lol :-P I did learn something today tho root explorer will extract apk files how convenient lol.. Btw its in drawable-nodpi lol took me forever. Anyways I like it the way it is, just bored and have never looked in the framework before. Kinda makes me wanna pull out ps and make an epic weed theme lmao I haven't seen that done yet.
Be my guest haha
#129
Posted 11 February 2013 - 11:41 AM
- prstorero likes this
#130
Posted 11 February 2013 - 06:46 PM
#131
Posted 11 February 2013 - 08:40 PM
- usmcamgrimm likes this
#132
Posted 11 February 2013 - 09:43 PM
170.88KB 66 downloads 140.97KB 64 downloads
At this rate I should get 6+ hours screen on time with over 30 or 40 hours on battery or so.
- vtwinbmx likes this
#133
Posted 12 February 2013 - 03:26 PM
#134
Posted 12 February 2013 - 03:33 PM
Loving the ROM. Extremely clean, fast and smooth. I am still evaluating the battery since I have only been running for a day out so. I would like one request. Is there an APK for the text message application that gives the quick reply option? That is the only texting feature I miss.
I would have it in there but it causes some issues for people with mms. When i get a chance ill make a flashable zip for it for those who want it.
#135
Posted 12 February 2013 - 04:40 PM
SMS popup from the market works perfectly
#136
Posted 12 February 2013 - 05:31 PM
- solo1414 likes this
#137
Posted 12 February 2013 - 07:17 PM
- Built in toggles (extra flash)
- Larger 4.2 keyboard (next build)
- Inverted gapps (next build) (will have a flash available for stock ones)
- Fully stock theme (extra flash)
#138
Posted 12 February 2013 - 08:34 PM
Great work "P"Things that are coming:
#139
Posted 12 February 2013 - 08:53 PM
- ryankliber likes this
#140
Posted 12 February 2013 - 10:13 PM
I use handcent and apparently they pop up won't work anymore...
