Working CM10.1 MMS
215.15KB 45 downloads{ROM} Android Aggression Updated {2/26/13} *GSM patch *Stock theme *Fast *king beatz
#181
Posted 19 February 2013 - 07:42 PM
#182
Posted 19 February 2013 - 08:03 PM
#183
Posted 19 February 2013 - 08:09 PM
I'm using nitros themable mms.apk with quick reply and all that got it from an old jellyhaters . All you gotta do is hit the view button and then back before you send and it always works. Props on getting it working but the themeable one is sooo awesome :-)
This is the themeable one and props goes to lowns for making it work
- ryankliber likes this
#184
Posted 20 February 2013 - 09:17 AM
#185
Posted 20 February 2013 - 11:38 AM
I will post screens its futile to try and explain this is from yesterday 51% after 4 hours......1 hour screen on
What apps do you have installed and what is syncing? We all know the ROM isn't the problem because everyone has had great battery life.
#186
Posted 20 February 2013 - 12:14 PM
#187
Posted 20 February 2013 - 12:16 PM
I like it. Finally a ROM without an annoying built-in pull down toggle so I can use my own. Seems very fluid too. Thanks.
You do realize that the "annoying" toggles that took a while to make for these ROMs was made possible by me, right? Lol
- vtwinbmx likes this
#188
Posted 20 February 2013 - 12:18 PM
#189
#190
Posted 20 February 2013 - 12:19 PM
Yeah I think I might have been instrumental in making them work too.
Haha
#191
Posted 20 February 2013 - 12:22 PM
#192
Posted 20 February 2013 - 12:33 PM
No offense guys. I just like to be able to adjust the toggles to my liking so I use the one by J4velin. I end up having to stack them. That's what's a little annoying.
Use apk tool and remove the toggle line in layout- status bar expanded no more toggles
#193
Posted 21 February 2013 - 05:43 AM
#194
Posted 21 February 2013 - 09:30 AM
- prstorero likes this
#195
Posted 21 February 2013 - 01:22 PM
I have about the same as you with my information but I'm at 3h9m32s on battery with 81% still
#196
Posted 21 February 2013 - 05:16 PM
#197
Posted 21 February 2013 - 05:18 PM
No problem. Glad they worked for youUpdated post 3 with a new smart actions installer. I found out the ones from the base i used won't work when flashed to another ROM for some reason, but from Halo's base they worked. So thanks to him for letting me use his apps
#198
Posted 26 February 2013 - 06:40 AM
#199
Posted 26 February 2013 - 07:04 AM
How do we get the working CM10 mms?
It will be in the build we release today I got the tweaks last night so I need to add them in, flash the build to make sure everything works, then I can upload it
- vtwinbmx, usmcamgrimm and liquidpaper like this
#200
Posted 26 February 2013 - 08:03 AM
