![Posted Image](http://i1265.photobucket.com/albums/jj508/bamafan39/TRITONFORICARUS_zps0fec3684.jpg)
This is only for IcarusHD (remember this rom has OTA updates and depending on the update it could mess this up if you take them) i will try to keep up with the updates. if you find flaws let me know and i will try to fix them as i can
whats themed:
framework
systemui
calculator
contacts
camera
phone
calender widget
latinmeGoogle
google search(or velvet.apk)
circle widget
latinme
setcpu
settings
lock screen
to jp and t3t3 for this awsome rom
jayrod for answering my questions
not sure who did the wallpaper but thanks
i haven't tried it but this should work on spjester's stripped version..if it doesnt let me know and ill make it work
Directions:
if you havent already..install icarus first and set up
put Triton zip on base of sd card and boot into recovery and wipe cache/dalvik
install zip and reboot(on ics it takes a couple of minutes for the top statusbar to show up..you might even turn back light out then on)
Changelog:2/23/13
themed slider switches for settings/quicksettings
themed speaker on/off switch on lockscreen and unlock icon
added T3T3's themed talk.apk
Download:
