no screen bionic
fxz hob safestrap
Best Answer jp1044 , 02 February 2013 - 08:08 PM
The other night my bionic was acting sluggish and i was having an issue with safestrap. I uninstalled safestrap, backed up tibu and went to wipe phone through Hob which i have done many times. This time phone screen goes black after the big M. It boots up but i can't see with the black screen. If i go to recovery screen works fine. I tried to wipe and fxz again with same results . What did I do????
You've tried FXZ'ing through RSD Lite? If not, I would try doing that. Go to the full post
12 replies to this topic
#1 scoutss2
scoutss2
  • Twitter:spalm55
Posted 01 February 2013 - 09:05 PM
#2 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • Google+:jp1044@gmail.com
  • LocationColorado
Posted 02 February 2013 - 08:08 PM   Best Answer
  • shane1 likes this
#3 scoutss2
scoutss2
  • Twitter:spalm55
Posted 03 February 2013 - 06:14 AM
I will give that a try and update. Thanks.
#4 scoutss2
scoutss2
  • Twitter:spalm55
Posted 04 February 2013 - 11:07 AM
That did it thanks!!!
#5 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 04 February 2013 - 01:31 PM
Awesome! Glad you got it working!
-Team LiteSpeed- Sent from my FlyingJelly device
  • shane1 likes this
#6 Kach474
Kach474
  • 28 posts
Posted 29 April 2013 - 10:37 PM
I know this is an old thread but I am having a very similar issue. running JB with safestrap. I did a factory reset but did not uninstall safestrap. After reset I had root but halfway through restoring back ups root went bye bye?? Restored a nandroid backup of stock and would not boot. I now have the same issue, you can hear the boot animation but no screen. I can still boot into another slot with liquid ROM with no issues and still have full root.
I was going to attempt FXZing with RSD lite. My questions are, is there anything I need to make sure I do, and will I loose root?
#7 King Howie
King Howie
    Minister of Jackbooted Thugs
  • 882 posts
  • Current Device(s):Galaxy S4 GPE, Nexus 7 (2013)
Posted 30 April 2013 - 01:36 AM
Yes, you will lose root if you FXZ. You can, however, re-root your phone, but you'll need to use Dans latest exploit for the Bionic. It requires Linux
#8 Kach474
Kach474
  • 28 posts
Posted 30 April 2013 - 02:55 AM
ok. So I tried to FXZ but no luck. It fails at the 5 step in the process.
#9 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 02 May 2013 - 10:55 AM
What error is it?
#10 Kach474
Kach474
  • 28 posts
Posted 03 May 2013 - 02:23 PM
No sure now. It goes to the 4th step and then fails I think it said something about the phone returned FAIL. I would have to run it again. I saw somewhere that there has been issues with JB and Nandroid. If that s the issue If I were to reapply the update manually think that would help? I'm not real concerned about loosing everything I would be cool getting back to stock. Safestrap will let me completely wipe the liquid rom slot and re install the ROM from scratch. Not sure if I can do something similar with the Stock slot.
#11 B.E.McAllister
B.E.McAllister
    Paint by Number Master
  • 355 posts
  • LocationUT, PA
  • Current Device(s):Bionic
Posted 03 May 2013 - 08:41 PM
There are a couple files you have to remove from the fxz for jelly bean, I'll see if I can find a link<br />
#12 ratamacue
ratamacue
  • 24 posts
Posted 06 May 2013 - 06:47 AM
I had the exact same issue. Tons of others have, too. Fortunately there is a very easy fix.
Click here for the rundown:
#13 Kach474
Kach474
  • 28 posts
Posted 08 May 2013 - 10:49 AM
Worked like a charm. Thanks a ton guys
Also tagged with one or more of these keywords: fxz, hob, safestrap
