Phone problems
razr m xt907 droid razr m vzw verizon
Best Answer OldBaldy , 02 April 2016 - 05:17 PM
I charged up my phone because fastboot told me that my battery was low. I charged it for an hour and it still says low battery. I know that after 1 hour it should have somewhat of a charge. Most likely not 100% in an hour but up to maybe 30%. I also have it plugged into my pc and it bootloops between charging and the bl unlock warning. It also won't boot into anything except for fastboot. Even getting into that is a hastle atm. I tried the hw combo to get into recovery(hold vol+ press power and keep holding vol+), but that didn't do anything. How much would it cost to replace the battery(excluding the cost of tools[torx, spudger.])?
Your phone will not charge without a valid system. I doubt your battery is at fault. I would recommend trying a factory fastboot cable that will bypass the battery and power the phone directly. TBH is no longer active, but they are available on eBay. Here's a link for one, there are more so feel free to search.
http://m.ebay.com/it...2752?nav=SEARCH
Sent from my XT1575 using Tapatalk
Go to the full post
1 reply to this topic
#1 Ih8vzw
Ih8vzw
  • Current Device(s):Razr M, s4 mini, one m9
Posted 02 April 2016 - 04:51 PM
#2 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 02 April 2016 - 05:17 PM   Best Answer
  • spainter and Ih8vzw like this
Also tagged with one or more of these keywords: razr m, xt907, droid razr m, vzw, verizon
