[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#161 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 14 February 2012 - 12:38 PM
Have a question about bootstrap. I had installed the extra addition to make it always boot into recovery upon power down then up and since flashing the extreme debloat non-themed --it just boots up normally although it takes a little longer than usual. Should I just flash the jydaddy...zip again or what. Sorry if the names are not exact but I am sure most will know what I mean.
You have to flash that after every install.
#162 mywifecallsmeJA
mywifecallsmeJA
  • 14 posts
  • LocationSomewhere Close
Posted 14 February 2012 - 12:51 PM
Love learning new things!! Thanks man--not a complete noob to flashing but new to MOTO I appreciate your work and your very fast responses.
RELAX...YOU WILL FIGURE IT OUT...EVENTUALLY!!
#163 Guest_24v_*
Guest_24v_*
Posted 14 February 2012 - 12:54 PM
I am running extreme ics theme, and your theme also.
Ok, try this..
-Put on sd-ext
-wipe dalvik/cache
-flash zip
-reboot
Please report back if it fixes the problem.
  • mugsy77 likes this
#164 aktrazer
aktrazer
    SMod/News Team Leader
  • 537 posts
  • LocationGreensboro, NC
  • Current Device(s):Smasung Galaxy Note 2, ASUS TF700T
Posted 14 February 2012 - 01:15 PM
Worked like a charm. DT, you never cease to amaze me! Thanks again for all your work!
#165 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 01:39 PM
Ok, try this..
-Put on sd-ext
-wipe dalvik/cache
-flash zip
-reboot
Rock on man... You just made my Christmas list for not making me dig through XML's. lol
thank you sir.
#166 Guest_24v_*
Guest_24v_*
Posted 14 February 2012 - 01:46 PM
thank you sir.
Glad I could help. If there is anything else, say the word. BTW, that is the framework-res from the ics extreme version.
  • vannope and NickL83 like this
#167 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 01:53 PM
ICS Conversions are in the OP. Show 24v some love for doing my work for me. :)
#168 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 14 February 2012 - 02:28 PM
I flashed the Modded ICS UI Standard Debloat from OP now I am stuck in Bootloop hell. All i did was wipe cache and dalvik.. I wonder if the file got corrupted :(
#169 foxkat
foxkat
  • 201 posts
  • Google+:phil.katulka@gmail.com
  • Current Device(s):Droid MAXX, Acer Iconia Tab 10.1, HTC EVO 3D, Droid 2 Global, OG Droid
Screenshot is not built in. Any 3rd party launcher will give you different app drawers. Blur Launcher is just like that.
ADW EX is excellent.
Got it. I didn't think so but saw the screenshot and thought...well, maybe? As for the launcher, I was using Launcher Pro which also gives vertical scroll in tray, but it gets sticky after a while. I'll try ADW again.
Thx.
#170 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 14 February 2012 - 02:35 PM
.zip worked fine for me. Verify md5
md5 should be: bed3c160ca9995f514f7c35c87b6008b
#171 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 14 February 2012 - 02:44 PM
Too late. Im stuck in bootloop. Cant even go back to stock through fastboot since low battery..sigh
#172 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 02:48 PM
Charge it up..
#173 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 14 February 2012 - 02:56 PM
Charge it up..
yeah thats what im doing. Oh well gotta start from scratch :(
#174 ncwildcat
ncwildcat
  • 109 posts
Posted 14 February 2012 - 03:07 PM
Me too! Bootloop sucks.....Trying to charge this thing up while bootlooping very hard to do...is there a way to charge while in a bootloop??? I can't get this thing to power off...
#175 NickL83
NickL83
  • 37 posts
  • LocationBranford, CT
Posted 14 February 2012 - 03:24 PM
hey guys. Im using Safestrap and Im trying to get my safeside to be stock .173. Im currently using another rom and wanna just go back to stock. I have a backup of my stock nonsafe side .173 but all I get is a blank black screen on boot...Any ideas what be greatly appreciated cause I want to try this out!!! Thanks Guys!!
#176 tankdroid
tankdroid
  • 36 posts
  • Twitter:@Tank_oZ
  • LocationBirmingham, Alabamastan
Posted 14 February 2012 - 03:55 PM
(FROM THE OP) INSTALL INSTRUCTIONS... FLASH USING BOOT STRAP ONLY!! SAFE STRAP DOES NOT WORK WITH INIT.D.
It will not work with safestrap.
UPDATE: Oops, I think you will have to perform a factory reset to get it back to stock. Possibly have to RSD Lite and start from scratch!
#177 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 04:20 PM
Donwload the Stock Rooted 173, Wipe everything and flash it. you will have stovck 173 on the safe side.
  • NickL83 likes this
#178 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 14 February 2012 - 04:34 PM
Hey flash addicts, I am back. Did I miss anything :lol:
#179 mbb350z
mbb350z
Posted 14 February 2012 - 04:52 PM
Noob with a factory cable you can program with no battery. Not sure where to buy one i made one but you have to solder. Let me know if you need more details.
#180 1BadHEMI
1BadHEMI
  • 12 posts
  • LocationPasadena MD
Posted 14 February 2012 - 04:58 PM
Hmmm, I just flashed the Modded ICS Standard Debloat and am also got into a bootloop. MD5 checked out okay.
Th3ory, did you copy the file the 24v posted above into the standard? He said he only modded it for the extreme. Is there a difference in the framework between the 2 versions?
