[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#141 Baloot89
Baloot89
  • 29 posts
Posted 13 February 2012 - 08:56 PM
Help pls....Im a Noob....I just flash this on safe strap......was there a base rom that I needed to flash this prior...if there was I didn't do it.....I rebooted and my screen turn off.....Im unable to turn it back on......Did I totally break it?.....Man just got it too
In OP's post said to not use safe strap your going to have to RSD back Then OTA then reroot and flash using bootstrap
#142 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 13 February 2012 - 09:07 PM
DT, you are the best dealer for this crackflasher!
Sent from my rooted RAZR. If its not rooted, its not right. Droidrzr.com
  • Rouger and dustincook87 like this
#143 nsaechao
nsaechao
  • 48 posts
Posted 13 February 2012 - 09:23 PM
Thank you! mattlgroff help me back to safestrap....don't know about bootstrap but safestrap safe me this time...was in a rush didn't fully read the OP about using Bootstrap only....switching to bootstrap now :)
#144 cdfjr1975
cdfjr1975
  • 78 posts
  • LocationLas Vegas
Posted 13 February 2012 - 10:07 PM
Still have more work to do on it. maybe a Themer will make something. lol.. I hate themimg. :)
Maybe you should put this in the OP and save some time. Seems you make this disclaimer every ROM.
Great work and thanks for hooking the community up with so many options.
#145 Guest_24v_*
Guest_24v_*
Posted 14 February 2012 - 04:14 AM
Dialer, popup, menus, pull down, etc. Little $#!+ here and there... Still have more work to do on it. maybe a Themer will make something. lol.. I hate themimg. :)
I got a little jump on it for you. :D
If you haven't got the menus fixed when I get home from work, I will jump on that. I am just time limited this morning, so I just swapped in a bunch of pngs from my theme for Abysm.
#146 melfunn
melfunn
  • 165 posts
  • LocationNashville, TN
Posted 14 February 2012 - 06:03 AM
Help pls....Im a Noob....I just flash this on safe strap......was there a base rom that I needed to flash this prior...if there was I didn't do it.....I rebooted and my screen turn off.....Im unable to turn it back on......Did I totally break it?.....Man just got it too :(
sht...was in a hurry...so do I have to get a replacement?
Soft reset(vol. down & power for 10 sec.), moto will appear, click menu to get back to safestrap recovery, toggle back to unsafe mode, reboot and UNINSTALL safestrap and install razr bootstrap.
#147 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 14 February 2012 - 08:00 AM
Sweet.. You are now my official Valentine. Lol
#148 foxkat
foxkat
  • 201 posts
  • Google+:phil.katulka@gmail.com
  • Current Device(s):Droid MAXX, Acer Iconia Tab 10.1, HTC EVO 3D, Droid 2 Global, OG Droid
Posted 14 February 2012 - 08:26 AM
Gentle bump... :unsure:
I realize this is simply a MOD of a ROM, not a full ROM, but does this allow screen capture as the images seem to imply, or must you still use a rooted capture such as Screenshot?
Also, is there any way to get vertically scrolling app tray out of this? I hate the horizontal paging.
Just curious??
#149 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 08:29 AM
Gentle bump...
Screenshot is not built in. Any 3rd party launcher will give you different app drawers. Blur Launcher is just like that.
ADW EX is excellent.
#150 Guest_24v_*
Guest_24v_*
Posted 14 February 2012 - 08:40 AM
So, if I want to theme other apps like Settings, blur-res, etyc can I just pull them from a 173 system dump, theme them, and add them into my flashable zip, or will that have an adverse effect being flashed after Clutch?
Sorry if this is a noob question, still learning over here.
#151 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 08:41 AM
Yep. :)
#152 Guest_24v_*
Guest_24v_*
Posted 14 February 2012 - 09:53 AM
Awesome, I really enjoy theming.
#153 Sgerena
Sgerena
  • 95 posts
Posted 14 February 2012 - 11:23 AM
Did we get the blacked out menus fixed? Thanks
#154 Extremedigital
Extremedigital
  • 19 posts
  • LocationAuburn, MI
Posted 14 February 2012 - 11:35 AM
I cant get sqlite editor to work. It just hangs and fc. This is how I installed. I fast booted back to .748 then took ota to .173. rooted, installed safe strap, wiped data, cache, dalvik. rebooted, re rooted, and re installed bootstrap. wiped cache and dalvik and installed extreme debloat with ics theme. rebooted and noticed some bloat still showing up. I then went into settings, privacy, and did a factory reset with format on the internal sd. re rooted again and loving the goodness. (feels squeaky clean also) Sqlite is the only issue i'm having. Just trying to change the entitlement check. The wifi tether app is working fine but for some stupid reason I like using the hot spot.
#155 Guest_24v_*
Guest_24v_*
Posted 14 February 2012 - 11:48 AM
Are they blacked out in all versions, or just extreme? Can someone post a screenshot?
I'm not running this rom as I have not gone to 173 yet. I am waiting for the deo rom, but I will be more than happy to help if someone can show me.
#156 mywifecallsmeJA
mywifecallsmeJA
  • 14 posts
  • LocationSomewhere Close
Posted 14 February 2012 - 11:52 AM
Me too!! Gotta have my drop down toggles!! haha
RELAX...YOU WILL FIGURE IT OUT...EVENTUALLY!!
#157 Sgerena
Sgerena
  • 95 posts
Posted 14 February 2012 - 12:04 PM
I am running extreme ics theme, and your theme also.
#158 mywifecallsmeJA
mywifecallsmeJA
  • 14 posts
Posted 14 February 2012 - 12:22 PM
Have a question about bootstrap. I had installed the extra addition to make it always boot into recovery upon power down then up and since flashing the extreme debloat non-themed --it just boots up normally although it takes a little longer than usual. Should I just flash the jydaddy...zip again or what. Sorry if the names are not exact but I am sure most will know what I mean.
#159 greek6486
greek6486
  • 209 posts
  • Twitter:@greek6486
  • LocationMaryland
  • Current Device(s):Razr Maxx
Posted 14 February 2012 - 12:28 PM
Has anyone tried applying this to eclipse 1.0 yet? Would be an interesting outcome!
#160 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 12:37 PM
I'm sure eclipse is debloated. I'm sure you would have a VERY bad outcome.
