[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#81 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 13 February 2012 - 02:45 PM
CDMA_N_04.06.00R LTEDC_U_07.1F.00
Perfect! Just confirmed I AM on 173 base! Thanks!
#82 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 13 February 2012 - 02:46 PM
Quick question - Infex and Abysm both said they would "sip" battery, yet I'm getting FAR better battery life with stock than I was with either of them (even before I updated to the 6.12.173) - so does this "Go Faster" script actually improve battery life, or is that more rhetoric?
Rhetoric? LOL... You know ANY reason I would have to persuade or talk you into running or using anything I make? Do I get money for the more users that flash my stuff so I need to CON people into using them? You see a donation link anywhere?
I had excellent battery life and so did MANY others, Your battery issues, frankly are not my problem. And if you think I will even entertain you to help with what may be causing you a battery issue (Other Than the fact that you probally made that observation a day after you flashed it) after comment that implies I falsified info for my domination of the ROM market... You are sorely mistaken.
  • frankyvee, psyjohn, JBeXX and 3 others like this
#83 guybrush
guybrush
thanks from guy on day 2 of razr (maxx) .. what a giant leap from the incredible (i will always rememberrr you, dinc!)
#84 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 02:47 PM
I'm on the ics theme and all the menus are blacked out and I can't read what they say. How to fix this? Extreme ics themed
LOL... I see that now.. Must have missed a XML Edit. :) I will fix it. Plus I will put a stock revert in the OP.
  • mugsy77 likes this
#85 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 02:49 PM
Call me stupid if I missed it, but what are the differences between normal and extreme? Also, do smart actions work with these?
Everything works and the differences are in the OP.
#86 Rouger
Rouger
  • 55 posts
  • LocationLongmont, CO
Make sure you flashed the right one. :) It has ICS in the name. Not really possible since the modded apks will be forced in.
Flashed the ones I downloaded with ICS in the name, both the standard and extrem. While they do seem to load, I do not see any difference. Even when I pull up Phone info it says Clutch v1.0 and Clutch Extrem v1.0. I'm going to try redownloading and see if that helps.
I am coming from the Clutch Conversion Extrm which was running great.
Is anyone else having these issues or am I the only one and thus doing it wrong?
#87 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 02:50 PM
You don't have the ICS icons in your Status bar?
#88 JBeXX
JBeXX
  • 87 posts
  • LocationColorado
Posted 13 February 2012 - 02:52 PM
No issues here. Did the same and ICS UI is all nice and ice creamy on extreme.
#89 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 13 February 2012 - 02:53 PM
Thanks for the replies. Did a factory reset after it all, and it came back ok.
Anybody having issues with MyBackup Pro from working? Loads up but hangs on black screen. Tried reinstalling as well but no go...
  • dustincook87 likes this
#90 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 13 February 2012 - 02:54 PM
What's the preferred mething if running Abysm over 173 base with BS?
#91 JBeXX
JBeXX
  • 87 posts
  • LocationColorado
LOL. Hey Rouger, I am on desktop version of razr.com for the first time and just noticed you are not only a fellow CO resident but a fellow Longmont resident!! Small android world we flash in.
#92 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Backup pro works fine on my phone
#93 ncwildcat
ncwildcat
  • 109 posts
Posted 13 February 2012 - 02:55 PM
Thanks...missed it. You da man!!
#94 Rouger
Rouger
  • 55 posts
Posted 13 February 2012 - 02:59 PM
Yes sir, they are. Guess I was thinking I was missing things.
What other items are changed so I can look into them and see how they look?
Sorry, was my bad...
#95 Rouger
Rouger
  • 55 posts
Posted 13 February 2012 - 03:00 PM
Yes it is a small Android world. I'm off Hwy 66 near Lyons...
#96 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 13 February 2012 - 03:04 PM
Dialer, popup, menus, pull down, etc. Little $#!+ here and there... Still have more work to do on it. maybe a Themer will make something. lol.. I hate themimg. :)
#97 JBeXX
JBeXX
  • 87 posts
  • LocationColorado
Posted 13 February 2012 - 03:06 PM
Yes it is a small Android world. I'm off Hay 66 near Lyons...
Nice, wife and I just bought a house in old town west side by sunset golf course. Now if only I played golf and not hockey ;). We own the Longmont based business, Where's My Leash? In-Home Pet Sitting.
Good stuff. But I'll stop yapping to you via forum now ...lol
#98 mywifecallsmeJA
mywifecallsmeJA
  • 14 posts
  • LocationSomewhere Close
Posted 13 February 2012 - 03:09 PM
DT, I hate to even ask this but does the ICS version have any toggles in the pull down and if it does not how difficult would it be to add them?? I would also like to say that I truly appreciate what you do and glad you don't let the haters get you down. SO... THANK YOU!!
RELAX...YOU WILL FIGURE IT OUT...EVENTUALLY!!
#99 Rouger
Rouger
  • 55 posts
Posted 13 February 2012 - 03:10 PM
Cool, yea I can understand the added work for that, tried it once on my OG Droid back a year or so ago. Takes a lot of patience...
#100 Sgerena
Sgerena
  • 95 posts
Posted 13 February 2012 - 03:13 PM
Ok thanks
