I've used this tool a few times and it works great.
I just used it to. Worked like a charm. Took straight to .748
Posted 13 February 2012 - 12:14 PM
Posted 13 February 2012 - 12:17 PM
Posted 13 February 2012 - 12:26 PM
173 is for cdma. This won't work with GSM RAZR that you have.Hi.Im running Android 2.3.6. ,version 651.167.19 . retain.en.eu - If i want to put this ROM , I should put 6.12.173 first and then the ROM or ? And what doest "Wipe Dalvik" means?
Thanks.
Posted 13 February 2012 - 12:28 PM
Thanks.
Posted 13 February 2012 - 12:33 PM
Posted 13 February 2012 - 12:36 PM
Oopsy, my bad. I didn't think they played nice together. I need to leave it to the Mr Miyagi's of the RAZR before I replyActually ... Since it is a BLUR system and "MOST" of the files would be named the same, it should work. Any files not in the system will be skipped over by the script, plus the MODs are made for system.
They only thing that would have yo be removed is the build.prop. If you want to drop me the prop from the EU I can mod it and make a package for it.
Posted 13 February 2012 - 02:03 PM
Posted 13 February 2012 - 02:27 PM
Posted 13 February 2012 - 02:30 PM
So I was coming from the Clutch Conversion Extrem to the Clutch Conversion ICS and it seems that nothig changed?ICS UI Versions are in the OP... I plan on more in the UI but it looks sweet.
Posted 13 February 2012 - 02:31 PM
Before you ask, yes I wiped Cache and Dalvik cache.
Is there something I missed?
Posted 13 February 2012 - 02:32 PM
I don't think so, but I could be wrong. .748 and .173 are two different things. .173 Roms will not work if you are on .748. Since you are on Abysum, you installed a custom recovery, either bootstrap or safestrap, which put you off the upgrade path to .173. In order for you to get the new update you will need to use the razr utility tool to reflash stock .748 system. Anyone feel free to correct me if I said anything incorrectNot sure where in my upgrade path from Abysm 1.1 to .748 to .173, but if I have a corrupt Google Calendar, is there a way to grab/fix this without data reset?
Posted 13 February 2012 - 02:33 PM
Posted 13 February 2012 - 02:34 PM
Posted 13 February 2012 - 02:35 PM
safestrap or bootstap, makes no difference for install, yes? Just wipe cache and Dalvik for both, yes?
Posted 13 February 2012 - 02:36 PM
Posted 13 February 2012 - 02:38 PM
What is the 173 Radio version?
Posted 13 February 2012 - 02:39 PM
Posted 13 February 2012 - 02:41 PM
