[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#341 JoJoLanny
JoJoLanny
  • 190 posts
  • LocationTennessee
Posted 16 March 2012 - 09:51 AM
Ok.... 3 questions....
1. Can we get BUA "Contacts" working?
2. How come my dialer isn't black?
3. Where can I get that sweet rear end wallpaper? :-)
I have a fever..... and the only cure..... is more cowbell!!!!
#342 bryannh
bryannh
  • 19 posts
Posted 19 March 2012 - 09:56 PM
any reason why the modded ICS versions arent available in the OP?
#343 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 20 March 2012 - 03:55 AM
If i remember correctly, there were way too many people having issues with them so DT pulled the files for phone safety reasons.
Sent from my DROID RAZR using Xparent Red Tapatalk
#344 cncrrddn
cncrrddn
  • 12 posts
Posted 26 March 2012 - 12:52 AM
Your instructions leave much to be desired for this neophyte...
Put on SD Card
ONLY
Wipe Cache
Wipe Dalvik
Flash It
Reboot
(BTW how do you wipe Dalvik? The internet does not know and neither do I.)
My results (from recovery menu):
qe 1/1
-- Install /sdcard/rom ...
Finding update package...
Opening update package...
Verifying update package...
E:signature verification failed
Installation aborted.
.....okay I was able to do it with the CWM (clockwork mod)...........still don't know how to Dalvik tho.
#345 jmp485
jmp485
  • 94 posts
  • Twitter:jmp485
Posted 26 March 2012 - 01:31 AM
Anyone have a good d/l link for the standard clutch ROM?
#346 milkshed27
milkshed27
  • 195 posts
  • LocationFlorida
Posted 26 March 2012 - 09:04 AM
Put on SD Card
ONLY
Wipe Cache
Wipe Dalvik
Flash It
Reboot
qe 1/1
Place the file on your external SD Card.
Using Razr Bootstrap reboot into Clockworkmod.
Scroll to Wipe Cache.
Scroll to advanced, wipe Dalvik Cache.
Go back and install zip from SD Card then reboot.
If we question our own actions, our thought process, make a conscious decision to what we feel is right every single day, that's what I believe to be Divinity. That's true Shamanism.
#347 cncrrddn
cncrrddn
  • 12 posts
Posted 26 March 2012 - 09:20 PM
Cool.
I did manage to fumble through it on my own.....everything is so disconnected....
I did a wipe cache partition and wipe data/factory reset with the stock recovery then did the update..........should be fine...it seems fine anyway.
Actually antutu benched at 15% above stock stock rom (unrooted etc) at the default clock speeds et al.
#348 milkshed27
milkshed27
  • 195 posts
  • LocationFlorida
Posted 27 March 2012 - 07:51 AM
Cool.
Yes that works fine, however a full wipe data/factory reset was not necessary to install this since it's not a ROM, but it is good practice because flashing a full ROM will require a full wipe.
#349 danieltedwards
danieltedwards
  • 19 posts
Posted 28 March 2012 - 04:52 AM
Hey DT. Great job on this ROM. I like the stock look for some reason but I'm glad you put this together for all the debloat and speed mods. However, I was wondering if it is possible to put the power control in the status bar, like on many of the custom ROM's out there. Not even sure if this is possible but I figured I would ask. Thanks a lot.
#350 jmp485
jmp485
  • 94 posts
  • Twitter:jmp485
Posted 28 March 2012 - 09:42 AM
I may be wrong but I think you need to be deodexed for that mod to work 100%
The ones you get using an apk all have serious shortcomings
#351 danieltedwards
danieltedwards
  • 19 posts
Posted 29 March 2012 - 03:11 AM
Not sure if DT is still checking this thread. But i ran into a problem with the ROM. When trying to use SQLite Editor the app would freeze up and upon touching the screen bring up the force close/wait option. Also when trying to use My Backup Root app It would bring up the app but stay at a black screen. I flashed Eclipse and back to stock rooted and both apps work fine. I'm not sure what is causing this problem but hopefully it can be fixed. I like having Clutch for the debloat and GoFast script. Hope you can help. Thanks.
#352 onemotodroid
onemotodroid
  • 51 posts
  • Twitter:onemotodroid
Posted 29 March 2012 - 07:00 AM
Your busybox version should be roll back. I use v1.17.1 with this rom
#353 danieltedwards
danieltedwards
  • 19 posts
Posted 30 March 2012 - 04:37 AM
Thanks onemotodroid. I got the same response in another thread. I'll have to switch back over to Clutch and give it a try.
#354 jmp485
jmp485
  • 94 posts
  • Twitter:jmp485
Posted 30 March 2012 - 07:38 AM
thanks. worked like a charm
#355 onemotodroid
onemotodroid
  • 51 posts
Posted 30 March 2012 - 11:35 AM
This rom is so solid and runs GREAT. The thing I like about it is that it still keeps the Moto Razr feel.
I have tried most of the others but this is the rom i keep coming back to.
Everything work!
When I have time i will be working on adding new features that I would like to add but, this is a great base.
#356 claps1775
claps1775
  • 596 posts
Posted 01 April 2012 - 07:37 AM
One question Mr. Theory. Can I install just extreme or do I need to install the stock clutch then extreme? I been running Razrx v1.2 and it is. Nice smooth rom. Now I would like to see what this rom is like.
Claps1775
#357 claps1775
claps1775
  • 596 posts
Posted 01 April 2012 - 10:05 AM
Not able to download the extreme or stick clutch. Says file is not available. And one have have a link that does or can email it to me?
Claps1775
#358 jmp485
jmp485
  • 94 posts
  • Twitter:jmp485
Posted 01 April 2012 - 05:15 PM
Claps1775
try downloading it using a pc instead of your phone I kept having trouble when I tried to get the file with my phone but no issues when I use my home pc
#359 claps1775
claps1775
  • 596 posts
Posted 01 April 2012 - 05:36 PM
Ahh thanks. It did work just fine. Thank you.
Claps1775
#360 claps1775
claps1775
  • 596 posts
Posted 02 April 2012 - 03:43 PM
I did what you said to do. On SD card. Used matts 1 wipe to rule them all then flashed with boot straps as always ans rebooted. I soft bricked and would.not get past the M duel core. I had rouse rsd lite to get back to stock root and flash my back up. What happened or does 1 whipe to rule them all does not work for this mod? Yes, I was on stock rooted.173
Claps1775
