Ok the OTHER busybox installer worked. After installing it, My BackupPro will open. Also Quadrant score was 2200 before and after installing bb it was 2500+. So what is happening to busybox, or is the 2.3.6 motofail root not installing it?Don't see any such post. Installing that app - it does not run for me... just spins
[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
#301
Posted 17 February 2012 - 07:13 PM
#302
Posted 17 February 2012 - 09:59 PM
#303
Posted 18 February 2012 - 03:37 AM
DT - I appreciate your hard work, but can you please remove the download or stipulate in the OP that the ICS builds will cause bootloop? I know it's my responsibility to read before flashing but it would really help others new to the razr to avoid the getting stuck at bootloop.
LOL... I removed them from the OP 3 days ago.
#304
Posted 18 February 2012 - 04:31 AM
-I used it as well and same result
Thanks for the emailing me the file - i did install the ICS Extreme and its working great for me. i love the fact that its Moto, De-bloated but includes the app's that I like. Also, has all the speed upgrades (Great idea).
I downloaded the file to remove the black on black txt but, after reading the posts, I will not flash until root cause is found.
One issue that I have not debugged: Mybackup pro will not load - i will spend time on this issue later today
New Ideas for a ROM:
DSP Manager would be great ( i will try loading apk onto this ROM later today)
overclock in the init file (with all the stock setting) again I will have time to see if this works with this ROM later this evening
Thanks, again GREAT WORK!
#305 Guest_24v_*
Posted 18 February 2012 - 04:36 AM
If you flash DroidTh3ory's original ics zips you are fine.
Then after that you can flash my addon and it should work fine.
The issue came with the files that combined the two.
#306
Posted 18 February 2012 - 04:49 AM
I have had zero problems with the originals and then your menu fix added. I was able to go to the extreme version, add facebook back. The only thing I miss is the universal messaging box as I have 7 accounts (business & personal) and it is nice to have a quick look. I edited the script again, removed the messaging references, reflashed and still not there. I probably missed something silly, will look at it again. Great work by you guys! Thats why I donate :-)From having a few others test this, what I can tell is this.
#307 Guest_24v_*
Posted 18 February 2012 - 04:57 AM
Did you restore a working backup with universal messaging before reflashing Clutch? If the script removes it then it was already gone, there would be no way for the script to "put it back".I edited the script again, removed the messaging references, reflashed and still not there. I probably missed something silly, will look at it again. Great work by you guys! Thats why I donate :-)
#308
Posted 18 February 2012 - 05:47 AM
Just flashed your menu fix and it worked GREAT. No more black on black text.
OKAY on to my next issue with Mybackup pro.
#309
Posted 18 February 2012 - 06:36 AM
if u are having the same issue as me - it's your busybox install. Reinstall it. My only question is why is busybox affected??Just flashed your menu fix and it worked GREAT. No more black on black text.
#310
Posted 18 February 2012 - 06:44 AM
Most likely because the busy box used in the root tool is older than the one I use.
Sent from my AXI0M [R]AZR using Tapatalk
#311
Posted 18 February 2012 - 06:48 AM
Thanks for returning DT! I'm wait on the revised ICS roms eagerly!
#312
Posted 18 February 2012 - 09:08 AM
Thanks!
-elb-
OK, I'm a total newbie at this. I've tried to apply the ROM's to my .173 RAZR on Verizon, and each time I end up with a bricked device which I then factory reset and then upgrade back to .173. Could you give me a spoon, and let me know where I'm going wrong?
This what I've done.
1) Download CLUTCH_CONVERSION_EXTRM_ICS_ROM_SIGNED.zip. Its filesize is 7737897.
2) Copy it to the sdcard.
3) Root my device.
4) Install razr bootstrapper.
5) Bootstrap recovery.
6) Reboot recovery.
Then the phone reboots.
7) Delete cache.
8) Go into advanced, then delete dalvik.
9) Install zip from sdcard.
10) Let it reboot, and then it comes up bricked.
I've tried variations of steps 7-9, i.e. delete data, then delete dalvik, then install. Just install, etc. Nothing seems to work.
I've also tried the non-extrm rom as well.
Any ideas?
Thanks!
-elb-
#313
Posted 19 February 2012 - 06:39 AM
#314
Posted 19 February 2012 - 07:11 AM
Hey guys just installed the extreme version and it is working great, but SQLite editor will not open. Any ideas of how to fix it?
The app needs the OLD version of Busy box. Download the Installer from Market.
#315
#316
Posted 19 February 2012 - 11:23 AM
#317
Posted 19 February 2012 - 11:28 AM
#318
Posted 19 February 2012 - 03:53 PM
Thanks for the great rom.
#319
Posted 19 February 2012 - 07:22 PM
#320
Posted 19 February 2012 - 07:27 PM
