[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#261 DonDraper
DonDraper
  • 156 posts
  • LocationLexington, SC
Posted 16 February 2012 - 01:16 PM
Backup pro opens but is just a black screen.
I have the same issue with Backup Pro. If you don't give it root access, it will open though. I did a restore with mattlgroff's 1.31, updated to 1.73, then rooted with his utility as well. Then installed bootstrap, Clutch Extreme, then signed into the market and pulled down Backup Pro. Black screen and will not start...
  • dustincook87 likes this
#262 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 16 February 2012 - 01:32 PM
I responded somewhere in this thread stating what I had to do to fix it.
Install jrummys busybox in market then run it and install it.
#263 nsaechao
nsaechao
  • 48 posts
Posted 16 February 2012 - 01:33 PM
Ty
#264 johnv331
johnv331
  • 13 posts
Posted 16 February 2012 - 01:51 PM
removed
#265 Guest_24v_*
Guest_24v_*
Posted 16 February 2012 - 02:08 PM
I don't know how to help you, but I would make your own thread asking this in the general section. You should get help faster that way.
#266 tankdroid
tankdroid
  • 36 posts
  • Twitter:@Tank_oZ
  • LocationBirmingham, Alabamastan
Posted 16 February 2012 - 02:28 PM
I need some help and am not sure where to turn as search has turned up nothing. I rooted and installed safestrap and made a few backups. I came across this site and wanted to install the standard stock ui. I uninstalled faststrap and installed bootstrap and installed the stock ui. I then deleted bootstrap and reinstalled safestrap and it said that it sucessfully installed. When the phone boots I get the option to press menu, but no matter how many times I press menu nothing happens untill the phone finally boots into the rom.
How can I get safestrap wprking or at least get my safestrap stock backup working in boot strap?
Again I know this isnt the forum for this but I cant find any thing else and at least one of you may have had it happen.
The same thing happened to me. Started with safestrap and then went to bootstrap. Deleted bootstrap and all the folders associated with it (I thought). Reinstalled safestrap and it would not let me boot into recovery. I ended up using RSD Lite and started all over again. I do not know if there is a quicker or easier way, but that worked for me! :)
#267 johnv331
johnv331
  • 13 posts
Posted 16 February 2012 - 02:36 PM
Tank, can you shoot me a PM with some instructions or link.
#268 randomcold
randomcold
    I'm a virus waiting to happen.
  • 132 posts
  • LocationTuscaloosa, Alabama
Posted 16 February 2012 - 03:03 PM
Is their a problem with Facebook syncing, for my contacts? im using standard
#269 piccit
piccit
  • 112 posts
  • Current Device(s):Razr M
Posted 16 February 2012 - 03:49 PM
No. Are you trying to say that you're having a problem?
#270 randomcold
randomcold
  • 132 posts
Posted 16 February 2012 - 03:52 PM
yes, for some reason when i add my fb acc. nothing happens
#271 piccit
piccit
  • 112 posts
Posted 16 February 2012 - 03:57 PM
Well the standard version doesn't touch Facebook at all. And I'm running a modified extreme version (modified to keep Facebook) and I don't have problems. So you problems are likely not related to this
#272 randomcold
randomcold
  • 132 posts
Posted 16 February 2012 - 04:08 PM
i fixed it, used someone my skills (none)
#273 dustincook87
dustincook87
    Dedicated Supporter
  • 50 posts
  • LocationBakersfield, CA
Posted 16 February 2012 - 05:38 PM
The busybox installer pro by jrummy16? It wont open either man, just constantly shows the loading animation....
free version does the same....
#274 Guest_24v_*
Guest_24v_*
Posted 16 February 2012 - 06:06 PM
*Removed for now.*
  • mugsy77 likes this
#275 mugsy77
mugsy77
  • 235 posts
Posted 16 February 2012 - 07:13 PM
Wow thx 24v. Awfully nice of ya! :-)
#276 maizer89
maizer89
Posted 16 February 2012 - 11:20 PM
tried 24v link still causes bootloop? can anyone confirm or is my razr just going through its time of the month
#277 Guest_24v_*
Guest_24v_*
Posted 17 February 2012 - 03:51 AM
If this is the case, I will take the links down. Those files are the original ones DroidTh3ory put up. I just made a simple fix in one xml file to change the black on black menu issue.
Has anyone else used the links I just put up?
According to Mediafire 17 people have downloaded those 2 files. If you have flashed either one, please speak up. Whether it worked or not.
#278 rpizzijr
rpizzijr
  • 155 posts
  • LocationWallingford, CT
Posted 17 February 2012 - 04:05 AM
What did you modify and how to keep F/B working on extreme?
Thanks!
But wait....if you're here, who's running hell?
#279 addicted2droid
addicted2droid
  • 5 posts
Posted 17 February 2012 - 04:19 AM
I used it as well and same result
#280 snives
snives
  • 947 posts
Posted 17 February 2012 - 04:30 AM
Thanks!
The easiest thing is to just install the Friendcaster app from the market. Otherwise, you are going to have to put back in a few system files and setup their permissions.
