[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#241 jcutter347
jcutter347
  • 72 posts
  • Twitter:@jcutter347
  • LocationSnook Alley, Florida
Posted 15 February 2012 - 09:32 PM
All is working fine for me, but i ran the menu fix zip and that worked great, im also running 24V newest theme for this rom and look really good, but when on the browser and go to the more tab its all black and you can not read anything. thats my only issue, thanks
Where is this menu fix zip?
#242 randomcold
randomcold
    I'm a virus waiting to happen.
  • 132 posts
  • LocationTuscaloosa, Alabama
Posted 15 February 2012 - 10:56 PM
nvm fixed
#243 Extremedigital
Extremedigital
  • 19 posts
  • LocationAuburn, MI
Posted 16 February 2012 - 02:50 AM
Has anyone tried to flash the .176 update after installing clutch?
#244 onemotodroid
onemotodroid
  • 51 posts
  • Twitter:onemotodroid
Posted 16 February 2012 - 03:37 AM
Can someone provide a link to the
The current link is showing only a 2.5M file and the other ICS Extreme has been removed.
#245 Guest_24v_*
Guest_24v_*
Posted 16 February 2012 - 03:40 AM
The link in the op for regular extreme is correct. The file should be 2.5m or so. Just verify the md5 before flashing.
#246 Extremedigital
Extremedigital
  • 19 posts
Posted 16 February 2012 - 04:34 AM
I have all four of the originally posted Clutch rom conversions. I also have 24v's menu fix zip. It needs to be flashed after clutch to fix the black on black. Just need a way to shoot them to you. PM me and we'll figure out the best way.
#247 jcutter347
jcutter347
  • 72 posts
Posted 16 February 2012 - 05:32 AM
Extremedigital, any way you could get me the menu fix as well?
#248 Guest_24v_*
Guest_24v_*
Posted 16 February 2012 - 05:42 AM
Ok, try this..
-Put on sd-ext
-wipe dalvik/cache
-flash zip
-reboot
Please report back if it fixes the problem.
Post #163 :)
  • Extremedigital and nednarb like this
#249 islandfever
islandfever
  • 353 posts
Posted 16 February 2012 - 06:59 AM
Anyone?
#250 islandfever
islandfever
  • 353 posts
Posted 16 February 2012 - 07:00 AM
Anyone?
or 175?
#251 Extremedigital
Extremedigital
  • 19 posts
Posted 16 February 2012 - 07:16 AM
Anyone?
I just did. Wont work. Fails during verification.
#252 islandfever
islandfever
  • 353 posts
Posted 16 February 2012 - 07:19 AM
yea 176 must flash on stock 173
So I think you need to flash back to stock 173 apply 176 then clutch?
#253 Extremedigital
Extremedigital
  • 19 posts
Posted 16 February 2012 - 07:22 AM
Its worth a shot. Hell I have nothing going on at work today......
#254 islandfever
islandfever
  • 353 posts
Posted 16 February 2012 - 07:23 AM
I tired reverting back to stock then tried to apply 176 and it did not work. Perhaps this revert does not TRULY take you back to 100% stock? Might I have to delete bootstrap or do I need to run a reroot? I DID temp unrrot with voodo before flashing 176 but that didnt work either...
#255 Extremedigital
Extremedigital
  • 19 posts
Posted 16 February 2012 - 08:42 AM
I fastbooted back to .748. I am at .176 now and just about to flash Clutch...
#256 nednarb
nednarb
  • 9 posts
Posted 16 February 2012 - 08:46 AM
Post #163 :)
Thanks that worked great. Now I really like this conversion.
Thanks for all the work Droidth3ory.
#257 Extremedigital
Extremedigital
  • 19 posts
Posted 16 February 2012 - 09:17 AM
Ok I restored back to .748 using the Droid Razr utility 1.3, Took the ota update to .173, flashed the .176 update with factory recovery. Booted and did a factory reset with wiping the internal sd card, Rooted, installed razr bootstrap (both with Droid Razr utility 1.3), installed sqlite editor and made my changes then uninstalled (will be broken after clutch flash anyway), Then flashed Clutch extreme debloat with ics theme (wipe cache and dalvik) with using razr bootstrap, booted and then flashed 24v's Menu fix (wiped cache and dalvik) using razr bootstrap.
The System version says .173 But I believe that gets over wrote by clutch. The .176 update appears to still be in there because there's no force close when you hit the search button with the app drawer open and the moto cast widget is there now also
Success? well have to see if it stays stable.....
#258 Guest_24v_*
Guest_24v_*
Posted 16 February 2012 - 09:21 AM
If you guys are flashing my menu fix over the regular (non ics) Clutch you might get some extra blue in there as the framework has some blue in it. So, if you are trying to avoid the blue, don't flash my fix.
For that matter, if you want more blue, you should be able to flash my theme over the regular clutch, and get a bunch more ics blue that way. The menu fix is in there as well.
#259 nsaechao
nsaechao
  • 48 posts
Posted 16 February 2012 - 10:45 AM
Thank you dor the menu fix ^_^
#260 Raw Dodge
Raw Dodge
  • 122 posts
Posted 16 February 2012 - 12:53 PM
I just fastbooted back and got to stock ota .173 so i could take this script....so far so good,thank you for th hard work...Id like to put .175 over it but for now this is great.This is exactly what I wanted....
