[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#221 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 15 February 2012 - 07:12 AM
All is working fine for me, but i ran the menu fix zip and that worked great, im also running 24V newest theme for this rom and look really good, but when on the browser and go to the more tab its all black and you can not read anything. thats my only issue, thanks
No black in the browser so it must have to do with the theme. Let him know.
#222 Sgerena
Sgerena
  • 95 posts
Posted 15 February 2012 - 07:18 AM
Will do thanks.
#223 Sgerena
Sgerena
  • 95 posts
Posted 15 February 2012 - 07:20 AM
So which ICS Rom are you working on? Is it your own rom or are you working on the one thats on the roms page? Thanks
#224 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 15 February 2012 - 07:29 AM
The port of my GNEX AXI0M ROM.
#225 addicted2droid
addicted2droid
  • 5 posts
Posted 15 February 2012 - 07:30 AM
I'd like to see a 1% battery in this Rom. Is it possible?
#226 Sgerena
Sgerena
  • 95 posts
Posted 15 February 2012 - 07:32 AM
How far along are you? Getting close? If you don't mind me asking. Thanks
#227 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 15 February 2012 - 07:35 AM
Not possible... It is ODEX. 1% will be in the Deodex build. I see Nitro put out his update. That would have 1%.
#228 Guest_24v_*
Guest_24v_*
Posted 15 February 2012 - 07:43 AM
I'm on it. It is the expanded menu in the framework xml's. I will fix when I get home from work today.
#229 Sgerena
Sgerena
  • 95 posts
Posted 15 February 2012 - 08:20 AM
Thank you. Love the theme
#230 addicted2droid
addicted2droid
  • 5 posts
Posted 15 February 2012 - 08:25 AM
#231 Extremedigital
Extremedigital
  • 19 posts
  • LocationAuburn, MI
Posted 15 February 2012 - 09:50 AM
I tried something and it worked for what I was trying to accomplish. I fast booted back to .748 then updated to .173 ota. rooted and installed sqlite editor, made my changes and then installed bootstrap and flashed Extreme debloat with ics theme. The changes I made with sqlite editor stayed but sqlite was broke after flashing.
#232 frankyvee
frankyvee
  • 74 posts
  • LocationGeorgia
Posted 15 February 2012 - 03:33 PM
DT any idea what could be causing SQL Lite app to hang at searching for database.
We use this app to get the Mobile Hot Spot working...and a few other things..
#233 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 15 February 2012 - 03:52 PM
Does same for me, actually.
#234 islandfever
islandfever
  • 353 posts
Posted 15 February 2012 - 04:15 PM
OK.....so are any of these working? Seems like some have been taken down....I spent all day RSDing back to 173....dont wanna mess anything up here.
#235 webeougher
webeougher
  • 44 posts
  • Twitter:webeougher
  • Google+:webeougher
Posted 15 February 2012 - 04:48 PM
The non-ICS ones work. I flashed the regular debloat yesterday and the extreme debloat today, and they were both smooth and fast.
#236 islandfever
islandfever
  • 353 posts
Posted 15 February 2012 - 05:20 PM
Can we put the 174/175 radio ontop of this?
Should/Can you update to 174/75 and still put this on after? I have much better luck with the radio from 174, than 173
#237 dustincook87
dustincook87
    Dedicated Supporter
  • 50 posts
  • LocationBakersfield, CA
Posted 15 February 2012 - 05:38 PM
I also bootlooped on the ics ui extreme. I'm currently running clutch extreme and love it. Currently getting 10% batt drain every 5 hours of use.
Great work again DT. My concerns: button savior wont turn my display off, instead it goes to the lockscreen. Backup pro opens but is just a black screen. Is it possible to have a version with the verizon contacts backup assistant functional? On abysm contacts was an issue for me as well :/ Thanks again DT for making the #1 RAZR ROMS! (i know this is a mod, LOL)
#238 piccit
piccit
  • 112 posts
  • Current Device(s):Razr M
Posted 15 February 2012 - 06:43 PM
You can edit the update-script ('\META-INF\com\google\android\updater-script') and remove the lines that remove whichever backup apps you want to keep. Of course, you'll have to restore the apps (or restore back to full stock first)
#239 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 15 February 2012 - 06:46 PM
Dude you getting 10% batt drain every 5 hours??? In other words you should get like 40 hours of usage. DO you have a razor or MAXX
#240 dustincook87
dustincook87
    Dedicated Supporter
  • 50 posts
Posted 15 February 2012 - 07:51 PM
yes, i have the maxx :P
I have no idea how to do that o.O :(
