[Cdma Razr][Gingerbread] | Rom Conversion | Clutch 1.0 | Odex | 4 Versions | 02-13-2012 |
368 replies to this topic
#181 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 14 February 2012 - 05:00 PM
Hmmm, I just flashed the Modded ICS Standard Debloat and am also got into a bootloop. MD5 checked out okay.
Th3ory, did you copy the file the 24v posted above into the standard? He said he only modded it for the extreme. Is there a difference in the framework between the 2 versions?
Frameworks are the same in both. I flashed it also.
#182 1BadHEMI
1BadHEMI
  • 12 posts
  • LocationPasadena MD
Too late. Im stuck in bootloop. Cant even go back to stock through fastboot since low battery..sigh
Me too! Bootloop sucks.....Trying to charge this thing up while bootlooping very hard to do...is there a way to charge while in a bootloop??? I can't get this thing to power off...
Did you guys try holding down the volume key while pressing the power button? Thats how I got out my bootloop...
#183 1BadHEMI
1BadHEMI
  • 12 posts
Posted 14 February 2012 - 05:01 PM
Will try again and see if it does it again?
#184 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 05:03 PM
Cache and Dalvik only.
#185 islandfever
islandfever
  • 353 posts
Posted 14 February 2012 - 05:05 PM
DT:
How do I use that stock rooted 173 that you have up on the sticky? Safestrap (safe? non safe side)? Stock Rec?
Also, right now I have 174 and your gofaster on the non safe side and Ecplise 1.2 on the safeside.
Where do your clutched ones go?
#186 1BadHEMI
1BadHEMI
  • 12 posts
Posted 14 February 2012 - 05:13 PM
Thats what I did...
#187 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
DT:
Uninstall the recovery, uninstall Safe strap, install BootStrap, wipe it all, flash the Stock rooted 173. Boot it.
Wipe cache, Dalvik and flash it.
#188 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 05:14 PM
Thats what I did...
Seeing how you recovered from the Boot Loop that fast, I assume your using Safe Strap?
#189 1BadHEMI
1BadHEMI
  • 12 posts
Posted 14 February 2012 - 05:25 PM
No, Bootstrap. Just got finished with RSD. Updating to .173 now...
#190 ncwildcat
ncwildcat
  • 109 posts
Posted 14 February 2012 - 05:45 PM
OK..almost back to stock .173 after fastbooting to get out of bootloop. Want to flash the ICS Xtreme, but it sent me into a loop last time. Is the standard better or should I stick with extreme? I ask because I see that standard has also sent people into a bootloop and I don't want to spend another few hours fastbooting again
#191 1BadHEMI
1BadHEMI
  • 12 posts
Posted 14 February 2012 - 05:50 PM
Okay, I am done! Bootlooped again. Don't get it? Will stick with the regular non ICS version for now...
#192 ncwildcat
ncwildcat
  • 109 posts
Posted 14 February 2012 - 05:51 PM
standard or extreme?
#193 1BadHEMI
1BadHEMI
  • 12 posts
Posted 14 February 2012 - 05:53 PM
standard
#194 ncwildcat
ncwildcat
  • 109 posts
Posted 14 February 2012 - 05:55 PM
standard
OK. Will try extreme when I am done with this update in a few.
#195 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 06:02 PM
Hold on... I am looking at the framework-res. I see the issue.
#196 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 14 February 2012 - 06:07 PM
Thas what i did. It kept rebooting or if I held the volume up and down with power, i was able to get in stock recovery and fastboot only but then it will boot loop
#197 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 06:13 PM
The ICS Conversions are fixed. My VPS was taking the .zips apart on uload. lol.
  • mugsy77 likes this
#198 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 14 February 2012 - 06:16 PM
THanks DT I always wanted to give my phone an oil change anyway :P
#199 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 06:18 PM
Its for it every once and awhile.
#200 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 14 February 2012 - 06:19 PM
Yup ;)
