Best Answer OldUncle , 16 December 2015 - 12:45 PM
Mr.spainter
Thank you for your kind support.
TWRP is DONE with your help!
Have great day!
Go to the full postBest Answer OldUncle , 16 December 2015 - 12:45 PM
Mr.spainter
Have great day!
Go to the full postPosted 15 December 2015 - 05:42 AM
Hi all,
That's my sister's XT926. I gave it her after I bought Droid Maxx.
The device was Unlocked and Rooted with custom CWM TWRP installed by me.
Yesterday, my sister asked to do factory reset on her XT926... and I did... via CWM TWRP 2.8.0.0
Seems I choose wrong option and deleted OS itself. No backup... nothing.
Could you please, advice me How can I get it back to life? (With root capabilities of course).
OldUncle
EDITED:
Edited by OldUncle, 15 December 2015 - 02:33 PM.
Posted 15 December 2015 - 05:51 AM
Hi all,
The device was Unlocked and Rooted with custom CWM installed by me.
OldUncle
Try downloading the .15 version of KK from
Setup and use House of Moto 4.3 to flash
Posted 15 December 2015 - 12:10 PM
There is no root for this build. Repeat, no root. It is not rootable. This does mean that root is not available.
spainter
Thank you for your reply.
Is there any other way to solve the problem but preserve the capability to root the device?
Additional info: TWRP 2.8.0.0 Installed and working. and I used "Advanced wipe" with all options ticked
Result:
After restart it's stuck on Moto logo
Posted 15 December 2015 - 12:42 PM
spainter
You are unlocked. You don't need an exploit to regain root. All you have to do is have HOM install twrp when you flash or flash twrp with fastboot twrp will offer to root the phone for you after first successful run. then install the 2.4.6 version of Supersu from the playstore and your good to go. Since your bootloader is unlocked you will not be with out root. Just make sure you bootloader status is unlocked status code 3.
Posted 15 December 2015 - 01:02 PM
spainter
Great!
That's what I needed to hear! I just needed to make sure!
Thank you very much sir!
Posted 15 December 2015 - 01:19 PM
TWRP 2.8.6.0 is the newest one for the xt-926.
Posted 15 December 2015 - 02:32 PM
Great!!!
Everything is done like a charm!
I got the device back to life thanks to advices of Mr.spainter and the great tool (House of Moto) from Mr.SamuriHL
Regards!
OldUncle
Posted 16 December 2015 - 09:16 AM
Well, yesterday I finished flashing very late and didn't check for custom recovery...
Today, I see that No custom recovery installed.
This is a screenshot I made yesterday
"Custom recovery not found"
I followed instructions and have put TWRP-2.8.6.0-xt926.img into folder named RECOVERY under HouseOfMoto.
What else I needed to do?
I downloaded the recovery file from this link
Any advice?
Posted 16 December 2015 - 09:32 AM
Any advice?
Posted 16 December 2015 - 12:45 PM Best Answer
Mr.spainter
Have great day!
Posted 16 December 2015 - 01:34 PM
Mr.spainter
Have great day!
You are welcome. Glad you're back up and running.
